- CEL after unplugging Amp
- Heater Goes Full Hot Only on Driver's Side
- big issue: running lights on/alarm started/now no response
- Advice - Alarm System Prevents Car from Running
- gas vapor
- gas vapor smell
- Subsciption MB Electronic Parts Catalog (EPC)
- won't start
- Radiator Fan & Electronics
- Wipers won't stop
- crank position sensor
- Intermittent Losses of Power, Car Shut off and Restarted Immediately
- Fan Control Module Internals...
- what is this part, found in trans pan
- Stuck in Park
- Car won't turn over
- 2004 Crossfire Beginning to have problems
- Noisy Fuel Pump?
- AFRs Help
- p500a error code. '04 coupe
- What is this hose?
- '04 coupe electrical problems
- Double wrench service confusion...
- Datalog
- Eurocharged datalog
- Code P0171 - Intake Manifold needs replaced.
- testing rear gears and pulleys
- Tunes
- Sprint booster
- Alarm problem
- ECU Flash before or after throttle body mod?
- Aftermarket key fob car wont start
- Central Locking Control Module case?
- alarm system keep going off
- cigarette socket not working
- electric motor noise.
- New tick!
- Front Bumper Issue
- Idiot, put battery in backwards.
- BAS ESP Light + Soft Brakes + Weird Sounds
- Heater controls don't work!
- Bad front caster
- New Member Question. creaking sound coming from the rear of car.
- Door lock issues '04 crossfire
- Alarm Control Module
- fan control module?
- Repair Code "Wrench, Clock 24"
- Speedometer doesn't work; Brake, ESP, BAS lights all on
- Waterpump shop labor
- 2005 crossfire won't start
- Key cutting in 2015
- "Light out" and plate lights ?
- automatic transmission
- High Idle
- Driveline noise
- Rear toe
- If I'm stocking up on spares from a wreck--which ones?
- Small Oil Leak
- 2005 SRT6 Limp Mode (Stuck in 1st gear)
- Drivetrain: Metallic Rattling Noise
- Manual trans fluid question
- difference between these two tb #s????
- Does this sound right re Autobox Torque Convertor
- Srt Turns over but does not run
- overheating problem
- how to disable tpms light
- Mechanical questions...
- XF traction control question
- Transmission fluid brand Issues
- Engine shut down - no warning!
- Polyurethane filling motor mounts
- 2004 crossfire key stuck in ignition
- BAS/ESP Light Troubles
- Convertible Top Problems!
- Fan Making a Clicking Noise
- chips
- What would cause the car to suddenly stall?
- Need help figuring out ticking
- Intermittent Clutch Issue
- getting to the starter
- bad new walbro or bad ecu flash
- roadster deck lid
- Two Engine Issues: “Stuttering” and “Semi-Stalling"
- General upgrade advice
- How to stop roof alarm
- help plz? engine miss
- Need specs on fasteners for aerodynamic splash pan under engine
- How to manually unlock hatch
- Fuel gauge problem\ Fuel level sending unit
- Replacing Ball Joints and Tie Rod Assembly
- Alarm keeps going off...
- About to give up...NEED HELP!!!
- convertible top problem
- heated seats
- Flashing low fuel indicator lamp
- Can't turn off alarm after new battery install
- ECU Programming
- Locked door tone
- Code reader not communicating with computer
- Key/fob/transponder question
- Exchange SRT6 Wing for Std. Crossfire Spoiler
- Torque pro
- No starter turn over
- SKREEM Module
- Electrical Issues (Convertable Roof, Spoiler, Rear Defrost, Heater/AC Fan)
- Aem fuel pressure regulator
- Car Dies After Sticky Ignition Key Mod
- wiper motor replacement
- Air Bag Light
- Car won't start again!!! HELP PLEASE!!
- Loose pulley?
- Loose column
- Plastic tip gauge broken in gearbox
- Help with info please
- No power to fuse #8 right headlight!
- Idles rough, No throttle
- Throttle is messed up **Video **
- Sprint Booster... Round 2
- Searched mystery no start... want to confirm a few things
- Central Locking and Security Alarm Issues
- Used TCM Need Reprogramming or Not?
- No Supercharger Function
- Nitrous Question
- Hoping you guys can help me out!
- Fuel Hose Size?
- P0400
- Key and alarm issues
- alarm sounding
- Radiator Fan Runs Constantly
- Another cry for help
- Transmission Control Modual Stuck
- Fan blower motor
- Crossfire dead battery
- Reprogramming needed for LSD?
- Tach Signal
- 2007 convertible windshield trim trouble
- Air Bag Light is on.
- pls help - SRT6 mods effect on emissions tests
- trans seeping?
- Sticky Igniiton Key Fix - Comments
- Cannot reset/reprogram key fob...?
- Charging Light
- Whining Noise in Engine Bay
- Eibach springs rear clunking noise
- Air Selector Dial Not Working
- Lcd brightness in the radio?
- Does this all seem to check?
- airbag warning light
- Rear Gear Change on a 6 Speed
- shimmy at idle
- help please, no start, lights flash, fob's not working
- Help! I have no brake lights!
- Pop out of 1st ?
- srt6 check engine and bas/esp both on
- My Crossfire has a rough idle
- Crankshaft pulley noise
- Crankshaft issue?
- Car Turns on, Turns Over but Won't Start
- '04 Rear right brake light not working
- Transmission sticking after WOT (Auto)
- Transmission temp question
- DRB III tidbits in this article
- Car won't start - no cranking
- Ignition Switch/Lock Assembly Problems
- Mysterious clap
- Visiting the US and car has died!
- battery booster that will fit in glove box
- How to detect and repair parasitic battery drain
- Car starts, immediately dies?
- New troubling issues
- skreem module??? need help
- coolant light
- die and no start
- '83 Camaro PLEASE HELP!! no start/blowback
- No Fuel To injectors '83 Camaro Tried ...
- Does anyone know what this nut/bolt is for?
- Lights flashings & ?
- Crankshaft Position Sensor (CPS)
- stumbling
- Trunk stoppers causing damage
- Car Turned Off While Driving, Engine Wont Crank
- key fob problem
- Car stuck in Park Cannot Shift? BAS ESP Light on too
- Grounding Strap/Cable locations
- Various lights not turning off!
- Cruise control shuts off when I switch my lights on.
- Central control locking unit
- '04 Crossfire A/C problems
- wipers come on by themselves
- They say the "air intake element" is causing the whistling...
- Start issue
- Problems? Any help.
- Change radio frequency to a diffrent region.
- Is this normal operating range?
- It looks good but it is a doorstop
- fusebox nut
- 2006 Crossfire Will Not Start
- Burp on shift: 6 speed manual
- electical!! ughhh
- I think I am done
- My turn..Mystery NO START
- Coolant in Oil filter
- Seeking OBD2 to USB Cable + Software
- Eurocharged Tune
- Check Engine Light
- codes lean and rich same day
- battery drain
- Problems since changing the battery
- Help with a couple of small issues
- taillight issues
- Can I replace the spoiler button with a toggle switch?
- EGR valve Check valve?
- Engine temp gauge not working.
- Please help!!!
- Bosch Spark Plugs
- Rockauto RCM's
- Performance Chip
- I pulled 2 hard (RCM -K40)
- 2005 crossfire won't turn over
- UPDATE!!! On car won't start after running out of fuel🚫
- Fuel System
- 2005 Roadster power seat issue continues.
- run away starter
- crossfire cranks but will not start
- Help!!! Please! Need it badly
- Turning Off the ESP, ABS & Traction Control
- '04 Crossfire wont crank
- Aircon compressor
- Help! Crossfire will not turn over!
- Cps, replace or not
- Blank key question
- coverting base to power seats
- MaxiDAS DS708
- Changing the front grille
- Crossfire sporadically dies and all lights come on
- Banks 1&2 Lean?
- Car won't start after running out of gas and refilling.🚫
- Rear end clunking noise
- power seat issues
- flaps do not retract when closing top
- I assume I am right ...
- Power seat issue
- Electric seat problem
- Newby question re power
- AEM FIC spreadsheet needed...
- Roof going bump
- Are there any screws here?
- heated seats
- Remote entry issue
- Central locking not functional
