- Car locks with fob, hatch does not
- Strange brake lights, BAS/ESP light, ABS reader?
- Ayone knows what this is? (Under the truunk floor panel)
- SRT wont start/fire just out of the blue
- Intermittent starting/ runs rough
- Need help with intermittent starting
- ABS/ESP Light
- 2004 Crossfire anti theft problem
- replacing convertible top
- Replacing Skreem Module Worth It?
- Good latch
- Engine coolant specification
- Lights On! Even after the SKREEM Repair
- 1 Amp draw on fuse 35 draining battery
- Looking for auto electrician... Bulbs blowing and alarm sounding
- coolant level dropping
- Spoiler has no power and electric seats don’t work.. HELP 😭
- Clinking sound when turning
- Limp mode / misfire help
- Crossfire 04 ,automatic door locks
- Broken header latch 05 limited convertible
- Speedometer/Odometer and ABS, Cruise Control not working
- 2004 XF limited. Innacurate fuel gauge.
- Skreem module failure
- read oil dipstick
- read oil dipstick
- 2017 multi function lever repalcement?
- I'm the Forrest Gump of this site
- Explanation Needed
- Key help
- HELP!!! - Car won't start and I get a clicking noise when I turn the key.
- REST Fan won't stop
- Problems Chrysler Crossfire
- My Crossfire Nightmare!
- Usable Octane Fuel Grade
- Automatic transmission fluid change
- Has anyone tried the ArtiDiag800BT scan tool
- Back at the mechanic again keeps dying
- 2005 coupe
- Cable snapped what is it where does it go ?
- A saga continued @ 1500 RPM and @ certian temperature
- Slow draw draining the battery
- Shifter issue
- 2003 CROSSFIRE manual
- flashing lights and alarm going off drawing battery ?
- Wiper Malfunction - I'm Stumped
- Indicators not working
- 06 No start no crank
- Opinions on if I need a new Skreem
- is crossfire fuel cap a vented cap or not
- Spark plug recommendations
- Vogtland Lowering Spring installation DFW, TX
- fuel smell in cabin
- Caliper bracket bolts broke
- Hood will not shut all the way
- Crankshieft sensor wireing
- WHERE TO BUY the best fuel for occasional use or storage
- 2006 CF Dash lights.
- Alternators (Subtitle: I hate Valeo)
- Crossfire Coupe 2004 Spoiler randomly won't close
- Issues
- I search beta testers for the Skreemulator
- I found this part to be the cause of the erratic climate control fan speed
- Smoking Crossfire!
- Help with P0104 DTC
- Crossfire rough running, misfiring, wouldn't make it a block.
- Clockspring: Calling MB Gurus
- spoiler switch flashing red
- BILLET aluminum oil filter cap
- Coolant light after the crush
- Immobilizer (SKREEM) issue FIXED with resolder
- Does your xf makes noise when in low rpm/speed too?
- Code Readers
- Trailer Hitch
- P0300 easy fix
- Cigarette lighter power issues
- crossfire battery: my experience
- Battery Drain
- 07 Crossfire overheating!
- Battery Drain
- Duplicate keys now available.
- Alternator question
- Battery light and steering
- Electrical Gremlins. Need help!
- Bas/esp light
- P0600 and lots of dash lights
- My Chrysler crossfire srt6 won’t start
- C63 engine 4.0 TT - will it fit ?
- Errant left IC Dash Airbag light lit... Advice?
- Weeping rear main seal
- fuel pump ???
- 2007 Crossfire Coupe - No Start
- Alarm / anti-towing issue
- Head light aiming
- BAS ESP light stayes on.
- Intermittent Start Failure
- Is it a trasmission issue?
- skreem repair and diagnosing why screem failed
- No Start
- Sticky key fix now no ignition
- P0410 error fix
- Turn signal
- High Tech Mobile SKREEM Repair Service
- Convertible top not working
- Help! Wiring
- Spoiler not deploying completely?
- air pump check valve
- drbiii failure to communicate
- My crossfire won't run b/c of a bad chip! Can anyone help?
- 185mm pulley installed need help feels like rev limiter at 5500rpms
- Sudden voltage drop?
- Central locking pump
- What Part Is Missing?
- Virgin SKREEM EEPROM Files
- New Overhauls, New Accelaration Problem
- Low Coolant Light/When Fan turned on weird motor noise
- Crossfire 2004 rear wing not moving
- Crossfire 2004 power steering system
- Turns over but doesn't start
- 2004 Crossfire Limited ISSUES
- Car will not crank, pulled RCM & did solder repair
- SKREEM connector
- 2005 crossfire coupe
- Behind Gas Cap Filler Door (Water Drain hole and Drain hose)
- 19lb injectors without tune?
- Rear Window Problem (Defroster Wire)
- Autostick not working
- Car won't start
- Key Fob replaced and then Car won’t start.
- Car not starting - fuel pump relay
- Roadster Top Malfunction
- Battery Drain
- 2005 Chrysler Crossfire Won’t Start/Turn Over
- 05 Crossfire idler pulley fail
- convertible
- Crossfire sputters -feels low on power - wont start
- New Keys from Needswings
- Oil on pan
- Over center switch bypass
- 04 hard shift, dash is lit up
- Electric module help
- No ac, heat, vent or radio
- Trying to help . . Need to get car on Trailer
- What size tap needed to rethread wheel hub bolt holes?
- 05 Crossfire Base Multiple Issues (Driveshaft, Trans, ABS Etc.)
- BAS ESP warning light
- SKREEM Module Replacement NEEDED
- a/c climate control blend door location
- Help! Key Fob randomly stopped working and car won't start
- Air Conditioner works intermittently
- Unidentified part
- Massive voltage drop under high RPMs
- Anxious and Patient in Lincoln, CA.
- alarm problem
- Too Much Brake Pedal Travel?
- Need Help Won't Crank or Start
- Top Won't Raise
- Anyone use an E55 harness on their v8 swap
- Ebrake shakes when accelerating
- Convertible Top
- SRS Light / B48 Code / SRS Emulator? / Last light for the night!
- noise
- Question about secondary air injection pump
- ESP/BAS & ABS light on & Reset did nothing.
- Skreem and key now available in Canada
- Alternator blown
- Motorcraft Plugs in my 2005 Crossfire NA !
- AC blower Motor fried BUT..do i replace it ALL?
- Roadster No Start Issue, Help, Please!
- Flashing Emergency Lights
- Low coolant light
- Supercharger turning off
- REST Button Automatically Turning On....
- '04 hard lurch putting in gear, too many lights
- Shake
- Blend Doors vacuum line. Or am I missing something else?
- Spoiler limit switch replacement
- More Airbag Module Issues
- Engine problem - Looking for advice
- Highbeam issue
- Still burning oil - Desperate for help
- Starting problems
- Will Not Start
- E brake light when clutching
- DRB-3 Crossfire card
- Codes P0171 and P0174
- Replacement key fob shell breaks remote function
- Technical support
- Erratic / Intermittent HVAC Blower / Fan Fix
- I have a horn not working
- fuel pump failure
- Vibrations when accelerating, decelerating, or when hitting puddles or raining too ha
- Battery/Electronic Issue
- Cross fire won't start
- bas esp...???
- Key fob not working
- TPMS Mysteriously Working Again - After 3 Years!
- 2005 srt
- When is it NOT an RCM issue Alone?
- car alarm randomly activated
- Supercharger add on
- Emission Status Incomplete
- grommets for breather cover
- Help
- removing cover on heater control valve's
- Help clicking noise
- Need help with my XF!
- DRB III Crossfire Diagnostics Tech Guide
- Help to access behind the dash 2007+ with knee air bag
- Ignition Switch Wiring
- Check engine light and code readers
- Does this thing operate on any Logic?
- Replacing the SRS control module
- Crossfire rear floor brace for SLK modification
- HELP!!: N/A 6MT Won’t rev over 5K RPM
- MDP can no longer help with our SKREEM failures
- Some SKREEM developments...
- No high beams
- Tightening steering play
- skreem auto tranny vs 6 speed
- Too lean, too rich ... too many to list!
- Battery died
- Lost power and died
- Electrical Problem - Please Help
- Powered up my free '04, questions looking for answers.
- Problems going into gear w battery low
- Oil Filter O Ring Blowing Out
- Oil/Filter Change Tips
- FSS is set to 3,500 miles instead of 7,000 miles
- Disconnect Battery Reset Items
- Does this look like an RCM Problem?
- Cooling fans won't stop running with car turned off
- Anti-Theft System has Shut Car DOWN
- Weird rear noises
- Another No Start...But different :)
- Sounds like a taser...
- ABS brake sensor cost
- No start - SKREEM?
- spoiler linked to which wheel sensor
- battery for alarm
- Electrical
- Computer programming issues
- "Apparatus Box" Blower Motor
- computer electrical issues
- crossfire hood strut fastening clip
- won't crank '04
- Will not start every time
- BAS ESP light comes on every time
- Gas cap tether clip
