PDA
View Full Version : Troubleshooting & Technical Questions & Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23
  1. Will THIS type air intake fit?
  2. Rebuilding Project
  3. Cheap Sprint Boosters
  4. F2/ enginge control fuse on relay module blown
  5. Performance Chip
  6. Cargo Cover dimensions required
  7. Door Lock Faqs
  8. Brake light issue
  9. bosh intercooler pump
  10. Body control module fuse blows
  11. FSS Question
  12. No Start. RCM IS NOT MY PROBLEM
  13. OBD II MPG Reader
  14. Aftermarket Parts
  15. No start and/or fuel issues...
  16. VIN question
  17. I need help please!!1
  18. Misfire and all around crappy performance
  19. Transmission Question
  20. A small, subtle mod
  21. cabin filter
  22. Mercedes Factory Approved Service Products
  23. Should I buy a Battery?
  24. Speed/RPM Calculator
  25. speed sense wire location needed
  26. Coolant question
  27. supercharger cuts out
  28. Doggy
  29. Spoiled spoiler?
  30. Headlamp Freaking Switch!
  31. Replacement Steering Dampener Failure
  32. Internal window weather stripping?
  33. Massive Oil Leak!
  34. Crank position sensor
  35. Trunk Lock
  36. Failing oil level sensor. Need valid part #
  37. Abnormally low gas mileage
  38. Oil changes
  39. Fan Always On - Over Heating (new Member)
  40. Oil change capacity
  41. Crossfire/Mercedes joint problems and solutions
  42. G-Box G-Box Gold Series Performance Module???? Anyone know if this is any good?
  43. Chrysler Max Warranty Items
  44. Wont automatically start?
  45. Electrical smoke and smell
  46. Potential Future Aftermarket Products for Crossfires
  47. Least Expensive way to Monitor A/F - Wideband 02
  48. rad cooling fan
  49. AC compressor sticking?
  50. What exactly can you do with the stock ecu?
  51. Battery dies
  52. ECU tune question
  53. -10* Fan Mod
  54. Differential Oil Change!
  55. HELP!!! Went to do an oil change...
  56. Modification for providing variable wiper speeds?
  57. What Wrench
  58. radiator fan / control module
  59. Just saw limited Turbo!!
  60. Speedometer not working/way off
  61. First Oil Change
  62. Under spoiler decals
  63. Sprint Booster?
  64. Tvt Cai
  65. Blinglights Intake
  66. What is this Vacuum line for ?
  67. Air Pump bypass resistor
  68. ecu programmer
  69. Outrageous
  70. Does anyone have open access to autocheck?
  71. Actron CP9145 AutoScanner on sale at Amazon
  72. Idle RPM
  73. Tyre size question
  74. Gauges...help
  75. 2004 crossfire will not died once would not start twice
  76. Where is this beep coming from!?
  77. Alarm is about to P... me off.
  78. Selling Sprint Booster
  79. Transmissions Explained
  80. Windows seals coupe
  81. New Owner, a couple of baffling things
  82. Grrrrrr!
  83. need help with A/C problem.. compressor not engaging
  84. Short shifter/shifter slop
  85. '07 interior in an '04 issue. Need help
  86. short ram cai on na model
  87. Alarm Issues
  88. Battery Relocation
  89. HELP!!! Mystery no start with a twist
  90. need a carfax report
  91. Anyone have problem with Costco gas?
  92. Just got thrown a curve ball. What to do?
  93. parts
  94. Need Help with new crossfire!!!
  95. Automatic Ignition Starter??
  96. I still need a stock clutch and flywheel
  97. Oil Level Sensor Location and Testing
  98. how much does your car weigh?
  99. Dallas Area - Lambo Doors
  100. Floppy cruise control stalk
  101. Stacked Fuel Pumps
  102. Obdii & Eobd Reader Help
  103. Won't Start
  104. Spark Plugs After Modifications
  105. my friend at Diablo sport
  106. Laptop connection
  107. Tools for Crossfire
  108. Windshield wipers no longer function
  109. Looking for the next easy mod
  110. Needed: Mercedes Info
  111. Xfire sometimes won't start
  112. Door 2 position limiter clicks now when I open driver door
  113. Ignition wiring?
  114. K&N Xstream Filter Upgrade
  115. Hose left of coolant tank throbbing?
  116. Help: Mod idea
  117. What Type Battery do we Have?
  118. Turbo kit mockup update
  119. Button under accelerator? Stock or Moded?
  120. Crossfire no start pulse module?
  121. Eibach springs and rear sitting too low
  122. Check oil light on after changing oil and filter
  123. NAPA Sale
  124. Where is the brake light relay??
  125. 6 speed tough to get in gear
  126. ecu tuning
  127. N20
  128. High Idle After TB Edging
  129. True Fender Vents
  130. brake sensor replacement?
  131. Will I ever get my car put back together???
  132. Roof Strips
  133. Kinetik High Current Batteries
  134. Bosch Oil Filter
  135. Clearing DTC's with OBDII
  136. Running Mobil-1 10w30?
  137. Chip tuning
  138. Step by Step V8 conversion
  139. Fuel Filler Flap Problem
  140. no throttle response
  141. Valve Cover Bolts
  142. Jacking Points
  143. drag racers tire info
  144. Question on diagnostics
  145. central locking pump /security pump module
  146. Spoiler Operation
  147. performance chip
  148. Mobil 1 0W 40 BREAKDOWN?
  149. Rear Axle Fluid Maintenance
  150. Need a Roll Bar
  151. Brain Flying Tomorrow
  152. When To Service
  153. Engine Dies When Temperature Around Freezing
  154. part number or name..rubber gasket
  155. Can you put a supercharger on a crossfire?
  156. Code P0128..Anyone else?
  157. Cold Weather Engine Behavior
  158. Bumper Question!!
  159. MB SLK parts list
  160. L/F tire rubbing
  161. parts list pdf I found
  162. next gauge to install?
  163. Correct dynomode?
  164. Transmission Problem
  165. MAF upgrade
  166. fuel pump, Is it the one we want??
  167. SRT-6/C 32 AMG article
  168. Dealer Programming Crossfire
  169. warning...warning...will robinson...
  170. Billet Grille Fitment
  171. Cracked air pump?
  172. Engine and Transmission weight?
  173. Engine Studders After Adding Gumout
  174. ECU Reset
  175. Door Handle Installation
  176. Firmer Shifts for your Autostick ?
  177. ABS PUMP Keeps on running!
  178. Need to know, if and what you know
  179. oil temp sending unit help
  180. Panel warning lites & spoiler up
  181. Cool Queue cooling fan and IC pump controller
  182. Power Steering Fluid Leak?
  183. V8 Turbo Diary
  184. Throttle Body Modification
  185. housing under the MAF
  186. Just got P0720 and P0600
  187. Sensor in grill
  188. Rcm Refund!
  189. rhythmic vibration
  190. Thumping Noise?
  191. What is this and where does it go ???
  192. ECU tuning
  193. Inexpensive Performance Mods...
  194. Scangauge II
  195. Universal security guard tags
  196. Drivetrain loss? Dynolicious
  197. ScanGauge II on a 2004 NA
  198. stock airbox>C320 Airbox>C350 AIRBOX!!!
  199. Courtesy light wire connection HELP!
  200. Anyone with an FSM
  201. Brakepads Non Srt
  202. Eliminating the 4,000RPM cut
  203. ESP disable the right way
  204. HELP! Water in trunk
  205. Parking aid
  206. Dyno-Tuning Tomorrow!
  207. Manual Transmission Fluid: No service is required???
  208. Can the manual transmission handle 400+ hp?
  209. Tuning Questions
  210. Recall on RCM
  211. convert Fahrenheit to Centigrades / miles to km/h on dahsboard
  212. Oil brand
  213. Mystery car no start and radio??
  214. Xenon Lights
  215. Experienced Xf Advice
  216. hesitation, dying...
  217. Zex Nitrous install, with detailed step by step pics
  218. Headlight delay shut off time HELP!
  219. radiator fluid
  220. Atlantis custom software
  221. P0161 Code
  222. My car shuts off while Im driving and
  223. Memory Trac and ESP Module
  224. Gear shifter moves while accelerating
  225. Recommended Motor Oil Additive: BG MOA
  226. Filled with Pentosin CHF11S
  227. Oil Leaking From Right Front Top of Engine
  228. Where to buy coolant?
  229. popping out of first gear
  230. Leaking Oil Cap.
  231. Weight reduction
  232. Headlight Assembly!
  233. HP Cam shaft specs found
  234. AC evaporator drain
  235. NA Crossfire Modding: In depth
  236. Oil Change Question or Advice
  237. check out this engine!
  238. DynoStorm / Dynolicious
  239. My car running too lean?
  240. Fog Lights
  241. Changing Camshafts
  242. n/a fuel pressure
  243. Full dyno run on 04 Xfire FIXED!!!, kind of
  244. Two-spanner service items question
  245. Cruise Control Problem ?
  246. Little Sweet nothings for the car
  247. Help?! Convertible Button Fell... how to get???
  248. Need a new Cranshaft Position Sensor!!
  249. Key Fob Does Not Work
  250. Transmission question
