PDA
View Full Version : Troubleshooting & Technical Questions & Modifications
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23
  1. Key chip
  2. 185crank an crossovers
  3. Power steering leak - high Pressure hose?
  4. Chrysler Crossfire PUSH to START Button - Keyless Entry Car Alarm System
  5. Coolant level in reserve/overflow tank
  6. DRB III Emulator?
  7. Car Randomly Goes Dead While Driving
  8. Can a new RCM affect the TPMS?
  9. Suspected Current Drain - need advice please
  10. Windshield washers don’t spray water. When I try and fill tank it runs out on ground.
  11. Another No Start thread
  12. Can a new RCM affect the TPMS?
  13. Driving Habit - Putting auto in neutral at the lights
  14. No Alarm Sound
  15. Swap convertible tops?
  16. P0170 driving me batty
  17. Sweet Coolant Smell in the cabin.
  18. Nitrous window switch
  19. Low coolant light
  20. Newby having trouble starting my new 2005 Xfire
  21. Stuck in Park - too nice to be a paperweight!
  22. Holy keytastrophe batman
  23. Spoiler not deploying
  24. ***RCM issues ?? HELP !
  25. Car won't start!!
  26. Another Battery Drain Thread
  27. Tool for Roadster Convertible Top
  28. Lock and siren troubleshooting. Need help!
  29. SRT Random no power
  30. Code 0410 discoveries
  31. Will the SRT dash cluster fit in a roadster?
  32. Turn signal Question
  33. RCM issue? No start, lots of dash lights, P0600, wing up
  34. Couple of questions - Autocross car build
  35. Mid Or Rear mounted Hemi V8
  36. Starts but does immediately
  37. A/C blower motor
  38. Spoiler Motor Fuse #20 Blowing
  39. Dash background lights blinking and failing
  40. Need Advice on IC Pump Problem
  41. If it does start...
  42. car won't start and key will not come out of switch
  43. 2005 Crossfire starts and immediately dies
  44. Dash code that is not a "P" code... what is it?
  45. Removing the accelerator pedal
  46. top goes up...wont go down
  47. Right Rear Wheel Stopping Car
  48. SRT6 Rear Alignment Specs??
  49. P2004 dtc
  50. Smoke coming from the a/c vents
  51. Brake Lamps On/Electrical Problem
  52. Car don't start
  53. Inexpensive Hood support replacement
  54. Ok I'm lost!!!
  55. Frustrated! Car won't start!!
  56. Bloody headlight bailing wire
  57. Car Stall & electrical issues
  58. AC blower motor fuze help?
  59. AC Help!!!! Please...
  60. Lost Power on Highway..Then took off again.. What Gives?
  61. My fog lights won’t turn off.
  62. BAS ESP/ ABS/ E Brake/ Brake wear indicator light all on
  63. Crossfire ignition key reinstatement after forum recommended sticky key fix
  64. Convertible top problem
  65. crossfire roof problem
  66. crossfire roof problem
  67. crossfire roof problem
  68. Is it ok to remove the alarm from the car?
  69. Can't find source of beeping.
  70. Need help with Central Locking.
  71. Changed SKREEM, key & ECU no start!
  72. Drive train vibration under strain
  73. Help me with oil leak
  74. AC Compressor Bad?
  75. AC Issues! Yeehaw
  76. Change wheel bearings too?
  77. CPS code looking for thoughts
  78. Help with ESP/BAS light and codes
  79. Help with codes
  80. Frustrated at ignition issue - Why not a recall?
  81. Can to identify this part
  82. 2005 SRT no check engine light runs rough
  83. Dead Battery
  84. Engine Won’t Crank
  85. Cranks, no start!! No spark!!!
  86. Delayed driver seat adjustment
  87. AC Evaporator Drains
  88. Power loss and IC pump
  89. My '04 chrysler crossfire keeps dying help
  90. Xfire Died in Traffic - BAS ESP - no crank
  91. Is something missing here?
  92. Bigger axle for the crossfire
  93. Ultimate STUPID question, I'm embarrassed to ask!
  94. Dash lights and shifting
  95. Pcm interchangeablety
  96. BSA ESP idiot light and soft brakes and pedal
  97. blue smoke
  98. cps
  99. Multiple Power Issues
  100. Pulse Module?
  101. spoiler up, no Speedometer, ABS, dash lights
  102. Skreem
  103. Parts list cross reference
  104. ESB BAS and NO Super Charger
  105. 2004 crossfire coupe
  106. Post Catalyst Fuel System too Lean Bank 2
  107. AC shuts off
  108. Convertible top inop
  109. RCM or CPS problem
  110. Battery disconnect
  111. Cruise control
  112. park/fog lights stay on when ign off
  113. odometer flashing -730 with a clock symbol
  114. Door sill removal
  115. Bulb Failure Indicator
  116. Just Curious
  117. Seat Belt Indicator Light
  118. skreem!!!
  119. What did I do?
  120. 2004 crossfire coupe
  121. Car turns over but won't start until after a few attempts, also having problems with
  122. To SKREEM or not to SKREEM? That is the question!
  123. Replacement Engine Oil Dipstick
  124. 56mm clutched pulley
  125. Random Alarm issue and light flashing FIX
  126. Loss of power, engine getting hot
  127. odometer weird image with "621" displayed
  128. adhesive for quarter window rubber seal
  129. will not run, help please
  130. High Idle - Running Crazy
  131. Battery light flash on/off upon acceleration
  132. Does Alarm Siren Also Control Flashing Lights?
  133. Rear spoiler won't go up all the way!
  134. Hissing sound from the front of the engine
  135. Stacked Pulleys
  136. No Start: Did my car just become intolerable to heat?
  137. 02 sensor
  138. Wire routing from engine bay to interior
  139. '05 roadster fuel pump
  140. Still no start
  141. 2006 crossfire - roof switch blinking rapidly, roof inoperable
  142. Pioneer AVH-3300NEX
  143. Fuse info
  144. Switched Power for VDO
  145. Engine stops randomly
  146. Battery disconnect
  147. speedometer trouble
  148. Rear Camber Clarity
  149. Dash Warning Lights
  150. Filter Suggestions
  151. Starting issues '04 coupe
  152. 2007 SE Roaster cranking Issue
  153. Knocking coming from front and back when Accelerating from cold
  154. 08 Crossfire Limited stalled at light
  155. traction control
  156. Crossfire
  157. Engine Stops Running 2007 Roadster
  158. Part # 2004 Crossfire Camshaft Sensor
  159. Wheel Bearing
  160. power problem?
  161. Sticky shifting
  162. Telescopic wheel lock stops car from starting?
  163. Battery help
  164. Strange things happening when shifting gears
  165. Pumping gas issue
  166. Leafs into A/C vent because missing screen on passenger side under hood
  167. Srt 6 '05 throttle lag
  168. Remote would not open door car would not start
  169. Pcm?
  170. Brake pedal??
  171. Starter makes noise; engine not cranking
  172. Help!
  173. oil
  174. Airbag light
  175. Door air bag swap
  176. Engine Treatment
  177. '05 crossfire battery
  178. Spoiler fault... any ideas appreciated!!!
  179. crossfire key replacement!
  180. Air, hot and cold
  181. Brake light work only when headlight are off
  182. Key Won't Unlock Door
  183. ecu tuning
  184. I need help and cant find it anywhere!!
  185. Speedo not working
  186. No Key -How to unlock Steering Wheel ?
  187. ANYONE KNOW??
  188. lots of indicator lights came on and spedometer quit
  189. how do you completely disable traction control?
  190. 05 Crossfire
  191. Noise coming from front suspension
  192. Oil change with oil extractor
  193. SKREEM module life span
  194. 2004 crossfire NOT cranking - help please
  195. Conv top acts up
  196. Central locking not working collective effort?
  197. engine swap
  198. 05' Crossfire Won't Crank
  199. Bow cylinder removal
  200. Supercharger issues on highway
  201. Alarm system
  202. install a aftermarket radio problem
  203. P0300 Random misfire - HELP!!
  204. proper roof problem, need serious help
  205. Trouble starting my '04 limited coupe
  206. Rcm relays
  207. 2003 SLK wheels
  208. Is this Mystery No Start?
  209. No heat and it’s COLD outside
  210. Now I need some advice / help! AC system / heater control valve assembly
  211. Ignition coil, wires, boot and plugs
  212. Alarm!!!
  213. '05 crossfire oil gauge
  214. Numbers stamped inside gas cap?
  215. '05 crossfire
  216. Check engine code P0410
  217. Multiple cylinder misfires
  218. Coil packs wires
  219. Surging Idle
  220. Convertible Top Reset Procedure
  221. Help Needed, How Can I Get New Keys Coded
  222. Seats and cruise control
  223. Crossfire will not start!
  224. Traction control switch not working
  225. Battery discharging?
  226. Aerofoil engages on engine startup
  227. Swing/Ding noise from rear hatch area w/acceleration
  228. Stud replacement suggestions
  229. lock/unlock works after 30 minutes
  230. No start/anti theft issue
  231. P0720 code
  232. BMW power seats in Crossfire Coupe
  233. srt won't start
  234. Spoiler deploys when car is started
  235. MAF (Mass Airflow Sensor) Symptoms - High Idle?
  236. What is this?
  237. Manual trans CLK 430
  238. MAF sensor
  239. 2006 Remove the front seat
  240. Roadster trunk stuck closed.
  241. 2004 spoiler won't stay down.
  242. Should I be SKREEMING?
  243. Power Door Locks & Trunk Lid
  244. Power Door Locks & Trunk Lock Not Working
  245. Hard Starting and Spoiler Deploys
  246. 3 tries to start, then no cranking - SKREEM issue??
  247. Nasty noise?
  248. Demisting...
  249. Half of the dash warning lights suddenly put along with the speedometer
  250. Trouble with Lower 2 Zunsport Grilles
