- RCM Question again..
- what's this button used for?
- It's cooler in here...
- Will this Supercharger work?
- Computer tunes...
- Honey DO list ...
- Installing Paddle shift?
- Replacing the entire Chrysler wing on the leading edge of the hood?
- Dies on the freeway
- Let the hood mods begin...
- Is this the BCM?
- HELP My car only starts intermittently
- Vortex Mod?? Do these work... even a bit?
- Anyone with electrical knowledge?
- Hella horns
- Miller Tool Kit
- Gave up on my Crossfire
- Gold rotex pads and slotted rotor question?
- Turbo Kits... How Much Is To Much?
- Stupid Question, But I Really Dont Know
- problems starting
- Storing/Type of Gas ??
- Warning: LET "new" WP Pulley
- Mystery Wire!
- online parts breakdown?
- anybody ever have a temp sensor go bad?
- Roof Trim Problem
- Click/Thump Noise
- ODO and NAV System
- Current Odometer Lower Then Last
- Mercedes Air Box W/CAI
- cutting stock lmtd springs
- 2004's, Have you changed your battery?
- Pin Stripe
- Tire Pressure Monitior System
- update wheel spacers
- how to install boost gauge in manifold
- Kumho releases the first 15-series sidewall tires
- Broken keys - Need help!
- New Grill
- Let Tune In Se Florida
- Aftermarket Replacement for OEM Steering Wheel
- Help!
- alternator replacement
- Accessory Plug
- Popping Fog Light Caps
- Dyno mode on SRT6/SLK32 ?
- Ecu
- TPMS Question
- Custom Hood - Or Not
- Non-retracting spoiler
- Manual shifter knob removal
- Trunk gate not locking
- SERIOUS question
- TVT 250 question
- 2004 XFIRE Service manual
- Oil Cooler for the N/A
- Whistling noise, when gas pedal held constant
- Just rock gut - No Premium
- Dead xfire
- Bad Battery? Car Cranks Fine, But Stalls Under Throttle
- Downshifting vs Automatic
- stripped star bolt - code3 pulley, help!
- Wing Problem
- Code3 intake question
- Help! Why won't my key work?
- Automatic nitrous bottle opener feed back!
- DIY, if you dare, Nitrous Install
- New Key
- stuck in 2nd gear, limp mode, need help asap
- To anyone who purchased a lightweight CRANK PULLEY
- Manual Gearbox Conversion
- Engine turns off
- Gutted Intake Elbow!!
- Stability/traction control
- change the fluid in a 6 spd manual?
- Quick Sprint Booster Question
- CAIs
- Need Suggestions!
- Fiberglass "Scooped" Crossfire Hood !
- and ANOTHER P0410
- TVT Intake Mod
- Car not shifting past 5,500 rpms!
- Are these brake rotors on eBay as good as stock
- What have you done to your car?
- -22 to -33 degrees timing on crossfire
- Lambo Doors
- Brand New Battery Completely Dead after 2.5 Weeks of Not Driving
- Underhood filters and temp measurements
- service counter indicator
- Oil Pressure Gauge
- Power "Surging" Under Mild Acceleration
- dashhawk 2??
- Shifter sticking
- Yet another P0410...
- Anyone had wheel bearings replaced?
- Tow Dolly
- FYI Oil Change Intervals
- Race Fuel
- whats up with these chips?
- Ethanol anyone?
- Dimming Mirror Question
- Dual external wastegates instead of cutouts?
- Oil change/pumping out oil
- Car Unlocking itself/Setting off the alarm?
- DONE! Traction Control & ESP Completley off!!
- Weird noise!
- ESP and TC
- what is TVT 250 kit?
- remove trunk interior panels on coupe
- Limited Throttle
- Chilled My Ride for $4.95
- What Happened To My Top?
- Idles rough
- What can you do with the Chrysler DRB III Crossfire card & multiplexer cable ?
- "Wall" behind seats in Coupe, (4) 18"tires
- N/A Phenolic Spacers
- Going with NOS...
- Cold Air Intakes?
- ZF transmissions?
- any code3 s/c pulley+upgraded pullies and headers updates
- frozen ignition switch
- Break in period
- SRT 400HP Upgrade ?
- Splash Shield Delete
- Alarm/Trunk Malfunction
- Getting better cooling
- 'Frozen' radio display
- Check Engine Light
- NA to SRT6 Supercharger Kit
- Big day tomorrow...
- Performance tweeks
- Performance mod
- Water to gas...
- Air con smell
- M6 reverse gear...
- SRT Wheel question?
- Bought car used; lock/unlock buttons on key fob do not work.
- 2005 Auto stock in Limp mode, won't shift
- Custom ECU Tuning SALE!!!
- Starting Problems PLEASE HELP
- Odometer rolled back.
- M113 & M112 AMG SRT6 Engine assembly movie
- M112 Tech videos from MBZ
- Driving Light Diffuser
- New Owner, "Overboosted Steering"
- sprint booster put to the test
- Grill Mod
- Check This Post
- what are my grille options
- New Member questions...
- Air Bag warning Light - comes on when seat is moved
- Key stuck in the ignition
- rear gate 'crossfire' emblems
- Doors
- Phantom Grip Install
- Turbo Crossfire
- Trouble: FSS Reset
- Grounded The Car
- P0551 power stereing sensor
- Cheap OBD 2 Code Reader
- Inflation sensor(s)
- Help
- Hyper Ground/Hyper Voltage System
- Out of Gear???
- Rebuilding wrecked crossfire, need oil pan...cheaper lol
- Coolant light
- hi guys need some advice...
- indicator in dash
- Clank and rattle in transmission
- Leather Recaro 8-way Power Seats Install and Question
- Basket Ball in trunk sound
- Can't get my key to turnover
- Finally a solution to our shifting woes...
- Chrysler Crossfire Limo - Wouldn't That Be A Sight
- 3,000 oil change... the "TRUTH"
- Won't shift out of drive or neutral...Help...
- Interesting Oil Filter Study...
- Making a fiberglass subwoofer enclosure.
- Crossfire Performance Packages
- Magnetic Oil Change Plug
- Swap MB 5-spd AT for 7-spd AT
- Injectors vs. ECU tune
- The official eaton supercharger thread.
- Scientific Instrumentation
- Bearings??? HELP NEEDED
- wheel spacers???
- TVT injectors
- I"m superchargin'
- Overheating question
- Differential / U Joints
- Horn Installation Question
- TVT intake not a sure thing
- new clutch
- Radio Shack chirp vs OEM siren chirp
- Stuck ignition key
- Running Lean?
- AEM Stand alone fuel management
- Battery dead
- AC dead
- smelling clutch :(
- Improving Gas Mileage
- electrical problems???
- brakes & rotors
- Crank Position Sensor (CPS) connector
- will i run lean with an ecu tune?
- serpentine belt routing
- Alarm??
- Flashing low fuel light and check engine light
- Check engine light came on.
- Tvt Ecu
- TVT ECU Tune and Routine Service
- Question about oem ic pump
- Sprint Booster
- Auto trans - Does xfire start in Second gear?
- Ignition Switch's Acc Terminal
- NO Turn Signals... Mechanics Stumped.
- Vibration between 70-80 mph
- Calculating supercharger speed
- Gear Shift Knob (Will this fit Autostick?)
- just think out loud about boosting n/a xfire
- dyno'd na w/ needswings cai and magnaflow catback
- Keyless Go!!!
- P0410 - Secondary Air Injection Problem
- this belong somewhere?
- Single or double filter intake?
- Anyone ever seen this JSP front bumper?
- Startech/CTD front bumper
- Alarm goes on for no reason
- Throttle Reset Logic ?
- to do list on needswings intake?
- Hi-Tech Crossfire
- Vortec
- Awesome Help!!! Let & Cpt!!!
- Won't Shift out of First...
- headers and more!!!
- will this help or hurt performance?
- Steering box
- NA performance list
- Homelink
- Can't dyno the 6 properly
- "High Oil" light
- 0W30 vs 0W40
- just purchased upgrades
- Multivex mirror finally arrived
- Where to buy harness pigtails, injector connectors, etc?
- SLK 230 body kit
- Sparg Plug Question
- Body and etc
- Experimenting with Toluene
