- crossfire will not start and will shut down while driving
- ODB Reader ELM327 killed battery
- Car tuns over once then dies- New Remote/RCM fix done
- Dash break light on, won't shift all of the time
- Instrument cluster swap
- Need tech advice (intercooler pump)
- AFR gauge
- luz de motor encendida
- Intercooler Pump Question
- P0141 and P0161 Codes
- Master Lighting Switch
- ignition barrel broken today...
- unresponsive gas pedal srt-6 please help
- Throttle Body / Computer Question
- Thanks
- Surging and rough idle with NO check engine light
- Spare Tire
- In Need! My Xfire brothers help is needed!
- Lower Y-Pipe Question
- Hissing Sound from rear!
- engine failure
- Transmission control or safe mode??
- clicking in the rear end
- O2 sensors - which is which?
- Service Code?
- Euro charge problems
- Drivers Side Door Hindge
- Washer reservoir leak?
- '04 Crossfire Surge's
- Supercharger Squeak When Idling
- Misfire codes only when wet
- No engine crank/start
- Idle surging in park. Help Please...
- convertible top wont go down
- Hood problems
- Turn signals, gauge/instrument lights not working
- Replacing head gasket
- ESP pressure sensor 1
- Eurocharged Tune
- CPS and Fuel Pump
- worried about nothing?
- Stereo stop working
- K&N cleaning cone
- Oh this darn car....
- Cold start taking too long - no codes
- That darn BAS ESP light
- How do I get vacuum hoses apart?
- Heat-related misfire issue (P0300, P0302, P0305, etc)... need help!!
- I can't figure it out
- Can anyone please translate/describe what these codes mean?
- Consistent Beeping/Whistling Sound from interior Dash While Driving
- Is my water pump shot?
- Locking system
- O2 Sensor 2005 Crossfire
- interior fan motor won't turn off = runs battery dead
- Newby Questions...
- Suspect bad ignition cylinder
- Replacing ABS Module...I think
- Replace key cylinder housing and housing
- Radiator fan module problem
- 2005 Red Xfire -20 weeks with dealer
- NA Misfires, shudders, stalls
- Car died!?! HELP?!
- dead battery
- Got a bit of money to spare, investment?
- Automatic shifter assembly problem or is it the transmission connector plate
- Unplugging BCM..
- engine shuts off - oil in tail pipes
- how to install the wavetrac
- Radio powers on but no sound?
- Need an exorcist
- Houston Repair Shop wanted
- Headlights
- '04 crossfire no crank issues
- Service indicator on ODO screen?
- Engine Light Code?
- Serpentine Belt Tensioner. Gas Strut or Clock Spring?
- Interior Door Pull Handle Repair/Retrofit with Pics
- Top Hydraulic Fluid leak
- What is this??
- Transmission cooler lines hooked to lower radiator area?
- New air filters - hiccup at 2,800 rpm
- Error Code P0303 Help
- Temp control problem
- Yet Another Engine Ticking Question
- Brake Light and Propshaft problems
- Power Top control module PN 5104947AA
- A newb question from a veteran...
- Tcm
- No Crank '04 Crossfire
- Car shudders
- Power Steering Pump Differences
- Crank, start, die. Crank, start, die. No Crank. The SKREEM!
- Very Loud Continuous Beep
- First Performance Mod
- A new one for me?
- electrical Gremlin- Roof/spoiler flashing light issue again
- Possible Skreem Module?
- FYI - Water Pumps
- Horsepower
- Performance module
- tcu
- Hard cold starting
- crossfire manual? no haynes, chilton only online?
- Fuel Pump Questions
- Oil filter seal...
- '04 crossfire
- Has anyone gotten the "light out indicator" after installing HID's?
- No start, no electrical, NOTHING
- CAN BUS - Learning ...
- Fuel Filters
- 2004 Crossfire/Charging
- P0140 codes
- TPMS problem
- Warning Light for Lights
- Throttle
- Eurocharged regrets
- My P0410 secondary air code fix
- Replacing Gauge BackLights
- Automatic Tanny Question
- 181mm vs. 185mm
- Question Regarding Skicky Key Fix
- Heat stays on
- Skreem part number?
- Help!! RI Xfire experienced technician/mechanic
- Crossfire Engine Knock at Low Idle
- Intermittent radiator fan
- Spark Plugs
- Alarm randomly goes off.
- 15 weeks problem shooting and no repair
- If RCM goes bad away from home.
- Windshield Washer Pump
- ESP/BAS, ABS and CEL lights
- intercooler leaking
- Clarify symptoms - RCM, CPS, SKREEM
- Remote locking problem
- Serpentine belt will not tighten
- Driver's Window
- OBD-II DTC Codes inc 2xxx and higher
- Car Alarm Not Deactivating and No Start-Help!
- new battery fixed radio
- dead
- Rear Spoiler - Not opening fully
- Sticky Key Fix Cost
- Clunking Noise From Parcel Shelf Area
- Lean Mixture codes
- Nv3550
- "passing blinker" mod
- 3rd Brake light not working
- Key will not turn when inserted in ignition
- Top will not go down/up
- Alarm Dis-abling Starting my car
- Getting to know the "Silver Streak"
- Hum/Vibration in Pedals @ 44-46mph
- Turbo/Blower kit for 2004 Crossfire?
- Air Foil Problem
- Replacing my RCM/air injection issues
- radiator fan woes
- top will not close
- barra hidraulico capo
- Mis fire all cylinders
- My turn, no start
- problema cierre llave
- blower motor replacement
- Central locking system doesnt work with key
- Key Fob Issue
- intermitentes
- SRT6 supercharger is cutting out
- SRT 6 Roadster 2005 ENGINE LOCKUP!
- Crossfire Heater Blower On / Off / On / Off
- After resealing breather valves, will not fire
- P0410 secondary air injection
- Aerogel CAI wrap
- Radio problem
- cierre centralizado
- Check engine light
- No brakes!
- problem
- ~161k miles - Idle concern
- Can low transmission fluid cause check engine to light up?
- mods install
- Auto transmission issues
- Possible blown gasket? Need help plz
- airbag light
- Strange Issue - Likely vacuum related.
- Thoughts on Preventive Breakdown
- Valve Cover Gaskets + Oil Separator Reseal Repair Question from Newbie
- How do I unlock this connector...
- tpms light
- Pass door glass stuck in down position...
- Leaking A/C compressor, probably
- Oil light on
- Dashdaq PC
- code 3 stacked
- [2004 3.2 M112] Cylinder numeration
- Flashing Lights!!! Help!
- heated seats
- Tranny Leak from "Case Connector"
- Pulse Module or SCREEM?
- BAS/ESP light
- Ever run your gas tank this far empty?
- I think it's too full...
- anyone know the size of these fittings?
- all diff. and pinion OEM part numbers
- What would cause this?
- Heater/AC issue resistor did not fix...
- Relay specs re Check Engine Light
- J.j.
- Car won't pass safety/emissions - P0171 / p0171 System too Lean?
- Engine Management Light and Relay burnt out
- OBD readings not fault codes
- continuous vent airflow?
- interior lights
- Dash light replacement
- Differential rebuild
- 90mm Throttle Body
- Sprint Booster
- Ticking and Wrench - 2 on Display
- Headlight adjustment problem
- My dealership is useless!
- Possible SKREEM module... cont. from another thread
- SRT6 bogging down and heavy gas smell
- Help: Wire broken behind upper console!
- Would not start
- How to remove BELT TENSIONER
- Spoiler Won't stay down
- Steering box adjustment?
- Loud engine after clutch replacement ??
- Car starts twice, dies twice. Skreem module again?
- What to check out
- Help help help
- headlight please help
- Windshield wiper issues
- my 2004 loss of power
- Malfunction Indicator Light
- Radio not working
- please help
- Gas Pedal resistive and stiff
- fan/rcm problem please help!
- Spoiler light flashing.
- Multiple issues after jumping a battery mishap
- TPMS and braking
- Air bag light
- Sticky accelerator
- 2004 MT Will Not Roll Over
- How things work
- Lower Control Arm Bushing
- Pulling to the left when driving
- Battery Problems?
- Transmission 6 Speed Stick clunk sound into second gear
