- Same issues as others NO START
- Not The RCM!
- Need Information on Speed Activated Spoiler
- Thieft Alarm activates without warning
- engine missfire
- The crossfire won't turn off
- IAT at 95C with new IC pump! How to test?
- $25.00 Paypal dollars to the first...
- HELP!!! Ticking noise in engine bay
- Help a girl out :)
- Outside Air Temperature Probe
- Getting The Alternator Out
- No interior or trunk lights
- SRT6 Fan Woes
- 2004 crossfire ticking noise
- Car battery isolator?
- Any way to stop the spoiler warning?
- OBD2 Code Reader
- Daveace in the UK
- Shorted transponder
- Noisy A/C
- supercharger not working
- 2006 Crossfire will not turn over
- Car won't start. Possible skreem
- A/C Won't Blow Cold
- Won't start and no keyfod control
- Pulley Saver Kit
- Center Support Bearing
- ECU Programming SRT vs Base
- The day after replacing alternator, car went into 'safe mode'
- Musshy brake pedal
- '07 Crossfire roadster
- Spoiler activation and interior light issue
- Tow away sensor
- My Roadster is haunted!!
- 74mm mod
- Bad Vibration in Reverse/Idle
- Weird noise / Spring pads
- My Alarm
- JUNKYARD BEAT ME! How to get BCM clip off?
- 2004 XF intermittent starting problems
- K40? Starting issues!?
- ESP/BAS Light code C1210
- Maf replacement and still runs cruddy
- Pulley, intake, tune, & supercooler problems HELP!
- No Crank Condition Plus Other Issues
- battery light
- UltraGauge Blue. Anyone heard of this?
- My BAS ESP light comes on while driving?
- Acceleration Stall
- Rear spoiler help.
- My brakes warning light on the dash came on yesterday?
- Get Code reader to Work
- Top wont go down
- Reflash
- Starting issues...RCM related?
- Another BAS/ESP Conundrum
- groaning noise when locking doors
- Skreem Module Fixed!
- N/A different fluids
- Crossfire Wont Sart
- No FM reception on factory receiver
- Roof issue returns
- Has anyone successfully read BAS/ESP codes
- #@##**&%%# RATS and Wires.
- Am I getting ripped off? (SKREEM)
- Won't Start Please Help!!! 2005 SRT6
- Drivers seat. heated seat
- re smoking valve cover gasket failure, again?
- help help help elec probs
- I have a no start problem
- New toy
- Skreem
- '05 won't Start. Suspecting Skreem?
- SRT 6 Air/Smog Pump
- Intermitten Cranking/Starting
- start button
- Ignition Coils
- Changing the Steering Wheel
- MAF cell code on N/A??
- Airbag Light on and do we have passenger weight sensors?
- Please Allow Me to Vent "turn over"
- Wing Control
- Dreaded parasitic battery drain
- Windshield washer nozzel
- Central locking
- Accident, fender, front suspension damage, Advice Wanted!
- '04 crossfire
- '05 Crossfire completely dead - 50 amp fuse keeps blowing
- Purchased an Autel diagnostic tool
- Crossfire roadster, strange ignition problem, please help.
- Electrical Issues? Gradual loss of power
- signal light trouble shooting!
- Tire pressure / BSA/ESP light
- Transmission fluid
- tomorrow will be a big day
- Convertible top not working
- storage
- Vacuum Brake Booster Line (SRT-6)
- Shuts down while driving, won't crank
- 2004 crossfire
- New intercooler pump!!
- Craigslist scammed:( Need your help my fellow xfers.
- ID the oil leak?
- Flooding
- 2005 Crossfire won't start
- replacing seat relay
- Traction control isn't completly off
- Only third brake light working
- Dead CPU?
- Heater noise!
- Srt gear ratio
- Locked Out!
- Vehicle Security and SKREEM
- heated Seats
- 3.46 diff. for the crossfire
- Key Fob Inconsistant Function
- Needwings Map Sensor
- Spoiler has mind of its own!
- No blowing, air speed matches outside air.
- Won't start turnover
- Completely flustered
- Alt. Problems
- Air Bag Light Still on
- Thumping Sound every few seconds at idle
- Dead 2004 Crossfire
- Convertible top fluid fill up Instructions
- Problems with my MAP sensor circuit (Manifold Absolute Pressure)
- map sensor
- Help Nitrous install please :)
- right bank dead
- Possible Air pump problems.
- Crossfire won't start, help!
- Solved the Mystery No Start, now it's the Mystery headlights on, no break lights...
- Head Beam / Flash light don't work - both of them
- Alarm system deactivation???
- Fog Lights Flash when car is in park and doors are locked
- Battery discharge problem
- engine compartment
- Oil Light
- Water in trunk
- throttle surges in park
- Set off alarm, now no start
- Car stops accelerating at 5,100 rpm, 70-100 mph and freezes there when I floor it
- '05 Crossfire Won't Start
- multiple cylinder misfire with 110 octane
- Cleaning the headlight assembly? Help!
- NOBODY HAS AN ANSWER TO MY ISSUE. Help!
- Stalling
- '04 Crossfire Throttle Body
- Climate Control Fan Speed Fix
- 2005 coupe cranks but won't start.
- Water in trunk - add drain holes?
- Can old oil result in a higher idle speed
- Alarm Issues / Clicking In Bay
- Stock injector psi on limited
- For performance purposes
- Trunk won't open
- RCM Module relay needed
- cheap air pump
- Varta 3.6 150h Batteries for Siren Rebuilds, Free Shipping ends Today
- No Start - Need addition solutions
- ignition switch turns but no start
- All kinds of pulley problems
- hood scoop.
- Key Fob - Keeps Draining New Batteries Within 5 Days **Please Help**
- Battery Voltage
- Eurocharged
- Dyno but tc and esp kicks in
- Engine stops for no apparent reason while driving
- Transmission Shifting out of sync 5spd
- Short Shifter
- New problem
- Aggressive wheel rumble at 65+
- new ignition problem
- seats move don't move
- new problem I have not seen here.
- P0410 how i fixed
- Crossfire headlight lens mod
- No Start after 3 years storage
- 2004 Crossfire, computer tuner
- wing goes up when starting...
- Electrical Problem won't start sometimes??
- rear spoiler wont go down?
- PO410, RCM seems Good, Air Pump works when Jumped ????
- Central Locking Pump Question
- Fuse box diagram
- no start - appreciate any input
- Radiator Fan Issues
- 2004 crossfire stall issue
- Central locking pump module failure question
- Blower motor wont shut off
- Problem with belt, noise from Engine bay (videos)
- Windscreen misting
- Code PO335 problems
- Key Fob/Remote & Central Locking
- Heater fan problem. Please help.
- Pulling the steering wheel.
- BAS/ESP light and less power
- Radiator Cooling Fan Not Working
- Fuel pump question
- Intermittent beep/squeal from passenger side
- Double bad news in the same week, need help
- What is the unit under the headlight?
- Ignition Wiring
- BAS/ESP & "bulb Light" indicators on when pressing brake pedal
- How do I change the inner wheel bearing??
- CEL-evap leak
- computer delay time
- Bad Battery could cause to stall?
- Threw Serpentine Belt Tonite SRT6
- HELP, I'm stuck, alarm will not turn off, can't start car.
- my car wont start the first turn of the key help
- Engine stalls with in the first 30 minutes of start.
- First time modifications!
- No speedometer, No odometer, 6 indicator lights on and F1 fuse blown
- Engine shutdown
- Where does this part go ???
- Tweeter/handle door trim removal
- only revving to 4000 RPM SRT6
- Fuel Pump Permanently On
- Rookie Mistakes - Need Help
- Rear Bow Latch
- Now that you own a crossfire, a starters guide to ownership...
- Engine Oil Can indicator light comes on
- Mercedes-Benz Chassis Codes Explained
- 2004 crossfire won't start
- help how to remove console cover 2005 xfire roadster limited
- problem with fuel pump??? PLEASE READ!
- Loud, rapid clicking.
- Bas/esp
- Building Ford 9" set up
- Dashboard is DEAD, car starts and drives
- Car not running - Fix it or sell it?
- Trans model ? Conductor plate for a 04
- limp mode
- OBDII scanner recommendations
- Dash light!...?
- Help, Car at Dealership for 3 wks due to SRS module
- Hey everyone… I’m scared!
- ok maybe someone out there can help...
- truck won't lock? wtf
- '04 crossfire. P0715
- Random upshift and occasional down shift??
- Won't Start (FIXED)
- High decibel whine in cabin of Crossfire
- Keyless start button system - Ignition Cylinder/Lock tumbler
- studebaker57
- RCM relays???
