- Water pump end play
- Looking to figure out what these hoses are in the evap system.
- Xfire has been in storage for 5 years, advice???
- Fuel pump replacement
- hesitation during acceleration
- Blue smoke on startup
- Auto trans mounting bracket and configuration
- Boy Scouting with my'05 Coupe
- AC Woes on 2005 XF
- DRB III tech manuals
- Wiring harness information
- Multiple Electric Issues
- Bad Idler Pully
- Is this a Hidden Key Code?
- Locksmith made 2 keys / Need help
- Transmission Problem or Electrical problem?
- Just picked up from service, something's broken.
- SKEEM Issues (After Re-Flash)
- BAS/ESP and ABS light on. Scan Tool: iCarSoft i980 for MB
- Slow leak under car...found the source...but WTF is it?
- Anyone know what this is?
- Startng
- Rear window washer
- Dual mass flywheel
- esp-bas code 1330 Wackamole
- Weekend ride becomes my daily driver - what maintenance?
- Car will not start after a flat battery
- 2006 crossfire codes. ESP.
- HELP! Drive belt tensioner question
- supercharger bolts
- Trouble with convertible top
- DRBIII Manual
- No crank. Cooling fan runs when key is on. Dash lights work. New Transmission Pisiti
- Battery Drain and Strange noise coming from BCM Area
- Too many fault codes- help
- Intermittant problem
- Need Help, RCM, SLA, TCU? Where to start?
- convertible top
- No crank no start issue
- Maintenance indicator
- Wheel Sensors
- Going into limp home mode within the first ten to fifteen minutes of driving
- Skreem failure
- Check engine light running lean
- Blown Head Gasket 60k Miles
- She be Hot!
- Vertical door hinges
- Relay Control Module & Cooling Fan
- Wiper motor replacement
- Crossfire throttle pedal 2005
- hazard lights work but turn signals don't
- Cruise Control not engaging - DRB3 seems fine - ideas?
- Crossfire mechanic in Orlando area
- Tonneau latch
- Glove Box Light Problem
- Won't turn over
- New guy, new 2005 limited - 2 second starts!
- No speedometer, no brake lights, all dash indicator lights on
- Random alarm trigger - not faulty siren
- Turns over, won't start after battery charge.
- Key fob support
- Spoiler not operating
- No start, but print plate was soldered !
- Help!!! 2005 crossfire, replaced throttle pedal, no rpms
- 1982 crossfire very sluggish
- 2004 limited xfire fan full speed anytime
- Replacing positive starter cable
- Need RCM replaced?
- Alarm random trigger / interior lights dead
- Starts and Stops
- No power to top down or spoiler buttons
- Non-Stop Horn!
- Transmission disconnect during gear change
- Squeaking noise inside of car
- trim inside of the crossfire trunk loose
- stuck driver's seat
- RCM or?
- Dashboard Electrical Haywire
- Engine sound
- Catalytic converter engine performance
- 05 Crossfire Base
- fuel pump for 2005 SRT
- ~ Opinions on Altenator Diode Test Readings Requested Please ~
- Crossfire issues
- Ignition question
- 2005 Crossfire -Key will not turn ignition and beeping sound with red blinking light
- Dashboard not lighting up; car wont stay running
- CLP/SSM Success or Misadventure
- How to remove the pins from the throttle body connector?a
- Blower Fan
- Replacing Alternator
- Air bag light on
- oil filter
- Would you please help?? Metallic noise(static) sound under the car in the rear(avi)
- Dashboard lights all lit up
- Help with belt tensioner
- Computer Control Relay
- No communication no crank
- Skreem or not?
- Scanner
- 04 Crossfire 3.2 6sd standard trans.
- Pedal Commander
- Removing accelerator pedal
- 327 to 307 swap with LSD, '07 manual Limited Coupe
- panic button not making noise
- 2008 crossfire limited acceleration
- Coolant hose in back, Picture Included
- Bas / abs
- Cant clear "TPMS" DTC error
- Coolant Hose "Discontinued" - What Now?
- O ring for transmission electrical connector
- intermittent ac fan speed
- Air Conditioning ??
- Crossfire key
- What Next?
- Brake & Clutch Pedal Mount
- unidentified humming sound
- Loud thump when hitting brake in reverse
- Fuel system lean and Intake manifold runner
- Throttle Response Controller? Thoughts?
- My approach to a smaller Supercharger pulley
- 2004 Crossfire - Electrical nightmare - HELP
- RCM, possible place for a Killswitch?
- electrical or Security system problem??
- Slave Battery For Charging A Battery With A Smart Charger
- Automatic Coupe - No drive just revs
- Alarm
- S/C pulley disintegrated! Is this a thing?
- 0442 code and other issues
- Stating issue
- HELP! crossfire cam module
- My 04 crossfire
- Car key wont turn to ON
- Spoiler will not operate
- Convertible top, wing not working
- Personal, help with getting my car back to life
- Convertible Top
- M113k inquiries
- Burnt Rcm (Feedback needed)
- 2004 cranks but won't start
- Battery change
- Smog check after new battery
- Homelink Garage Door opener dead
- Help With BAS/ESP & ABS lights, Limp Mode
- ESP engine light error: PCM Coding Incorrect - what does it mean?
- Mystery Hole in Firewall Underneath Brake Booster
- Getting code 3fff-0000
- lost key
- Two lonely wires can’t figure out where they go! Help
- HOW/WHAT to TEST if You Have Starter Wiring Issues?
- Lifting a crossfire. Suspension drop problems
- High pitch bird type noises coming from the engine.
- Transmission filter locations
- Double din Radio install
- Battery grounding issue?
- Blinking Dash Lights
- towing button light flashing
- Electrical or computer??
- No crank issue
- Mercedes specific codes
- Safe to Tow a Short Distance with Driveshaft on?
- there is fuel in the charcoal canister !
- wrench for convertable top
- No start, no crank, but dashlights (sometimes )
- top problems...episode 1,000
- Automatic: Wont go back to Park
- Engine stalls out every few hours - help!
- trunk rattle
- Tonneau latch locks but come switch blinks…until…
- A slightly different Central Locking issue
- Replacing rear brake pads?
- Reset airbag
- MB A1937701798 and A1937701898
- Dim Low Beam, Left Side
- Spoiler not closing… Doh!
- Top & spoiler Inop
- AC suddenly blows hot air, any suggestions?
- eletrical issue
- Engine oil, Best
- Tonneau cover locks top down, not top up
- problem convertible top not closing properly
- Dtc 168?
- Parasitic draw
- Audible warning briefly with top down manually
- Need specs on machine screws holding latch mechanism in door.
- Help with broken vacuum tube
- Rcm
- Coolant level warning comes on with headlights
- No Wipers. No Turn Signals. No Entry using Remote
- changing the displayed units
- Key Fob and AntiTheft Alarm not working
- p2040 Reductant air pressure High Input/6 other DTC
- Pulse control module
- ESP intermittently off
- Replacing Brake Switch - removing panel
- Rear glass rubbing
- Code color
- Dashcam wiring through the firewall - path?
- Which 2006 cars immune to "Sticky Key?"
- How to replace fuel tank sender
- Cold Weather & Louder Idling/Acceleration
- 89,000 miles never used premium!
- Engine Bay Relay Module. What is it in charge of?
- Does anyone know where I can get custom electrical modifications?
- Catalytic Converter Going Bad?
- Hood Safety Latch
- Crossfire mechanic available?
- Secondary air injector motor
- OBD port connection
- Starting issue
- Potential upgrades to my '05 limited version
- Intermittent Starter Problem
- Leaving Key in Ignition Switch
- UK 2005 Crossfire automatic no-start
- SKREEM Turn Signal Flasher Relay Issue
- SRT6 P0455 Evap System Leak Detected Large Leak
- Drive train rumble from a stop
- Flutey noise when driving
- Ignition switch won’t turn off
- ECU Troublesoot
- ABS ESP lights and front right brake acting up
- Cylinders #4 & #5 misfire code
- Parasitic Battery Draw
- RE: Another Crank no Fire
- Bad Head Gasket or PCV issue?
- seat
- engine power limiter/spoiler/Odometer/ speedometer
- Central locking vacuum pump not working with key
- Parisitic Battery Drain, TPMS Module
- Top inoperable - where to start?
- No crank no start
- RCM - Question for tighed1
- 2005 crossfire drain / fuse question
- Error code 52 and will not start
- '05 Xfire starting curiosity!
- Won't Start
- Will not accelerate fast and has a sputter
- 722.6 Transmission Fluid & Maintenance
- Replacing battery
- Won't Start
- Tow button Flashing and exterior lights all flashing
- No Airbag Lught - DTC - Implausible Signal in DRBIII
- TPS & BAS ESP Issues
- Airbag Light
- replaced ignition switch but key still sticks in start & cranks no start
- BAS/ESP light and limp mode
- Oil light goes on then off when the oil level is okay
