PDA
View Full Version : Engine, Exhaust, Transmission and Differential
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14
  1. Where can i get a tune up done for my car?
  2. Oil Leak!!!
  3. Cooling system sacrilege
  4. low coolant light comes on and off.
  5. crossfire data display
  6. X-Pipe I.D.
  7. Show off your Engine Bay!
  8. Do K&N AIR FILTERS do more harm then good
  9. question 74mm TB
  10. Secondary air pump part number
  11. Anybody have black crinkle valve covers?
  12. Quick SC Pulley ?
  13. Under My Hood Pics...
  14. Going from flowmaster 44 to stock?
  15. Cps
  16. good dealer Atlanta area
  17. Fuel Rail Inlet Fitting
  18. NA Engine Stuttering
  19. Air injection pump check valve
  20. Replacement drive belt for NA $11.00 + ship ck out srt belt
  21. P0300 codes, but no CEL
  22. Where to buy 74mm Throttle Body Upgrade
  23. n/a MAF upper bracket
  24. Are ANSA mufflers still avalible
  25. Noisey pulley
  26. Idler pulley
  27. Idler pulley
  28. Pulley
  29. car wont start
  30. Headers, I mean jewelry, arrived
  31. Powdercoated Engine Parts...Sneak Peek
  32. Engine blocks? Srt6 and n/a
  33. Valve cover ports
  34. non start and cutting out
  35. Took off my Manifold Covers tonight and its not good...
  36. Megan racing exhuast
  37. New Longhorn Unrestricted DCAI
  38. hello new member and non start
  39. Powdercoating Under The Hood Need Suggestions...
  40. How to take off Valve Covers and Manifiold Covers???
  41. crossfire engine problem
  42. Got Nitrous?
  43. Temperature Guage
  44. Blower from C230
  45. Cutout Volume
  46. Attention! Anyone thinking of a V8 conversion
  47. valve cover leak
  48. I think the dealer lied to me.
  49. Leakey coolant reservoir!!
  50. Full Engine Spec Sheet Hose & Part List
  51. New toy Monday...
  52. mobile one
  53. Received really bad advice!
  54. Good buy on Torx tool set
  55. Water pump failure?
  56. Found this buy for N/A belt/pulleys
  57. supercharge or turbo ?
  58. It had to happen. My girls first breakdown...
  59. lysholm style charges mounted upside down?
  60. Stuttering between 1500-2000 Fuel pump?
  61. O2 sensor help plz!!1
  62. X-Pipe Size
  63. megan m-rs
  64. Happy New Year!!!
  65. OFF TOPIC...Premium Question?
  66. high idle after intake manis reinstalled???
  67. Cold Start Dies
  68. 3.7l engine discussion - swap?
  69. Engine hesitation when you hit a bump
  70. Pentastar V6 bolts to out 6spd.
  71. Trans fluid level - automatic
  72. Supercharger and pulley bearings
  73. Chrome Chrysler wing emblem on srt6 air cleaner
  74. LPW and Eurocharged Tunes?
  75. Big Johnson bites the bullet
  76. water pump question
  77. cold air intake ideas
  78. headers?
  79. 2004 SRT6 Limited Six Speed
  80. Best Spark Plugs and Wires for modded SRT6
  81. Intercooler replacement tips, anyone?
  82. Expensive crossfire lesson
  83. Turbo-New ideas & input
  84. OBX n/a exhaust
  85. Exhaust material
  86. Injectors
  87. Won't read code
  88. need new Battery/ Autocraft Gold H6 48
  89. true dual exhaust help
  90. Mass air flow
  91. White exhaust smoke normal?
  92. c350 intake tubes???
  93. EGT sensor for zt-2, what's your thoughts?
  94. DCAI and 62mm SC pulley installed finally
  95. Car driving me nuts
  96. ignition fault
  97. Codes
  98. code P0172
  99. New battery installed and...
  100. cars bogs
  101. Strange automatic gearbox characteristic in 05 Limited?
  102. Camshaft Sensor
  103. Crankshaft Sensor Again???
  104. Need help
  105. Engine Swap #2
  106. engine mount help needed
  107. Aluminium Flywheel
  108. Strange Wine from Engine
  109. My air filter
  110. Can you super charge a n/a crossfire?
  111. Borla or Magnaflow
  112. Tensioner and Idler puller question
  113. electric supercharger
  114. Louder Engine Noise
  115. Catalytic converters
  116. Official N/A Gains Thread
  117. mobil 1 5.49 2 wipers buy 1 get 1 free
  118. Rear cat and Resenator delete and X pipe swap
  119. Oil Catch Can and cleaner tips...
  120. Nitrous
  121. Getting ready to do my first oil and filter change. Any recomendations on products
  122. Need info on lowering an NA
  123. Magnaflow Inspection
  124. oil catch can & crank case vents
  125. Turbo Charging a XF Limited?
  126. Battery Light comes on when I accelerate
  127. I don't really know what else to do ...
  128. installing Rob's catch can, where does this hose go?
  129. v/8
  130. oil filler tube base gasket
  131. Engine Question
  132. Help looking for post on the v8 hemi swap
  133. Looking for after-market resource
  134. I screwed up!
  135. Napa joined in
  136. how to replace spark plugs
  137. SRT-6 Supercharger noise
  138. Letterbox exhaust vs Dual
  139. Has anyone ever found the reason for the 5th "O" ring in some of the filter kits?
  140. Coolant that will work with OEM Coolant
  141. P0412 code
  142. ? stock SRT6 air system on an NA?
  143. 25% off on brakes/batteries at Advance Auto
  144. Mobil 1 Oil plus Mobil 1 filter
  145. Mobil 1 filter vs. Mann filter vs. Purolator filter
  146. What do I need ... Looking to return to OEM intake, from NEEDSWINGS
  147. Methanol Injection
  148. Crankshaft Position Sensore cable/harness
  149. What's the right PSK
  150. bouncing between gears? '05 auto ltd cpe
  151. Anyone need a used engine?
  152. Noise near alternator/pulley? Goes away after on hour of running
  153. E37, Manual?
  154. Diagnostic Port
  155. Help with logs, how lean does this look?
  156. If anybody can help me please !
  157. Car Keeps CRANKING but Does NOT START
  158. Dashdaq - How to Calculate Injector Duty Cycle?
  159. Engine Smoking
  160. Aftermarket Exhaust tips (pictures) thread
  161. Muffler free
  162. Gas
  163. What is the best exhaust to get for a Crossfire?
  164. Modifications needed on the MB Engine Cover?
  165. LTB 74mm TB & 3in MAF
  166. Rear Cats Removed/Awesome sound
  167. Topping off the oil?
  168. Shaky engine
  169. noise under car??? trans/cat???
  170. Dual Ansa exhaust coming
  171. 320 Log Header Project
  172. Shopping for a SRT6 supercharger pulley
  173. SLK32 Performance Questions
  174. Crank Shaft Pulley-Misfire Issue-Help
  175. dual cai vs cai
  176. No Start Persistent - D. I. G.
  177. Oil warning light / odometer missing?
  178. 'Thunk' when engaging clutch at low RPM in first gear?
  179. A brief history of octane
  180. BEGi Turbo Kit information/discussion thread
  181. Engine Swap Question
  182. "04" crossfire stalls when warmed up
  183. vibrating shifter above 75mph
  184. Installed Johnson CM30 Pump / What triggers pumpt to come on??
  185. Just ordered my Megan Racing M-RS muffler
  186. Tappet noise, intermittent idle miss, rough shut-down
  187. Sprint Booster Special!
  188. '04 crossfire w/ 80,000 miles, has lifter noise
  189. Safe to removal under hood insulation?
  190. Oil filters $8.50 each if u hurry!
  191. Replace the Crankshaft Position Sensor now??
  192. Alcohol/water injection on NA
  193. best exhaust for the roadster
  194. Drive shaft flexible disc
  195. Lambo style exhaust
  196. Need some suggestions
  197. P0400 Help Needed
  198. EVA monitor will not reset!
  199. Gas usage!
  200. Anyone Find A Remote Start System For Crossfires?
  201. Rear Cats Delete Pics
  202. First engine troubleshooting question!
  203. magnaflow price increase on the 14th
  204. Awesome! Video inside!
  205. cats on the fritz again!
  206. P0335 Code with no MIL but won't clear
  207. Issue after Descreened MAF/Debaffled Elbow
  208. PO335, replaced Cam & Crank sensor PO335 code remains
  209. Does anyone know what Mercedes engines can be used in a crossfire?
  210. multiple engine codes popped up at 1 time
  211. Custom Exhaust
  212. 0W40+filter SALE 32.99 advance auto ends may 30
  213. TVT Design
  214. Dream Car Wont Start - Tears Tears Tears
  215. MANN fleece at Advance
  216. Supercharger problems
  217. Where to get bigger Injectors?
  218. Beginning of the mods
  219. Want more HP
  220. N/A crossfire hp figures.
  221. low temp thermostat?
  222. Cheap exhaust
  223. i need someone from nyc area's help
  224. New Process Engine
  225. Where to get 74mm TB ONLY?
  226. Aluminum Idler pulley, Belt Tensioner Pulley
  227. Intercooler
  228. Powered by Renntech?
  229. Do you need an oil change in Cincinnati?
  230. My modded engine cover
  231. Oil consumption?
  232. Does a new Air Filter = better mpg's?
  233. Painting my engine cover
  234. what's the difference sae >> sae1 oil (HELP)
  235. TB boring
  236. How can I swap my engine for a SRT-6 Engine?
  237. AEM Wideband sensor question
  238. Air Filter - which way does it go in?
  239. Voices in My Head
  240. going a little insane with my exhaust
  241. Gremlins again!
  242. Airbag warning indicator lamp is on!
  243. Spark plug cross-reference...
  244. I need info on motor swaps for my XFire
  245. Latest MB 229.3 & 229.5 approved oils!
  246. Temp problem
  247. Temp needle going too high?
  248. Ultimate XF engne swap
  249. 154 MPH ampient temp 86
  250. SL-55 Nightmare... Install pointers??
