- NEED NEW Lock Barrel Cylinder - Will this work?
- Poor gas mileage with new fuel filter.
- Unanswered question for the Pizzaman
- rpm limit increase problem
- Need urgent help
- Stock SRT-6 Wheels with Wheel Spacers?
- Hood Latch Problem
- Bad vibration after flex disc swap.
- 2005 SRT6 Electrical Problems - please help :)
- Aftermarket alarm constantly going off - Looking for bonnet sensors
- Rear diff questions...
- Confused, manual trans and diff oil...
- Crossfires with no or small problems & how 2 fix it.
- performance chips
- MIL Codes after washing car?
- Coolant quiz
- Electronic Oil Pressure Gauges
- interchangable
- 100k miles. What else needs done?
- K&N filters?
- BCM issues how common?
- p0335 p0456 p0341
- Replacing engine coolant using a GREEN method
- installing pressure regulator valve
- 2004 Crossfire Vibration
- Question about lifting my car.
- Can spoiler be disabled easily
- Changing odometer
- Replacing starter
- engine light comes on! solved it for a while?
- Problem after replacing battery.
- Question about eurocharged...
- speaking of air-conditioning
- Could this be something other than CPS or RCM?
- P0100 and Erratic Idle
- Vacuum line under the battery holder
- start problem
- MB Star DAS Crossfire compatibility problem
- Oil filter adapter
- First Dashdaq Log
- AftermarketSpeedometer
- Reset Needed??? for working with the ignition module?
- DashDaq w/ZT-2 Install Help!
- Back to stock heat exchanger
- $69 chip?!!! 60Hp & 7 Mpg?!!!
- Ecu
- '04 Crossfire window noise
- engine cover...
- Help with changing filters
- Stock SLK32 AMG Dyno HP/TQ - Results/Graph
- line lock for burn out and launching
- Engine Mount (Polyurethane Fill)
- slk grille
- Battery ran down
- This car gives me a headache and I don't even own it.
- Where does HVAC vacuum come from?
- Did the $3.35 Mirror CCTV/Radar Detector Mount Mod!
- Problems with interior fan
- Dashdaq user input ground wiring? Need urgent help
- Has my car been been Eurocharged tuned?
- Live Data Concern
- Unusual Movement while accerlating
- Driver side motor mount help
- Auto Trans Fluid...Filter Necessary?
- AC blows hot? Weird idle/lope at start? Fixed mine!
- Require help regarding dash warning light.
- Needswings Cai
- Power Seat and Heat
- Transmission control module not communicating
- Strange A/C Problem With Cooling Fan Running High
- XF stalled 3 times yesterday... ideas?
- Transmission Cooler Return Line
- WATER IN CAR ( UNDER passenger seat )
- Is this normal clutch noise?
- Diagnosing engine noise
- Switch Recolor
- What exactly sets the alarm off on these puppys?
- manual sprint booster work on automatic
- HELP ! Where can you buy a 74mm throttle body at ?
- SLK32 Gauges
- Keyless Entry ... Lights Flashing
- Where is this rubber hose supposed to route?
- TB first or tune first
- just cut off
- Need warranty work done anyone
- Key Won't Turn Please help...
- Spoiler motor...
- 2004 Coupe Spoiler
- Locking door while key is in ignition
- 113k, no cel...but a hunch (please read/help)
- engine analyzer
- How Interchangeable are Sprint Boosters on the SRT-6?
- fault codes
- Windscreen Wash Tank Leaking
- Dexron III in auto transmission?
- Battery going dead
- 1st gear/clutch 'skipping' on humid days
- Burnt out ECU :/
- flywheel
- Warning light staying on
- fan controller
- Gear Not Shifting. Help!
- 722.6 transmission info
- Engine remapping in roadster?
- lowering my crossfire
- LPG Conversion
- day time running lights
- Gremlins again!!
- Random issues "I think" are all related
- Mystery No Start - Fuel Pump Relay Module - Solder!
- Hydro Dipping
- Computer Trouble
- Transmission Control Module
- Differential help
- Dash Pod from Junk
- Custom Grille from Junk
- Is there any way to change...
- Driver side window problem
- Sprint Booster or Eurocharged Tune?
- window issue
- Steering feels loose
- Supercharger Electric Clutch Removal?
- SRT-6 TPS Issue
- Starting Issue
- How to Jack Up Front, Jack Pad Missing
- 451 page Crossfire parts list... couldn't add to sticky by Valkryderguy
- Lots of trouble going into Reverse, need some help
- Xfire Coolant light on! Need help plzzz
- Key won't remove when in PARK ... suggestions?
- Windscreen Wipers
- HELP: Car not starting. Not RCM or Crank Shaft Position sensor
- Do we have a PDF of this booklet?
- 74mm Throttle Body, surging idle
- N00B in Houston - N/A Tune questions
- Total Shut Down?
- Wasted morning PSK
- Various Parts Lists
- Jacking Car Up
- Help needed - Dyno Run
- Passenger Airbag on an '06 Crossfire Coupe
- Sluggish when cold.
- Eng. cut off
- Faulty TCM ?
- Possible upgrades?
- waterpump
- need help with windows
- idler pulley fix.
- Make your own cargo cover?
- Battery Indicator/Construction Zone Interference?
- Newbie fuel economy improvement ideas
- SLK (White) instrument cluster
- Auto Tranny Effective Life?
- Electronic Parts Catalog (EPC)
- check your flex disks!!
- Thinking of making License Plate Lens Replacements
- UK Link
- servicing
- Timing belt / Chain
- OBDii Software
- Does anyone know if this would work???
- Catch Can Install - Question
- Changing wheel size
- OBDII Code Readers
- I need help big time with the car, please read on.
- What mods would you recommend for a budget of $5k?
- DRB III or StarSCAN - or both?
- Mod questions
- Relay issue
- wheel bearing
- Intermittent Complete 12V Power Loss / Ideas ?
- Auto Shift Gear Indicator
- New Key - Need Some Help
- Cam & crank sensors
- DIY Adjustable Rear Camber Arms
- update on stalling Code P0562
- Unplugging Ultragauge
- Mystery Issue... Generator/Alternator?
- Fried Sprint Booster
- Anti Corosion module
- No lights on this one
- bas esp/ abs light
- Cruise control malfunctioning...
- 35 shot of nitrous
- gas tank...waiting 3 months
- Extra H/E, Data Log and weather
- water & IAT's temperature # 2
- Need help. Can you measure or take a pic of this part?
- engine runs rough, loses power
- Tie rod end
- Coolant Leak :( could use some help
- water and IAT temps.
- Rear Wing extends on startup
- $$ saving replacement parts
- Spark plug replacement tools needed
- Mechanic In Dallas, Tx
- Tach signal for Zex Window Switch
- From OEM to AMG, back to OEM... Still no fuel
- hardtop to covertible srt6
- cruise control not working
- rattle?
- Looking to do racing seats.
- '04 Stock Coupe Tune
- air bag light
- cluster/console color change for hire
- auto trans
- I need some help
- Engine Oil Change
- Bosch CPS Cheap price
- Engine's heat problem
- Got used 74mm TB on Ebay/ Needs Cleaning
- OE Discounts Parts - XFire Offering
- Auto not changing
- TVT Designs out of business???
- Mercedes Guy Here, Need some Transmission Advice :)
- different year transmissions compatible?
- need advice please
- Purolator/Mann fopaux
- Auto Headlights, Fogs On With Highbeams & Other Quirks Fixed!
- WoW... this sh** is LOUD!!!
- wiper issues
- Brake upgrade
- P0410 (secondary air injection system)
- ok still a mystery
- car won't start
- Steering wheel airbag question.
- window washer fluid sensor on when full
- K & N Cotton Air Filters - Best Replacement NA ?
- Is someone rattling a paint can?
- Intake Manifold out ... Got a couple of questions
- Another N/A nitrous thread
- Help Please!!
- Replaced CPS. Idles fine, but dies immediately under load. Have scan stats.
- O2 sensor problems - ready to tear out whats left of my hair!
- Idler Pulley for SRT6?
- interior hood latch askew
- Left Lights on
- A little rough sounding at idle
- I Kin D r i f t Now
- Auto Shifter moving when torque is applied (SRT6)
- Missing?
- Anyway to beef up stock air intake?
- Battery light still coming on after replacing it.
- replaced battery
- Power Steering Fluid
- Cruise control failure
- Hood strut (rod)
- Spoiler up and so is top
- Turbo SLK320 on Ebay
- Won't Start
