- Just ordered new wheels (rims) and tires (tyres)
- Any photoshop experts out there?
- Rims match?
- Touch-up paint for wheels
- POLL: which wheels... Limited or SRT-6 ?
- Calculating correct offset (without spacers)
- 18" front, 20" rear
- Winter Wheels...
- Optional tire sizes on factory wheels?
- Question about Tire & Wheel insurance
- Need 30 For Tein Adjustable Suspension Kits
- Need help; may be being taken advantage of by repair shops
- Anyone go from Conti OEM to the Pilot Sport A/S?
- Snow Tire Fitment
- Wheel options
- brake question
- Chromed Factory Rims
- Problems with Brakeworld.com
- Resetting tire pressure sensors
- axis wheels nitto 555s
- Seller says stock tires will fit rims
- Tire Rub
- AMG or SRT6 Sway bars??
- clunking in rear end
- Putting thinner tires on the car?
- Anyone selling tires 255/35/19's??
- 235/35/19 for snow tires
- Suspension question HELP?
- Whats the criteria for a spare
- Looking for SRT6 wheels?
- Brake pads
- Got new tires what a howel!! Need Help ASAP!
- Carbon fiber wheels...
- New rims without pressure sensors!
- Tires rubbing with stock wheels!
- e brake
- gold spoke rims
- Low pressure warning question
- I am confused on rims for my Crossfire
- 18" rim at rear axle ?? - will it work?
- 16 inchers for snow tires
- Not a regular problem???
- Does anybody have the SRT-6 rims chromed?
- Mandrus Wheels
- Factory rims H E L P !
- Tire Pressure Monitor
- HDDP: Your new brake upgrade is ready
- Squeak from driver's side rear suspension when it rains
- Painting the calipers...
- H&R Sport Spring Set
- Wheel Spacers
- Wheels I picked out, will they fit
- Black Stock Wheels
- SRT6 Stock Wheel Weight?
- Where can I buy Lorinser LM6 replicas? Can't find them
- smallest i can go
- can i put 20's on all four corners?
- Backing plate question
- 4 sale wheels tires and spacers
- just installed new tires... wow...
- What color calipers?
- Front tire size
- Need opinions. Tried on some wheels today
- Lowenhart LSR 20" Rims
- Tire Pressure - Ambient Temp.
- Morse Ceramic Pads
- Offsets? Huh?
- 18x8.5 and 19x9.5?
- Power Slot - cryogenically treated slotted rotors
- Michelin Tweel Concept Tire
- Brake Disc Shields for SRT-6 Wheels?
- Tire inflater
- Black Rims for black cars?
- help for new srt6 wheels
- XF Wheels Fit Other Vehicles?
- Lowenhart LD5 wheels
- 20" all around ???
- Stock Xfire wheels in black
- Best looking alloys on a Crossfire ever?
- wheel spacers
- New ADR Sterling Wheels
- Changing Tires
- Anyone using "run flats"
- Need more Bling? Check out PimpStar!
- Used Michelin PS2s for sale
- Factory wheel size
- Well here they are
- x-fire vs slk h&r cup kit??
- wheel rim conversion kit ... for the crossfire...
- 19" Giovanna wheels on 2005 Xfire?
- bas esp light
- Bleeding Brakes
- SRT-8 RIMS Fitting question
- Offset
- Black wheels for crossfire
- how to install brake pads
- Eaibach spring installation...
- SRT-6 and eibachs?
- 18 in rims
- Fitment question
- SRT6 Brake Upgrade (FINALLY)
- Finally... The Correct Part
- Rotor / Pad bedding Proceedure
- New Track Tires & Wheels Photos
- Need New Tires at 16k....Guess i shouldn't drive it so hard! :)
- Crack in rear rim
- Suspension
- ordered my new eibachs!
- Bedding Brake Pads/Rotors
- SP Street Plus/ Porterfield pads?
- squeaking brakes - when to replace?
- Rear Rotor Removal !!!! HELP
- Tires for Cheap
- 7.5 X 17 rims/ 5 X 112 / 42 mm positive offset? will these fit?
- will these fit
- OEM Braking System Upgrade
- Eibach springs part number?
- do you need 2 front tires (all seasons)?
- Stop Tech Big Brake Kit
- Zone Wheels
- Alignment issues with Eibach Pro-Kit??
- 235 front's???
- Anyone selling their 19" rims?
- New Wheels 4 My Track Tires
- spare donut
- Can I use 35 mm offset on a 17 x 7 inch rim? (for snow tires)
- Anyone interested in $239 17" snow rims? Any insight or help would be appreciated.
- Supension upgrades
- sloted rotors
- chrome mercedes center cap?
- My Other Weekend Project
- Wheel Burs & Scrapes Repaired
- Please post your ride height...
- Michelin Pilot Sport A/S
- Black/dark rims...
- Nitrogen instead of air in tires??
- Brake rotor wheel flange
- Fuse for TPMS
- Michelin Pilot Sport Cup
- Intrax Springs
- air pressure light
- Custom vs Stock Suspension VIDEO
- Crossdrilled rotors for SRT-6
- EBC Green today!
- Anyone tried Dunlop Winter Sport M3 snow tires?
- CERAMICOOL Brake Pads
- Bbs Lm, Work Vsxx, Hre, Kenisis
- Grease Splatter??
- Camber Adjustment Bolts
- Lowering your crossfire
- Wheel Spacers
- just slammed my srt6 to the ground with bags!
- Why are the rear rotors solid and not vented?
- What's the treadlife on the runflat tires?
- Foose 20" Lusso wheels
- H&R Cup Suspension Kit - Track Experience??
- "chrome" crossfire rims $799...
- New Wheels
- Soft ride?
- New BREMBO BIG BRAKE KIT 4 X-FIRE
- Nails in tires
- Weight of OEM wheels???
- Need help. Lug bolts or Lug nuts? on XFire vs. MB SLK Thanks
- When I turn my wheel to the extreme left I hear a grinding or rubbing
- Lug Bolts
- UK Tyre Spec
- Squeaky Brakes
- Brake Pads / Rotors Life
- Curb rash wheels...need some help!
- Is there a "BIG" brake option for the Xfire?
- Crossfire Rims - Deep Dish
- Roadster Limited Dustless pads?
- Rotex Install Help
- Tire Pressure problem.
- Anyone willing to trade?
- Front tire cupping
- our rims are apparanly made by Ronal
- TIREFIT system with tyre repair sealant
- Thumping noise in rear when sitting idle...
- D - Minus Sizing for Winter Snow Tires
- Crossfire with aftermarket wheels
- Loose rear suspension
- For Sale: Brabus Monoblock V 19"
- 20's?
- Sidewall Bubbles - Michelin Refund?
- Good Grief -- Can't find brake fluid
- Winter's over (I hope) - Prepare Xfire
- Wheel Offset Compatibility
- rotex gold pads for srt6
- Can some post the centerbore for 2004 XF rear 19" wheels? TIA
- tire puncture kit
- Rotex Gold Brake Pads
- new wheels
- Srt6 Rims
- Brake Noise
- your thoughts please
- rotex gold part numbers please
- Do lowering kits void warranty?
- Tire Size Replacement Calculator
- Self sealing tires or run flat
- Tire and Rim Conversion Chart
- non OEM winter/ASPs
- Towing with the Crossfire
- Bolt Pattern for Crossfire wheels
- brembos and rotex
- $30,000 new car and I still need $1,500 in snow tires? How do we contact Chrysler?
- Puncture repair experiance
- Custom Sway Bars
- H&R SLK vs. Crossfire
- Front & Rear Sway Bar Photos ?
- Cheapest places for XF tires?
- Ceramicool Pads, Any Experiences?
- Custom Strut Bar Tower & Sway Bar Kit
- Suggestions for snow tires
- ROTEX GOLD PADS and PRO KIT???
- Blizzaks on for the Winter (photo)
- Chrome Crossfire Wheels
- 265/30/19
- Fixing a bubbled tire
- SLK32 Springs
- Stock wheels offset
- popping sound from left rear
- Concerned about Continental Tires
- H&R springs...
- New Wheels
- Eibach Pro Kit Question
- Eibach Pro Kit qun...
