PDA
View Full Version : Troubleshooting & Technical Questions & Modifications
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23
  1. Optima 34R Battery
  2. 2 air intakes? two air filters??
  3. Brake light lights up, whats the problem?
  4. Where is the PCV valve?
  5. Mobil 1 oil color change???
  6. Airbox: C320, C43, E500, S500... Which one is best?
  7. Any one have any ideas for a new cluster look
  8. Master list for MB/Crossfire part numbers
  9. Problem #2: Blower does not turn off. Does not blow cold air.
  10. Hi-Beams quit working?
  11. Conv top 05
  12. Cigar Lighter Problem
  13. want/need a AF guage
  14. Spare tire location
  15. Low coolant warning light
  16. oil ???
  17. Recurrent dead battery
  18. Super charger pully question.
  19. How the FSS Really Works
  20. autostick question.
  21. Brake Pad Disintegration!!! Another reason to change to Rotex Golds
  22. New Wheels and TPMS Arghhh!
  23. Traction Control Delete?
  24. Why not electric locks?
  25. a/f
  26. Turbo??
  27. Post MB/Crossfire part numbers here
  28. TVT's CAI: how bad is the whistle?
  29. bas/esp warning light
  30. It sure looks better in person
  31. Illumination when car is locked ! Heeelp
  32. Car rolls backwards when in drive. (auto trans)
  33. Tire Sizes 285-30-20
  34. Where is This Water Coming From?
  35. Install a SRT boost gauge
  36. TVT 265 Performance Question
  37. rear diff
  38. Transmission Upgrades
  39. dealer reflashes your ecu???
  40. My first MOD!!!
  41. Windshield wipers have gone nuts...
  42. I just discovered Eurocharged!!
  43. Automatic transmission fluid check tool length?
  44. AC compressor noise
  45. ECU Remapping
  46. Shorter Wheel Studs
  47. FSS questions
  48. key fob won't work, alarm goes off - stuck!
  49. Air Bag Question
  50. Rusted Nuts & Bolts ?
  51. Performance Chips
  52. Change Speedometer Illumination?
  53. Blue fluid leak from behind RF wheel
  54. Oils other than Mobil1?
  55. Weird "humming" noise at speeds 0-38 mph
  56. Help! Mayday! Loss Of Power
  57. ASP Pulley Kit from Needswings
  58. Crossfire just turns off while driving, and I can't get it started again for a while
  59. please help
  60. cigarette lighter not working anymore... fuses appear to be ok?
  61. What are "Steering Locking Bolts"
  62. Small Part Found on Floor Mat
  63. Koni shocks, are they worth it??
  64. Service reset
  65. Anybody have a Crossfire with the adjustable headlamp option?
  66. How to disable DRL's on a Canadian Crossfire
  67. 2005 LMTD convertible top please help!
  68. warranty
  69. amp connector
  70. American market headlamp switch wanted.
  71. Tire popped...bring on the weird noises
  72. weird poping noise
  73. do all xfires sit the same height,, what is yours
  74. Question: Isn't the stock XFire intake already a cold air intake?
  75. Simple horsepower mods
  76. trying to learn more
  77. Weird sound
  78. Removing OE Filters With NA Intake
  79. Xfire dies while driving
  80. What is the rubbing?
  81. Crossfire Tech In Central MASS?
  82. Fuel Cleaners
  83. Wire from battery to Cabin
  84. first mod and it's free "for the newbees"
  85. Easily Protect Your Battery from Early Death
  86. car alarm keeps going off
  87. Mixing Tires
  88. Tow-away alarm problem
  89. P0410 Code
  90. Long cranking time
  91. Steering box on it's way out with just 19,500 miles on the clock
  92. Sorry this isn't Crossfire related, but some cool fab work.
  93. Wheel hub dimensions SRT6 !!! URGENT!!! big brake kit
  94. Used Supercharger on a N/A model
  95. transmission trouble
  96. Washer Fluid Tank
  97. Supercharger Conformable Coatings
  98. X-fire Air Scoops?
  99. First check for 2005 crossfire with 50K
  100. Fuel Filter location?
  101. ECU Performance Chips
  102. car just cuts off then wont start for awhile
  103. Something's draining my battery
  104. Crossfire Performance Chips
  105. Recommended OBDII tool for Crossfire?
  106. WD-40 for throttle body
  107. Locking Car Security Chirp
  108. Front fascia and fender mounting points
  109. Star Diagnotic System SDS DAS on EBay
  110. help needed on start of car?
  111. BDM100 USB tuning tool???
  112. Please Help!! Active Spoiler Issue
  113. Battery relocation...?
  114. TVT CAI install done?
  115. Forum's BAS/ESP solution
  116. Strange lighted door sill problem. Please help!
  117. Servicing!
  118. MAF sensor
  119. Noisy clutch??
  120. Shop Recommendation
  121. California Cars with Tune question.
  122. need a bit of advice
  123. tvt 265 gains???
  124. sprint booster/ bottle cap does it work?
  125. ECU Tuning meet... Give me a reason to Travel
  126. Code Reader
  127. Sprint Booster difference or not?
  128. Code Reader / Logger
  129. Working on the fuel controller
  130. Coolant level light came on briefly yesterday...
  131. Michelin PS2 comments and questions
  132. New Video Nitrous Purge!
  133. Shift knob
  134. clk 430 engine cover
  135. Tire Sensor Question/Help
  136. Highly engineered turbo
  137. speed booster a must read
  138. list of codes
  139. The Best $300 Mod Available!
  140. How do u turn off outside air
  141. Erratic airflow from heater
  142. Side effect of 74mm Throttle Body
  143. Tough Manual Shifting
  144. Misfire on cylinder 3
  145. tinted tail lights
  146. OBDII connector?
  147. Light out issue...
  148. Techron and ECU flash
  149. Ignition key won't turn
  150. 7th injector or larger injectors???
  151. '05 Crossfire Problems!!! HELP!!!
  152. Crossfire Tidbits
  153. Stalling
  154. Instrument cluster problem
  155. K & N Air Filter
  156. Success with SRT wing on a Limited (electrical)
  157. Heavy-duty or racing motor mounts
  158. 74mm Throttle Body Upgrade
  159. Need some help
  160. Your electronic knowledge put to a challenge!
  161. dash/console lights
  162. I need help with tuning SRT-6 in Center County PA
  163. Shift Boot Conversion
  164. Code P0401, any suggestions?
  165. Clutch Replacement Question
  166. Need someone near Dallas to drive my car.
  167. Toddler Car Seat...help!
  168. Need Help Radio goes out when pushed hard
  169. Concerned about ECU Tune & Mods & Running Lean
  170. surge chip
  171. House of Power
  172. Thank You Mmz_timelord For Your Contributions
  173. surge chip
  174. Crossfire Tint Template
  175. How to reset the maintance light - FFS
  176. Transmission/Check Engine Light
  177. 0-60 times for '03 auto Crossfire stock
  178. toes?
  179. What is this flashing symbol on my ODOMETER!!!
  180. Putting in a Sunroof?
  181. Stainless Roll Bars (Sport Bars)
  182. Converting '04 limited to SRT-6
  183. HELP-Vibration after winter storage
  184. '05 ltd coupe keeps shutting down?
  185. whitch car get the most mods
  186. Race Ramps - two piece design
  187. manual or auto tranny sprint booster?
  188. So you say you want to flash your ecu at home huh?
  189. stuck in park???
  190. Battery Replacement
  191. Engine drops 1,000 RPM's when shifting???
  192. Fuel Door won't stay closed?
  193. Is there a tutorial online that shows how to manually change oil on the Crossfire?
  194. National Back Ordered/Seat Heater Modules
  195. Lifters Replaced?
  196. sporadic hesitation at stop/start
  197. Wing goes up when I start the car
  198. Nitrogen instead of air in wheels
  199. Tips on getting rear muffler hangers back on?
  200. The Whreel Deal on Aftermarket Rims - Need good input.
  201. Has anyone installed Stebel Nautilus horns
  202. ECU Tuning and Mini-meet in CT, March 14-15
  203. Sts Turbo 5 Psi With Out Tune.can It Be Done?
  204. Spoiler preference?
  205. Pulling fuses 17 and 18
  206. Road Noise
  207. Intake Manifold work
  208. Track Control Light Problem
  209. Sprint Booster
  210. Oil Filter
  211. Nitrous Purge Kit
  212. TVT / MB C320 Airbox Flow
  213. Relocate Parking Brake Lever?
  214. sts rear mounted turbos system. turbo charged are crossfires!!!
  215. Secondairy air pump code..need help
  216. Convertible problem help!!
  217. Spark Plug Gap
  218. new option for cup holder
  219. Noise in dash, dash lights out,doors won't lock...
  220. Flashing gas light...what is it?
  221. TVT Designs Airpump and EGR block off ?
  222. Dependable???
  223. Strange Odometer Reading
  224. RE: fan controll swith/ cabin fan
  225. Powder coating
  226. 07 Seat swap?
  227. RE: seat heaters
  228. HID installed
  229. Everything you need to know about Methanol Injection
  230. Dyno Software for ipod Touch? iPhone
  231. anyone get po505
  232. Brake Lights
  233. SKREEM no more!
  234. Factory Hood Modification
  235. Who would be interested in a affordable set of headers
  236. How old is your car in people years
  237. "Auto" lights
  238. Who has this tool?
  239. Traction
  240. Service Manuals
  241. going to convetional non-low profile tires
  242. Faith Renewed in my crossfire advice wanted on heads and cam work
  243. Emissions
  244. Starting Issue
  245. Clutch problem + horrible service
  246. temperature sensor broken, what could it be?
  247. Wing wiring mod?
  248. Brake Fluid And Brake Lines
  249. oil filter question
  250. Service Due
