- Crankshaft Position Sensor strikes again!
- Spoiler stuck open
- Check engine lights
- Help Please - 2nd time no start
- Traction Control & Spoiler
- tune up (HELP)
- new guy new problem, HA
- Wind noise from drivers window
- Check Engine Light
- Code P0715 won't leave me alone
- new spark plugs & wires
- Whats the Name?
- maintenance
- Central Locking (potential problem)
- Opinions on Crank Pulley Please!
- transmission surges downward?!
- Will not start
- Belt Squeak when cold
- Engine hesitation
- Door locks/hatch lock/lights/gas tank
- what just happend, a squirt/leak from supercooler
- Engine Stutter
- Hesitation when pushing in clutch
- 75mph Stall
- Door Chime won't quit!
- My Eurocharged Tune ECU Recovery Mode Experience
- AC Blower
- Windshield question
- Broken windshield
- Car wanting to stall all of a sudden!
- Chid seat & uk model -definitive answer
- trunk lifts
- Oil Consumption
- SRT6 : Removing supercharger pulley ...
- Help plz! Braking system failure! Limp home mode twice!
- Did not downshift after freeway cruise
- Washer pump
- intermittent very hard start.
- Power flicker/Alarm Sound during driving and post battery-tightening.
- 2005 convertible top will not operate
- A/C Rattling
- gauges
- 1rst Gear Issue/High RPM's
- Please Help - SRT6 abruptly loses all power
- US crossfire in Germany needs help by front suspension
- Air bags help
- needwings CAI noisy?
- How do I tell?
- SRT Wheel source?
- cigarette lighter flashlight?
- p 0101 code
- Double wrench -300 won't reset
- Oil? Pads? Rotors? Shocks?
- Weight of the Chrysler Crossfire
- Potential Differentials
- Cupholder my next Mod...
- Dome light cover removal?
- Engine Problem!!!
- Finding owners/maintenance records...
- SKREEM Module...Commentary
- Battery Light
- crossfire not starting after warms up
- Ignition Locked - New Cylinder Cost
- Come on who can answer this puzzle re a BAS ESP light problem
- What is an IC pump?
- Hypertech - Max Energy
- TPMS - Yeah baby!
- Fuel pump
- Problem with removing the lower engine cover
- Need Help Upgrading Non-Supercharger to Supercharged
- Well after MONTHS of issues/FINALLY getting RESOLVED! Have NOW run into MORE issues!
- Doors & Trunk - Locks dont work
- help! double wrench -500 symbol on instrument panel
- Rear Wheel Bearings--Help Please
- TPS Light On
- Gas light flashing, but I have a full tank
- Good vibrations? Maybe not...
- RCM or CPS? Need opinions!
- Chrysler DRB III scan tool?
- Pulling to the left and poor handling
- Cooling Fan not Running OVERHEATING
- Alignment Bolt
- false warning lights
- Cleaned the intake system yesterday, what is this...
- Lock and unlock air sound
- Car Won't Start After Fixing "Sticky Ignition Switch" HELP!!!
- Ignition switch problem "pin"
- roadster roof help for anybody in the future
- performance chips
- No start over 1 year later help
- Starter just click click, won't turn the engine
- Ignition Lock Advice
- Recommended belt
- OBD Trouble Code P0410...
- Location of OBD-II Connector???
- Automatic transmission whine
- Fuel Requirement
- Suspicious engine behavior...
- door lock mechanism
- dashdaq/zeitronix
- Crossfire stalls intermittently in traffic
- Timing Related
- How to reset CEL without ODB2 computer?
- HELP!!! '05 Crossfire stuck in 1st gear...
- Headlights not working properly
- BAS/ESP Light on with C1160 fault code
- Engine not start. All lights ok, but no noise.
- Where to buy wheel bearings?
- PLEASE HELP...START ISSUE!!! ECM? RCM? Skreem?
- Mystery Re-Start
- Cruise Control Disengages
- P0500 - Need advice on fixing.
- Horn not working? Suggestions?
- ABS Light & BAS/ESP Light & spoiler stuck up & top will not go up
- Fan relay module same for all Crossfire models?
- My Driver's Door Window is Hitting Against the Frame?? Not closing properly!
- Help!
- For those of you who have an Ultragauge, Scangauge, or use Torque...
- Has anyone swapped seats from an 04 to an 05 yet? Need help!
- Am I supposed to have a plug here?? Re-assembly after sticky key!
- BAS ESP Light
- Another mystery no start
- Tire pressure
- Another HVAC question.. audible door/vent opening sound with going from 0 to .5 fan
- problem with 2 gear and the gearbox freeze
- Central Windshield Wiper
- Mechanical/Transmission Poss Issues/NIGHTMARE time trying to find issue! HELP!
- AC/Heat won't turn off
- Relay control MODULE
- Blower motor resistor
- Aftermarket steering hub? revisited???
- Tranny Question???
- Are there any simple mods that add power and value?
- Best performance enhancing mods under £500?
- Fuel Pump Relay Project - We can rebuild him
- How to test blower motor vs resistor vs hvac control switches???
- A/C blowing hard then soft
- Idle adjustment
- Hood Latch Release Lever thing broken...
- Alarm Problems
- Gas pedal mod question
- Headlight Bulb Replaced Indicator Light Goes On
- Needswings CAI with stock engine cover. Possible?
- Security and Anti-theft Relay/Module Questions
- Auto on/off head lights
- BAS ESP Light
- 2 faults please help :(
- Two trouble codes reading $40 fix
- How much Transmission Fluid needed to replace after filter change
- tranny in Seattle
- A tribute to Rudy
- Can an ECU change from car to car?
- My memory is failing me, need help!
- Won't lock/unlock from remote or dash button
- Start Removal
- Flywheel Specs
- Battery Drain Problem
- Convertible top does not work
- Supercharger comparison - 3.2 vs 5.5
- '04 Crossfire left me stranded
- A/C problems
- Help!
- Car won't start
- Help with Misfire issues
- car wont start
- how to get a FREE EuroCharge tune
- Cruise control isnt working
- Anyone k?now how to disconnect stock sub
- performance chips
- Annoying sound when i open my door!!
- Possible to trap 95+ in the 1/8?
- Fan controller unit ex-USA
- Ignition switch
- Power Steering Issue Uknown how to fix
- how to remove shift knob?¿??¿!!¿
- Ignition Lock Assembly Help...
- LateModel21's Dashdaq Mount - Installed
- Sticky ignition switch
- Tribute and thanks to Rudy Compart
- Alt pulley removal without an impact?
- Has my crossfire got a iod wcm fuse ??
- ***-4-tat car won't start
- tranny problems
- New to site ... Question
- EV Crossie
- Thaat thear is Slicker than snot on a squashed bananna, maybe
- Kickdown prob !
- Intercooler or Chargecooler
- Window Problem
- newby question : where can i locate the engine number on the actual engine
- D-ring for Opening Convertible Top Broke
- Best OBD2 to buy
- Quick Mods for Performance
- HELP!!! Key Fob wont program...
- Eureka, I have found the light, and it is good!
- Varta battery
- Max Fobs
- Passenger seat belt won't click
- air filter size
- Central locking replacement... Things still crazy...
- Remote start
- My electrical accessory Mod!
- Help! Replaced Clutch, Now No Start
- Maiden in distress AGAIN Zzzzzz
- mystery no start
- Alarm goes off/Lights flash randomly
- Replacing dashboard lights bulbs with LEDs ones
- Dashdaq enhanced data
- Balance Shaft Chain removal
- Broken Headlight Glass
- Strange noise
- Water test setup for the intercooler
- Heater Blower Resistor Regulator
- I installed a killer chiller & how it works
- working question for nos
- Keyless Entry Push Button Start
- Fixed oil leak, but gave up on wheel bearings...
- Wave trac sent back to Untrax
- from 3.07 to 3.27
- Need Help With Rear Differential Issue
- Anyone Have a TCM I can Borrow???
- Illuminated gear shift knob
- My two SRT 6's times and modifications
- Garrett intercooler FAQ, found this item interesting
- An honest to goodness electric supercharger, really!
- IC's for sale on EBAY, Ha
- I just ordered a new johnson pump CM90P7-
- Keyless lock and Push Button Start
- water intercooler for post cooling?
- parts swapping?
- strange things happening
- Rim sizes that will work
- Rear End Differential Issue
- Automatic Tranny
- gas tank capacity srt-6
- Diagnosing Clutch Issues
- check engine light code PO 413
- Six-speed - vibration in shifter in second, shift w/out clutch
- Inner Fender Liner Replacement
- Strange starting problem, stalled immediately then no power?
- Squeal coming from fan at low speeds.
- Question for those who have changed rear wheel bearing
- 74mm Throttle Body
- tpms problem
- A/C and Heater Control Head problem?
- Auto transmission stuck in 4th. Until a re-start
- Bent or warped rims
- Clutch
- cold air intake
