- diagnostic system reset?
- Needswings (Rob) and rcompart (Rudy) did it !!!
- LUG NUT question please?
- turns over but trouble starting
- Steering Lock Cylinder Question
- newbie with crossfire problem
- Minor Questions
- Should I, or should I not mess with this? ...
- Convertible top removal
- Anyone running an FIC8?
- Where To Find Parts?
- GF chip does it really add 60HP
- Coming soon, wavetrac torture test
- A/C troubles
- Deleted Cup Holder
- Electronic Parts Catalog
- Mercedes Part Numbering System
- Washer Fluid Jets Not Working
- Fuel Filter
- Lower Grill Inserts
- newby
- damn hood stuck
- Copper Brass or Bronze?
- Why do Bosch Auxiliary Pumps Fail? Pics Inside!
- Throttle body?
- Hot air blowing when heat/fan turned off?
- setting up custom ignition code to start car
- your hardest and best mod?
- replaced BCM
- WTB: N/A spoiler motor
- Spoiler flashing: For highly electronic trained only!
- Crossfire Parts Suppliers
- Is this a Cold or Hot Air Intake?
- Anyone has pictures of a Crossfire with Eibach Pro
- Check Engine Light Reset Now Off BUT
- connectors to BCM
- Upgraded heat exchanger questions
- CRACKED a/c condensor
- LOSING COOLANT IN SRT6 (any ideas)
- How to remove the gray trim around the windshield
- EBay dual intake?
- low engine idle
- Brand new front lip for the xfire...
- Starting issues
- anybody want a dashdaq?
- removing rear emblems
- Alarm Issue - Opinion
- Which fuse is the fuel pump fuse?
- 5 point harness
- Caliper paint?
- modding lists?
- airflow
- Knock sensor question
- check your throttle pedal
- Lower Ball Joint: 57K miles
- Engine code P0171 - Mass air flow sensor problems?
- Driver Seat Won't Heat Up...why???
- I think mice are giving me a headache
- 100k miles on 2006 convertible, a bad idea?
- car unlocking problems
- spoiler problems
- Diffusers
- Starting Issue
- GForce Performance Chip for Crossfire
- Fob programming for door unlocking
- key in ing chime and door lock questions
- Auto Torque Lock up
- I just tested the resistor for the IAT
- torque requirements for intake manifolds
- paint wear on door threshold
- ScanGuage II and Eurocharged Tune
- Sticky Key - Key Won't Turn! Help?
- Eurocharged cable with ScanXL software?
- I found the answers
- New mods something Isnt right need help
- New 2004 Owner Handling Issues
- Who's using Blue Tops?
- White top battery
- check engine codes 412, 403 & 410
- has anyone replaced a water pump?
- Damm old N boney, need a place to rest - console
- Outer Tie Rod End
- Engine monitoring options?
- Help again
- change fahrenheit to celsius / miles to km
- Check this out! Dynotest with iPhone
- C3 pulley inquiry requested by vendor: "If new pulleys were made I would..."
- Will this engine cover work???
- Radar Detector; Price An Issue
- GF Performance Chip
- Battery Dead. Should I expect any issues after replacing it?
- HELP! Key Fobs not working - Car Stuck!
- Any way to retard timing?
- Radar Detectors: Escort Qi45... anybody???
- Check engine light
- Get the codes p0500 and p0720
- Paddle Shift Conversion Kit For Auto Trans
- Power wing/spoiler has a mind of its own?
- coolest engine cover yet!
- Debadge and tinted sidemarker tutorials, pics!
- Looking for a tune...
- Spoiler motor, What has happened here?
- Saw this...
- Help my crossfire died this morning
- HVAC Blower Speed.
- drivers side door lock fell out
- '04 '05' 06 & '07 Crossfire Part numbers in .PDF files
- part number for spark plug wire
- Goodridge Brake lines
- another problem :/
- supercharger problems??? help!!!
- TPS wire color for nitrous wot switch help!
- More Xfire Newbie Questions re: ride, comfort, etc.
- Auto trans shifting issues '04 NA
- Starting and Instruments Issues
- How much to expect?
- Fluid for Limited Automatic Transmission
- bmw vs crossfire
- Car Service / 40,000 Miles
- Part number cross reference...
- Side Mirror Mod
- Good Battery but won't turnover
- Sprint Booster Question
- Removing the Alarm
- Car won't come out of park when cold
- coil overs
- Sprint Booster on the V8... Wow!
- Shell Rotella T6 Full Synthetic
- Car hesitates at start
- Crossfire Protection Coveragenot thru Chrysler
- Oil warning light flashing periodically
- Online resource for MD Fluids specifications
- Maintenance Codes
- Replacement Key
- Rattle? Help!
- Can't remove trunk liner-roadster
- Oil level sensor revisited
- Rear suspension aligment
- Powerpedal = Sprint Booster?
- cigar lighter
- HVAC compartment and cabin filter
- reghten locking bolts for steering, torque?
- Fuel Filter clamps
- Pulley and chip questions
- C240 airbox intake tube
- Rain-X Latitude
- Pizza is Disturbed !
- new engine cover project
- How can you lower wind resistance?
- Question about Fan control (Blower)
- Rigidity increase
- location of evap service port
- My car only starts when it wants help!!!
- I really need the straight answer!!
- Is the S430 2000 air box / engine cover are a upgrade?
- Transmission oil leak
- Crankshaft Sensor - Up Close and Personal
- Spoiler problem..?
- throttle/gas pedal issues
- Where should I put my Air Fuel sensor?
- New CAI, How does this one look?
- "mystery no start" AGAIN
- Daimler Chrysler DRB III Crossfire Software Card
- Battery Bug by Argus
- Convertible roof window 2005
- Refill Radiator/Coolant
- What should I do?
- TVTDesign Closed for Business???
- 722.6 info consolidation thread
- Transmission Leak - Input Requested From Members on Post Fix Experiences
- No Sound from Speakers after Reversed JumpStart
- KEY Question
- Filter O-ring failure leading to Serp belt failure
- Active alarm without locking doors?
- sound deadening
- More carbon fiber added to the outside
- Car lost power then died...
- A quick sprint booster question
- Pulley Noise I Think? Help Me Please...
- strange problem
- oil catch can with off the shelf parts
- Roadster
- Killer Chiller
- Rear Bushes
- Steering Wheel
- P2098 Code?
- Turn Signals on Side View Mirrors
- Auto Dimming Mirror - it's not just for '04s anymore!
- Alarm system tech question
- the "wing button" in the SRT
- Has anyone tried converting from Manumatic to Manual
- TVT Designs ECU Tune and TB
- Are my Fenders rolled or is this the way they come
- Chrysler Service Contract vs. Mods
- Stuck in Park, check engine
- Engine Noise on Switch off !!!
- H&R Sport Springs or Eibach
- VIN# won't get key that starts car
- Carbon fiber key fob
- Install a N/A BCM on a SRT
- Stick shift question
- 2008 Limited W/Fuse 17, 18 pulled
- How can I disable the TPMS? (Tire Pressure Monitoring System)
- Trying to make use of my rims
- Power-Steering fluid change, DIY with pics
- oil pump or oil pressure sensor change? any know how to?
- Weird vibration while cold
- If you have had NA mods for a while, worth it?
- Still doing stuff even if its not for the C
- want a louder exhaust
- DynoTuned Performance in Va Beach, VA - Anyone used them?
- Need Help with Electrical Gremlins
- Fuse # 10 spot speed control question
- original battery since 2004 is death near
- W5A580 / 722.6 Transmission Information
- Brake Light Switch
- Queston about tire monitor system
- May be battery time
- Tasteful mods
- '05 Repair manual
- Where to get a clutch?
- 2004 XF won't start
- Cabin Filter: Quality?
- Stronger Differential and axles available
- Sprint booster
- Camshaft position sensor: DIY replacement with pics
- That F%^**&*## Washer (Sprint Booster)
- Water leakage
- RPM flutter when idling
- Running Hot
- Fuel Fill Door wont close
- OEM Replacement parts?
- Headlamp Assembly Drainage Bung Question
- CPS Socket size
- Interesting Read About Phantom Grip LSD
- Chrysler Crossfire Specialist Student Reference Book
- P0600 & P0705 codes being thrown
- Found out how much downforce the wing puts out
- Shift kit available for our cars! AKA: Silver Box
- Best Way to Reach Wheel Well Access Panel?
- Garage button?
- Problems With Starting the SRT, Battery Related?
- Controller Anti-lock Brake
- Will a cat back void my Warranty?
- Overall Grill Dimensions???
- Car cranks but won't fire, but eventually will
- Air Conditioner Compressor
- Altenator Problems
- Purolator Part L25277
- TPMS dissection
