Looking at a car and saw this...need some expertise.
Old Sep 24, 2016 | 10:25 PM
wiplash's Avatar
Default Looking at a car and saw this...need some expertise.
Please see photos.
What would cause all the oil mist/residue in front of the Supercharger?
Thanks
Old Sep 25, 2016 | 12:00 AM
Billy22Bob's Avatar
Default Re: Looking at a car and saw this....need some expertise.
hmmm....doesn't look severe, just maybe never been cleaned - general road/engine dirt.
Looks like mine did when I bought it at 70k miles.
Give it a clean and recheck a couple of hundred miles later.
Old Sep 25, 2016 | 07:29 AM
Can't really tell for sure. But a couple of pictures look like either the crankcase breather covers (mounted on top of valve covers) and/or the valve covers may be leaking. The crankcase breather covers are prone to developing leaks as the gasket is only an RTV-type sealant and the factory installation was very poor quality. There are quite a few posts about repairing this issue.
Some folks have had actual valve cover leaks and you can get new gaskets for that.
Later,
Old Sep 25, 2016 | 09:48 AM
That one photo shows oil seeping out of the breather cover seal - like 95% of all other Crossfires do eventually.
No reason to not buy the car!
Old Sep 25, 2016 | 01:34 PM
NeedsWings's Avatar
needs a valve cover reseal and new oil cap gaskets
Old Sep 25, 2016 | 10:13 PM
wiplash's Avatar
How much would it cost to take of these issues?
Also the Headliner is starting to come off. What's the typical cost for that?
Thanks.
Old Sep 26, 2016 | 12:59 AM
Billy22Bob's Avatar
Been a couple of years since I did it, but to clean the breather, I think you get better access to the internal galleries by pulling the full covers off ..??
Mine were full of crap since the previous owner didnt change the oil for at least 35k miles prior and possibly even used semi synthetic - #lotsofgunk.
Use MB recomm. RTV and maybe consider changing the cover gaskets whilst out.
PS - If the oil is clean on a tissue wipe of the dipstick - not always guarantee of good service intervals - may have just been changed - should use MB recommended Mobil1_0W-40 as well = $$.
Old Sep 26, 2016 | 06:30 AM
Thanks.
Most of us have made the crankcase breather & valve cover repairs ourselves. Not particularly a difficult task, but is somewhat time consuming. With the crankcase breather covers, lost of preparation required to get the surfaces completely clean. I did this repair by only removing the air cleaner box and without removing anything else (i.e., valve covers or any of the coil packs). If the valve covers are also leaking, then you can try just tightening the valve cover screws to 7-8 ft-lbs (these are the larger screws you see throughout both valve covers & a few pass thru the crankcase breather covers). In many cases, these are just loose and the valve cover leaks.
And as a precaution, when performing the crankcase breather repair, never re-use the aluminum screws that hold these down on the valve covers. These are a 1x use only! And don't require much tightening force (maybe 3-4 ft-lbs). Just slightly over "finger tight" will do. Otherwise, you'll break the screw head off & then be required to extract a screw thread using an "easy-out". Motor is typically "rock solid" in these cars, but it isn't "Detroit iron". Takes more "precision or critical" maintenance than a "backyard mechanic" tugging & pulling on these engines.
Regarding the headliner, again, many of us have completed a recovering ourselves. Somewhat of a pain getting the headliner out & back in. And lost of prep work to get the headliner thoroughly clean before recovering it. If you remove the headliner yourself & take it to an upholstery shop for recovering, probably going to cost you $100-$150. If you have the upholstery shop remove & re-install the headliner, probably talking $250-$300.
And as pizzaguy stated, neither of these would keep me from purchasing the car in & by themselves.
Old Sep 26, 2016 | 06:32 AM
needs a ..... new oil cap gasket
Never knew I could get just a gasket. Learned something new today!
Old Sep 26, 2016 | 06:42 AM
With the filler cap extension fitted, as they came from the factory, there are two identical gaskets.
CLICK
Old Sep 26, 2016 | 06:54 AM
Yeah - I saw this in the PDF exploded view I attached to an earlier post in this thread. Never really paid much attention to the diagram. Clearly shows the 2 gaskets/seals.
Old Sep 26, 2016 | 08:40 PM
chuK_138's Avatar
Default Re: Looking at a car and saw this...need some expertise.
Might be the only who's experienced it to look, but I thought I saw oil flung on the rubber boot by the SC pulley. I would suggest wiping it off and checking the smell of it. If it's putrid smelling, the SC clutch is leaking from behind and will need a new blower.....been there, done that. Hopefully it is just belt dust, but there's a lot of it there.
Old Sep 27, 2016 | 01:34 PM
waldig's Avatar
Talking Re: Looking at a car and saw this...need some expertise.
Here is my 2 cents for headliner:
https://www.crossfireforum.org/forum...installed.html
enjoy, Woody
Old Sep 27, 2016 | 03:49 PM
wiplash's Avatar
That's what I was afraid of.
Old Sep 27, 2016 | 04:43 PM
I do not think that oil blow by from the SC necessarily means a new or recon blower. If the rotor bearings had failed then the rotors may have touched but if the oil seal(s) have failed anywhere then replacing the bearings fitted with the correct seals would cure the problem. The rotors and gears are in separate chambers, separated by a wall with bearings in it. The gear chamber will see varying air pressure due to blow by, this would be evened out to some degree by the hole in the pulley shaft.
That is my take on it anyway.
dpeel82
Sep 16, 2016 09:19 PM
poopbicycles313
May 10, 2016 05:21 PM
Dgiomatch1
May 10, 2016 06:42 AM
LuckyXF05
May 2, 2016 04:49 PM
jthaub
Apr 19, 2016 06:47 PM
