Top convertible problem
Old Mar 14, 2013 | 04:40 PM
Mrmiata's Avatar
Default Re: Top convertible problem
I was hoping you'd pop over into this thread..
And I'm fairly sure I've seen cylinders on ebay on occasion..
Old Mar 14, 2013 | 04:57 PM
Originally Posted by Dragoncross
The latch of the window has a bit of resistance but as far as you make the turn to the right direction you'll be fine.
Just make sure you have released the top at the windshield FIRST, otherwise there is too much pressure on the rear bow latch.
Old Mar 14, 2013 | 05:05 PM
Manual top down for dummies :
1. release the D-ring and push the top up.
2. open trunk, turn the 5mm hex nut to release the window bow. close the trunk.
3. lift the window bow and use slim 10mm wrench or special tool to release tonneau latch.
4. lift the tonneau and hold it up.
5. fold the top GENTLY into the tonneau area.
6. close the tonneau and latch with the 10mm.
Manual top up :
1. lower the windows.
2. release and list tonneau.
3. lift the top and hold the rear bow up.
4. close & latch the tonneau.
5. close & latch the rear bow.
6. close and latch the D-ring.
HINT: If you hold the left front side of the top with your left hand and rotate it down slowly, it won't SLAM, then latch the D-ring.
( do this even when the top is working correctly )
Old Mar 14, 2013 | 07:09 PM
I take it you bought the car with the broken top? Or did it leak fluid and you had the cylinders rebuilt?
I am with Dave on this one. You may have air in the system. I haven't had to work on mine but I would think you need to bleed the air out of the pump. Just my take if all the sensors are fine.
Old Mar 15, 2013 | 04:46 PM
johnlisa61's Avatar
Thanks....I did find the leak...but also a little hydraulic fluid, did the trick... It's been up and down and filled the hydraulic fluid. So, I can no have the top down....and not worry too much.
Also.....another problem just surfaced.. The spoiler will not manually deploy and it was working before. I haven't touched anything related to that area or spoiler.. The dash indicator shows a red light when starting. If the red light lights? Is the fuse still good?? Just wondering. Also, is there a way to reset ??
Thanks to all who have helped.......It's been a good feeliing to be helped so feely.
John L
Old Mar 15, 2013 | 04:49 PM
johnlisa61's Avatar
Probably got it with a leak....but who can know now?? I know I've used it over 20 times and now I do have it working with replacing Hydro fluid....I'll keep an eye on it..
Thanks so much for all your help.
John L
Old Mar 15, 2013 | 04:54 PM
johnlisa61's Avatar
got the hydraulic fluid and filled the resv. Yahoooooo It worked. and its down now .. I'll keep an eye on the level... minor inconvenience...
Thanks...had to do it a couple times to get the fluid around
Now have new problem....spoiler wont deploy from the dash switch. On starting car red light goes on...it has worked ... I didn't touch anything related to it... Is there a reset???
Thanks again for all the helpful suggestions... and insight.
John L.
Old Mar 15, 2013 | 06:24 PM
It works going down the road but not on manual correct?
Old Mar 16, 2013 | 05:08 PM
johnlisa61's Avatar
Since this problem.....I've had company...so I haven't been able to take it out to 62 + mph. , to see if it automatically deploys. Really that's the important part that I would want to work..
Hoping to get to it in a couple days. Alot of family visiting.
Thanks,
John L.
Old Apr 28, 2015 | 04:11 PM
mlwest8783's Avatar
John L.
Glad you got it working again!
It kind of sounds like the same problem im having with mine. So you added fluid and it worked? Did you have to do anything to the top to get the fluid through out the system? My fluid was at the minimum line so I filled it up but that didn't do anything.
Here is what mine is doing, is this how your was?
Old Apr 28, 2015 | 05:41 PM
https://www.youtube.com/watch?v=gXDIE0rolrE
There are two cylinders for the top bow, I'd suspect one of them has gone on strike.
Have you looked really good for a leak?
Old Apr 29, 2015 | 06:50 AM
mlwest8783's Avatar
Have you looked realty good for a leak?
Ok, I will inspect them a little more closely, thanks
Old May 4, 2015 | 04:36 PM
mlwest8783's Avatar
Found out what the problem was! The switch on the bow lock release is having problems. I disconnected the plug and it opporated perfect. The only problem is that it doesn't recognise the bow is locked into place so the trunk will not unlock.
Old May 4, 2015 | 07:52 PM
mlwest8783's Avatar
I took off the locking mechanism, and found that a spring was just hanging there. I reattached to where it needed to be and now the top works flawlessly. I wanted to give my update so anyone have the same problem I did so look there during your troubleshooting.
Old May 4, 2015 | 07:59 PM
Good tip ! Thanks for getting back !
Old Feb 2, 2017 | 11:59 PM
Jarrettc2008's Avatar
where is this spring. or what does it look like. I dont see one on mine.
Old Feb 3, 2017 | 02:47 AM
djohn14296's Avatar
Smile Re: Top convertible problem
My bad, have to have so many words and couldn't figure how to delete.
Last edited by djohn14296; Feb 3, 2017 at 02:50 AM. Reason: didn't read enough posts.
Old Feb 3, 2017 | 08:22 AM
  #38 (permalink)
mlwest8783's Avatar
You have to unbolt the locking mechanism and remove it from the lid, you will see a spring on the underside. Its really small so if you have to reattach it, you will need to use really small needle nose pliers. It was easy to fix, luckily that's all that I had to do.
ZERACER
Jul 7, 2020 10:21 PM
Hoppy
Dec 7, 2018 07:36 AM
PimpDaddy
Sep 29, 2016 11:55 PM
mike28117
Jul 17, 2015 01:59 PM
Bayukbros
Jul 17, 2015 11:21 AM
