- Replacement for siren module
- Automatic Transmission gearshifter stuck
- Looking for spare key
- In operative key fob
- Break NIGHTMARE! (pedal squishy & traveling)
- Input needed
- Clips for Convertible Top ?
- ECM 2006 Chrysler Crossfire
- Bad fuse?
- Help diagnose intermittent rough running
- car running with no instruments working no a/c
- How much does it cost for a locksmith
- Cant control fan location, blows out every vent all the time.
- key wont start the car and wont go into gear
- All warning lights on, key fob works, no code, crank no start
- Fried my passenger headlamp socket - need help
- Roof bucking and window bow won't drop into place.
- Help with cut wires PLEASE
- Trying To Replace A Fuse On My Crossfire Fuse Box Looks Different
- cps , after 3 no luck . Now it's igniting at a tone wheel and pulse ring could be a
- SRT6 - Misfire
- Hello. The wire harness in the trunk?
- Parking brake, rear pads, and hardware
- Relay Control Module
- Camshaft position sensor bolt size
- CPS Install
- Transmission Will Not Shift
- no crank, black rectangel/square in the IC
- Suggested Troubleshooting steps for stalling
- 2005 Crossfire roadster key and shifter problems while parked on slight incline.
- Key stuck in ignition
- CKP location and more
- Gremlins in electrical
- It's ALIVE!
- Won't start after stalling, manual trans
- Manual trans issues
- CLP shenanigans
- Locking System won't disarm with FOB
- DRBIII in Plano TX if needed
- 2006 XF engine stumbling.
- Pictures of what's inside the gear shift lever assembly (SLA)
- 2005 Crossfire Shift Knob Problem
- Hood strut/support
- No crank after new keys
- Crossfire Key Diode
- Battery draw
- Lock/Key Issue
- Issues with O2 codes
- AC charge ?
- ESP/BAS Light // Stalling on streets
- engine shut down
- Blown radiator: a case report, and a new possibility
- More pesky dead battery woes!
- Always something! Code P0007 and C101E
- July 2023 Car starting issues – probably the RCM
- Blower Motor Continues to Operate with the Keys Out of the ignition
- Chime when shifting into park or reverse
- Will not crank
- Electrical Problem
- Oil filter "spike" loose
- 2006 crossfire Limited Coupe BSA ESP light
- Looking for dyno tuning in NE Ohio
- Data link connector
- Door latch replacement question
- Windows opening by themselves?
- Top won't go up or down
- 2005 Crossfire roadster basic has a relay static noise
- 2006 Crossfire Cranks but will not start--Tried Many Suggestions
- Small board with 2 wires under cowl?
- Drain line - evaporator air con coil
- starting issues,
- 2005 Roadster battery issue again
- RPM's Dropping to Zero (P0103 - Circuit A High)
- 2004 dies while driving, wont start
- ABS Pump/Module
- Flakey AC Fan Switch
- 2006 Crossfire Dead
- rear main oil seal & cover
- Mr
- Coolant light problem
- Does Manual have a TCM and where if so?
- data link connector Pin 5 wire routing
- 2006 Crossfire won't start
- Da Beat goes CPS
- "Fin" won't stay down and can't lock doors
- Need help finding extended lug bolts for 20mm spacers.
- Having fuel issues.
- Rear Light Markers not wired in?
- I'm stumped on code p0446 please help
- Headlamp adjusters
- Trouble communicating with ABS module
- Ignition Coils
- Won't Start
- I am on a road trip and got a P2098 code, safe to drive home?
- 2006 crossfire coupe intermittently won’t turn over
- Engine stops at Idle.
- Urgent need to fix
- Magnetic clutch of the AC compressor
- Crossfire coolant light on and AC not working properly
- ISO Original Manufacturer's Wiring Diagram
- Passenger power seat will not move
- Roof issues again
- Flickering Dome Light
- Rear defroster noise
- Brake pedal goes down very far
- BAS/S Light comes on
- Who can diagnose my 2005 Chrysler crossfire Mercedes-Benz or Chrysler
- Custom Gauges / Clocks / Dials
- Dash LED lights are dim!
- Crossfire 2007
- radiator fan runs all the time even with car off
- Replacing Seat cover with NOS
- Instruments and gauges working intermittently after being wet
- Dang! '06 Xfire no crank issue "AGAIN!"
- Passenger side headlights out entirely
- throttle problems I think, HELP
- Hydraulic fluid for top and cylinder repair
- SRT6 2005 gasoline smell when tank full
- SKREEM issue for UK owner
- Wire harness from washer reservoir
- 2008 Convertible top issues
- CHARCOAL CANISTER SHUTOFF VALVE OHM value
- Cut wires
- I KNOW this has been asked a million times and someone will likely yell at me but…
- Spare RCM and BCM
- Performance Chip
- Replaced RCM
- Auto-Shifter Shifting in Left Turns in Manual Mode
- Variation on the Mystery no start
- ABS rear senor cable issue
- Car Bucks and Stalls at Random
- Urgently in need of new working keys 2005 Ltd
- Two break pedal switches?
- PO is a POS
- Central locking failure
- Accessory Belt Tensioner - stiff and squeaky
- Morimoto 2strock 3 led bulbs
- '05 Xfire Limited: ECU / RCM box cooling
- How to lock coupe
- Squeal from front of engine?
- Supercharging to Supercharged M112 -> M11k-ish
- Some vacuum lines
- Computer issues
- Problem with spoiler
- '06 Xfire hic-up!
- Throttle bodies and Intercooler Cap.
- What's going on?
- Poltergiest in my Roadster?
- Changed CPS, still having problems.
- Remote fob problems
- Skreem Questions
- Are early Crossfires different ?
- Hesitation and/or missing
- the OEM alarm won't shut off
- Check valve
- Backfire when starting
- Blank Dash. HELP HELP
- Battery Dead ; won't jumper
- Cylinder 6 Misfire
- Convertible top - Maintainance
- SRT-6 EGR Valve / Transducer Location
- Code P0455 Woes! My free Crossfire has many problems
- No start, No crank
- Funky Looking RCM
- Not start, no cranck
- Skreem Repair by MSS
- Skreemulator the Skreem replacement
- Left turn signal dash light
- Convertible Top
- Garage door opener
- Are the (ECU & Key Transponder) the only thing SKREEM cares about syncing with?
- New Members Needing Tech Help
- License Plate Mount fix
- Car won’t stay running
- Catalytic Converter repair problem.
- Wooden door pull handle.
- Heater / AC fan switch problem.
- Help with SRT serpentine belt
- Crossfire won't start
- security bypass ?
- Pinout fuse
- SKREEM Conumdrum!
- At-205 re-seal
- Clicking no start / good battery
- Crossover tubes
- Starting and Water Ingress Issue
- Spoiler Button/Light Question
- Immobiliser
- Starter ground strap
- SKREEM work around mod?
- Won't Start problem
- Idle
- Using a battery starter
- spoiler override switch on console
- Intermittent starting
- Manual Shifter Locks In 6th Gear
- Dash Light red bulb
- Windshield wipers run Continuously with Key ON
- Radiator Cap milkshake
- Chime sounding and roof selector switch flashing
- Rear spoiler behavior & battery drain
- Remote won't Lock/unlock door
- Leaking red liquid
- Door not latching completely
- Crossfire Newbie needing help with water leak
- Supercharger does, sometimes, not kick in
- Throttle pedal position sensor
- Really Bad Gas Milage (9 MPG)
- BAS-ESP connector
- convertible top hand lever
- 2004 Xfire- smoke from steering column
- Electrical Back Feeding, FYI.
- Repair Service for Autodimming Rearview Mirror?
- No Crank / No Start (Not RCM)
- Random NO START
- Airbag warning and Seat
- Chiusura centralizzata non funzionante (Locking Pump Issue)
- Steering wheel locked up
- flashers come on for no reason
- Will Non Ethanol 89 Octane Work in Xfire?
- performance chips
- Obdii
- Rear window latch not opening
- Wiper - one side not working
- Electrical of course
- Odd error messages
- Can a Crossfire Tow a motorcycle on a trailer?
- Crossfire 2004 wont start after repair of RCM and replacing CPS
- Convertible Top Help
- Top or Trunk ?
- whine
- EVAP purge valve
- Battery Problems
- 2004 crossfire water under passenger seat
- Bumper question
- Help
- Help with no start
- Air Con and Radiator Fan
- P0410 a new twist perhaps
- Skreem going bad?
- AirBag Sensor Module - Airbag Failure Light
- throttle lag
- #9 fuse
- Diagnostic Socket fuse blows
- Help High Pitch Sound
- Crossdire Doorlock won't turn with key.
- 2004 Chrysler Crossfire Coupe - Serpentine Belt Slipped Off
- Raleigh NC Repair Shop
- Crossfire trunk locked
