View Full Version : Crossfire SRT6
- Remote Tune or Dyno Tune?
- NAV and Other Apps
- AVT Bosch Intercooler Pump
- SC clutch noise
- Code3 Pulley Issues...
- Throttle Lag
- Intercooler tank
- Need a help, jerking in the transmission
- Black Beauty going into storage...thoughts?
- Ultimate Dead Pedal
- intercooler leaking
- what temp does SC clutch disengage
- Who Graffiti my car?
- Need help please
- New SRT-6 Galleries: Rims, Paintjobs, Engine bays, Interior...
- Srt-6 mosaic
- speed limits removed
- SRT 6 Coupe in Austin For Sale (not mine)
- Another SRT for sale in California (again, not mine)
- where does this part belong?
- ebay srt6 Dallas $14,000 or make offer
- misfire not detected appliance bosch for the diagnosis
- Pics of SRT6 Engine
- Gasket part number needed
- 268 SRT-6 in 1 photo
- Problem, help needed!!!
- fuse relay box
- translate in italy
- Torque fast road paddle stage 3 clutch kit chrysler crossfire 3.2i v6*
- air box cover
- CRAP!!! Broken wheel!!!!
- SRT6 deceleration noise
- Startech 4.4s
- Thoughts on a Braided Power Steering Line
- Dyno results of ic pump failure before/after
- Anyone running Android OBDII Apps - Torquepro etc.?
- cost of ownership
- S/C Pulley Bearing
- Tranny fluid and washer fluid reservoir, repair cost estimates sought
- Ground Control Suspension Kits!!!
- ID this pulley please
- Getting Rid of Some SRT6 Stuff...
- Anyone near South Amboy NJ who can check out an SRT6 roadster for me??
- pulley went bad
- Need Advice on Mods
- lpg conversion kits for cars high-performance
- Heat Exchanger cooler
- SRT6 Roadster Puzzle
- Monthly Canibeat Meet - In 'n Out at Pacific Commons (Fremont, CA)
- Have y'all's updated Bosch pump gone out?
- 2006 White SRT6 roadster?
- Dyno ?, Numbers don't add up
- What's a reasonable coolant consumption rate...?
- Rear differential slk32 vs srt6
- Supercharger pulley problems?
- mods
- About to buy this beauty
- srt6 tcu gearshift eurocharged
- AMG S/C from my SRT6 for sale
- Need a new IC pump...But which one???
- Ultimate fuel rail
- reverse polarity
- SRT6 calipers
- Sold SRT6
- What's a used S/C worth
- IC PUMP question
- Hair Trigger gear selector switch + DIY appreciated
- 1/4 mile, final gear and rpm
- How many here have: 61mm, SL55 pump, 550cc injectors, ec tune ?
- Unhappy roadster...
- Eurocharged tune issue
- How long did your lens restoration last?
- The differential Carrier
- pulleys
- is this a Code 3 pulley?
- Best mods
- How Do I Remove the Center Lug Cover Plate?
- Eight years later... she's still got it.
- code 3 stacked
- Just wondering if
- Another Damned InterCooler Inquiry
- S/C pulley noise?
- Changing ignition switch and lock cylinder
- New Custom Plate
- Where's my boost!
- Throttle spastic
- SRT-6 Sold in Ohio
- spark plugs and wires
- Need some help from the "Mod" Squad. (Tech. guys)
- SRT-6 ssb 12,000 mi roadster for sale in MN
- Nissan GTR v SRT6 - there must be some similarities...
- Eurocharged Black Friday - Our biggest WEEK of sales ever!
- Checking interest on my SRT
- Rear Diff
- SRT-6 in CA for CF hood project
- Value of SRT-6 Roadster
- Rolling Shots of my SRT
- 253 SRT-6 in 1 PHOTO
- Crank Pulley Fell Off
- Sb
- great read
- Finally the tune is done, 366whp
- Anyone want their SRT with a 6-speed?
- Bittersweet day...traded in my SRT6
- sidelights
- SRT6 for sale in South Texas
- Bad News and Good News...
- Vegas Baby
- Give us a follow please
- rear hub/half shaft removal?
- replacing my intercooler pump
- Newbie w/broken motor mount
- Mile High Horsepower?
- what's a sure fire way to make sure your harmonic damner is okay?
- Supercharger clutch plate rivets
- defective Michelin's
- Here's one I haven't read about before...
- Air fuel bouncing on my wide band
- Anyone in TX/Houston /w spare $60k...SLR McLaren 15k miles for USD$60k
- Will a Needswings DCAI for an NA fit an SRT?
- 6 Speed
- 2008 ZH SRT6 2,375 miles...very expensive here...
- Looking for the leak.
- Ebay, nice SRT with the goodies
- Aero Blue SRT-6 Good Deal or Not?
- Waterless coolants - any updates?
- Needing a Pizza Delivered Fast!
- HELP-Buying SRT6-What problems to look for?
- Has anyone ever successfully installed an SL55 SC onto the M112?
- FS: 185mm pulley + PSK
- AUTOWEEK magazine Oct. 28, 2013
- Looking for speedometer picture
- Autoweek Article (Oct 28, 2013 Issue)
- For those of you so inclined - TCU dismantle and repair
- Oil cooler coolant leak
- Intake air temps high.
- Is this a fair repair quote?
- Rattle from headers...
- Has anyone ever installed a pre-cooler temp sensor
- New gearing in my SRT6 - from 3.07 to 3.27 - Success!
- It's been awhile SC pulley help
- SRT6 is not disappointing!
- Australia's Great Race Start = 22:55 GMT 10/12/13
- SRT-6 Coupe Value (in parts)
- help srt6 owners with sb
- Scored a Kestrel today on Ebay!
- twins
- Vacuum and boost leak, EC 61mm pulley
- Got a Set of Michelin Pilots today - SLK32
- help translate file pdf in italian paddleshift kit
- Another 61mm SC pulley
- New worlds quickest and fastest crossfire!!!!
- Needswings Took my money...
- srt6 roadster fyi
- 178 Crank pulley boost numbers
- SRT Help... MAP, and ECU (PCM)
- Holy whiplash batman!
- time for an oil change?
- N/A owner wanting an SRT6!
- new driveway and gopro
- Awesome new SRT-6 emblems on Ebay!!!!!
- maintenance check up
- Needswings Cutout Downpipes?
- Ic pump at Euro Charged
- Which of these batteries is more powerful and therefore suitable for departures on SR
- Change the fan?
- lowering battery voltage, engine startup problem
- Boost comparison - 65mm and 61.9mm pulleys
- best plug gap
- rattle from dash / heatshield?
- SRT-6 Differential (Carrier Assy)
- Some of you SRT-6 owners are missing out on the action.
- Need a body control module 5189811AA
- datalogs LEAN AFR
- Looking for a SRT6 in Cali for prototype
- Notes from the WannaGoFast 1/2-mile event... good, bad, & ugly
- intake/intercooler
- V6 exhaust design
- engine problem
- Where to find a BCM for the SRT-6
- i neeed a advice please
- ATF additives - anything worth while?
- Cracked Rear Wheel - Looking to replace
- thoughts on water pump supplier...ebay...cheap...
- I hope someone from the forum got this SRT6 roadster with only 7,357 miles on it!
- Take the car to a garage or not?
- Rear tail light pigtail
- New Pics
- Shock replacement question
- afr
- SRT6 Family need help.
- Own the FIRST SRT6 ever! (Really?)
- Check out SRT-6 pictures to instagram (we can post for you)
- Prescott AZ Repair Shop
- Color code for engine cover and air cleaner
- SC pulley bearing...
- Refinishing the wheels - not possible except at Chrysler dealership?
- air pump function
- What is the real deal with adding hp to the srt-6
- 174 SRT-6 in the VIN# gallery@www.srt-6.com, have you added yours yet?
- Needswings downpipes - cutouts open
- Diff cooler anyone?
- My srt6 roadster
- Safely use drag radials
- private party value car SOLD
- SRT le Mans
- Adjustable tunes
- Name this hose
- aem gauges
- supercharger issues
- SRT6 takes on the Nurburgring
- srt6
- '05 SRT-6 or '04 crossfire
- Splitter, Brake ducts, and hood vents completed
- Steering setup/alignment SLK32...going in for a tune...
- Ye 'olde chestnut...conductor plate
- sl 55 y pipe prices
- Suddenly no brake lights-anybody else?
- 6.5 ltr Brabus R170 SLK ...
- Help a kid out
- arkansas
- return from hail damage!
- Dallas shop to mod my SRT6?
- 20 inch rims PLEASE HELP
- Give me a freakin brake...
- ++ Added some pulley bling ++
- Got Torque
- Don't give me any lip velociabstract!!!
- SRT6 MAF location?
- New Eurocharged DC Location!
- How I got my rear in a sling again, sorta
- SRT-6 photostream
- Value of SRT coupe with salvage title?
- Fuel Filter/Regulator: hose to charcoal canister; why?
- Screaming Noise
- C.a.i.
- TB, tune and wheel cap questions.
- Rear Wheel Bearing Replace Help
- Tell Pizza what to do!
- Why Woody did not get the srt to Pa, blowed up
- Eurocharged in the UK
- Crossfire Easter Eggs
- Eurocharged Cross Canada tune trip
- Need some differential assistance, please.
- Header/stock exhaust sound
- blowed it up on way to carlisle
- SRT-Oil Smell in Cabin-At High Speed
- AMG Intake Manifold
- Help with sourcing EPC pls...
