PDA
View Full Version : Engine, Exhaust, Transmission and Differential
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14
  1. What kind of exhaust system do you have?
  2. CAI and Extended Warranty
  3. Installing Gauges, need help!
  4. Mercedes
  5. Another step finished for the c320 Airbox
  6. Catalyst Chrysler Crossfire 3.2i Coupe
  7. Installed Megan Racing Exhaust
  8. Using E-85 as an octane booster...(mixing with E-85)
  9. Custom Exhaust
  10. Mobil 1 OW40
  11. Engine Cover Overlays ???
  12. Max Supercharger RPM's
  13. N1 Carbon Exhaust Muffler
  14. Megan Racing Exhaust Question...
  15. MB airbox painted and installed. Awesome!
  16. Programmer Question
  17. Bad Check Engine Code Question
  18. Head Gaskets and Head Studs
  19. Gutted stock NA muffler
  20. New cat-back system... kinda
  21. PO171 code
  22. Mobil 1 Sale!
  23. ansa silverline
  24. Oil Catch Can Questions
  25. Eeeek... something is wobbling in my engine compartment!
  26. 30% off
  27. Headers?
  28. 6000 RPM REV limiter?
  29. Cold Air Intakes
  30. Dyno tuning
  31. My SRT6 hit 6500 RPM today... and I'm freaked out
  32. Boring out stock n/a throttle body
  33. 30% off Magnaflow and Flowmaster exhaust at Amazon
  34. oil change sale at autozone
  35. High Miles and ohh so dirty
  36. Help, Engine revs on it's own...
  37. Has anyone ever cut open a stock NA muffler?
  38. 5.7L or 6.1L Hemi Trans.
  39. Battery
  40. Oil leak problem Question
  41. SRT-6 Cams & Exhaust
  42. Resonator Removal Price
  43. Mods begin
  44. Recirc Cover - broken bolt. Please help!
  45. New intake installed... it ROCKS!!!
  46. A fresh approach for some fresh air
  47. BEANER - More pixs please
  48. tb installation help
  49. Dyno tune/Crossfire Guru in SoCal?
  50. Amazon and Exhausts
  51. Redline Water Wetter - Coolant Additive
  52. Lucas Upper Cylinder Lube / Fuel Treatment
  53. Primary Cat Removal
  54. Mobil one 0/40 and filter $29.99 Autozone
  55. PO100 Mass Air Flow / Check Engine Light
  56. Coolant/radiator help please!!!
  57. Endorsement for Mobile 1 0-W40
  58. Fuel Filter
  59. crazy throttle sticking to red line
  60. Rough Idle, car stalling, check engine light, multiple cylinder misfire :(
  61. OK...simple cry for help!! I want a muffler
  62. Spark Plugs Longevity
  63. crazzy throttle sticking to red line
  64. Car start/check engine light incident
  65. 6.1 L Crossfire??
  66. Water Pump Gone Bad
  67. Low RPM Cough
  68. Mass airflow sensor gasket
  69. Magnaflow Exhaust from Needswings.
  70. Exhaust Q
  71. Part Number for Engine Splash Shield?
  72. Check this out
  73. STS turbo
  74. A little help
  75. ALMOST dead cruise control
  76. High ringing noise when I let off the gas??
  77. Fleece oil filters $10.20 mobil 1 $5.79 1 day only
  78. E3 Spark plugs
  79. ANSA muffler
  80. Platinum Spark Plugs
  81. Walmart has Fram oil filters
  82. $14.00 OFF Mobil one oil change
  83. new battery
  84. Possible deal on Mobil 1
  85. The X Factor!
  86. Muffler, tint, intake questions
  87. Another "lifter tick" thread, with a twist
  88. MPG with K&N
  89. Fss -500
  90. O2 Sensor Replacement
  91. New muffler causing cat. converter problems?
  92. The truth about "ram air"
  93. Powdercoating valve covers... opinions on finish
  94. Valve cover gaskets from hell
  95. Modified Engine Cover
  96. Oil Cooler faq
  97. What's normal for IAT's
  98. Just ordered my NW CAI
  99. MB upgrade maf and such for Xfire
  100. New Spark plugs, New car!
  101. Cold air intake
  102. Quieter Magnaflow
  103. Eurocharged Coming to Las Vegas and Tampa, FL
  104. Smog check in Cali
  105. SRT6-Bearing Noise-Rattlin Sound?
  106. Jungle Juice
  107. Under engine pan
  108. Exhaust "
  109. Anyone used an A1 Cardone Mass Airflow Sensor?
  110. apollo cai
  111. maf cleaning
  112. Put the new parts on
  113. EGR and air pump deletion
  114. 181 components
  115. MAF for XF's???
  116. Installing Needswings CAI
  117. New Mercedes C320 engine cover and intake tubes from TVT!
  118. White smoke with new muffler
  119. Tips needed...
  120. Just installed 74mm Throttle Body
  121. Is E85 Better?
  122. Trouble from fuel stabilizer?
  123. Got my Ansa today
  124. More HP WANTED
  125. Only in America!
  126. Update: Living with the V8 Crossfire
  127. 181 pulley cad drawing?
  128. Kleemann supercharger
  129. Needswings cai finished
  130. Megan Racing M-RS Exhaust
  131. Crossfire NA engine - Mercedes engine #
  132. NA tune
  133. Hesitation?
  134. nw cai+74mm tb
  135. Does Anybody Know What Bas Esp On The Dashboard?
  136. Installing oil pressure gauge...
  137. Hood Liner
  138. oil leak??
  139. quick ? about using a jack on my car
  140. Minus one muffler
  141. Fully Electric Crossfire
  142. 74mm throttle body
  143. MB Engine Cover Will this Fit
  144. Nitrous
  145. Nitrous
  146. Exhaust damage due to Rearend Accident
  147. What is spray?
  148. A/C compressor pulley
  149. Header options?
  150. Removing Res and Muffler
  151. Ansa Ansa Ansa! Does anyone want the Ansa! Well here is the question...
  152. Accelerator pedal
  153. e500 or sl55 intake system
  154. areo turbine muffler + dual amg exhuast tip ?
  155. brabus exhaust tips ?
  156. Oil Pressure Gauge
  157. Exhaust tips
  158. correction...
  159. oil consumption
  160. megan muffler cheap sounds good
  161. Mobil one 3.98 QT
  162. Adding the SRT6 SC to a limited 3.2L?
  163. NOS Nitrous Direct Port V6 EFI Injection Kit NOS-08006NOS
  164. IAT sensor for SRT6
  165. body control module issues...
  166. nitrous
  167. Oil capacity question
  168. Sparkplugs
  169. Replace muffler with resonator
  170. Anyone wanting to sell their stock exhaust?
  171. Cold Air Intake Any Difference?
  172. Needswing Cai
  173. stage 2 manie
  174. N/A parts
  175. Valve cover leak...
  176. Exhaust in Gary's area?
  177. SRT6 factory intake
  178. SLK 320 motor engine mount the same?
  179. Rear cats delete?
  180. oil on serpentine belt
  181. OBD-II Scan Codes PO172 and 175
  182. Check Engine light and Vibration from engine.
  183. Stock Exhaust available
  184. Exhaust Question!
  185. SC retrofit for serious boost
  186. Gas without Ethanol
  187. Hood Liner
  188. Engine Start Button
  189. Downshifting into neutral
  190. Exhaust Manifold Interchangable?
  191. DYNO 354 rwhp SRT6 Eurcharged video/sound
  192. Black smog and 1 miter of fire From exhaust
  193. Replacing the air filter.. does it really take two of them?
  194. Hissing sound coming from engine bay
  195. Knock getting worse
  196. Another Engine Noise
  197. Turbo
  198. Ansa Muffler for Crossfire - Group Buy
  199. Check engine check?
  200. vrp throttle body
  201. Alternator bolt loose???
  202. Srt Resonator
  203. 3.2L engine
  204. 2004 Crossfire Front Engine Oil Leak
  205. Good, Inexpensive OEM Fleece Oil Filter
  206. Exhaust collage
  207. TVT265 CAI Air Box question
  208. Mb 320 Intake
  209. Magnaflow 16633 buttoned up again...and still lovin' it. (with video)
  210. InMotion or LET Tune poll
  211. Install
  212. Nos purge
  213. Headers For The N/A
  214. let stage 3 and headers
  215. let stage 3. and headers
  216. Please Help
  217. Stall speed
  218. Thermal Coatings and Dispersants
  219. Mods
  220. Nos
  221. Whats next
  222. Cheapest place to buy case of 0W-40
  223. Oil filter - paper vs. fiberglass / fleece
  224. Are their any california smog legal exhausts?
  225. New Exhaust w/ pics and video!
  226. needswings
  227. Needswings
  228. Help - engine dies... while driving!
  229. Ecu tune
  230. Ported intake manifold
  231. Race Only Exhaust
  232. TVT, I was browsing the Startech catalog. While don't you just steal it?
  233. Intake
  234. Disappearing Oil
  235. V8 Crossfire in Florida?
  236. dual tvt cai
  237. NA camshaft Preliminary buy
  238. Magnaflow 16633 system
  239. Stock CAI intake tube improvement?
  240. Slow acceleration after new plugs and wires
  241. Exhaust Humming Sound - Just After Starting Up
  242. New MB Cover Stainless add ons
  243. My car is in fire
  244. NW CAI installed on my SRT
  245. Dual CAI for the NA
  246. Coolant
  247. 2004 chrysler crossfire coolant light problem.
  248. Check Engine Light Code P2023
  249. Heads installed and some first impressions of driving
  250. Oil change parts needed
