PDA
View Full Version : Engine, Exhaust, Transmission and Differential
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14
  1. 2004 Transmission/Starting Issue Help Needed
  2. Resealing valve cover vents in cold weather?
  3. Part number 5098310AB. RUBBER CUSHION ENGINE MOUNTS
  4. Part Numbers
  5. Exhaust upgrade
  6. I finally changed my plugs after 203,000 miles.
  7. Transmission Fluid - What to use?
  8. Valve covers
  9. 64mm S/C pulley bearing
  10. Cheap(er) NGK sparkplugs
  11. Gearbox
  12. Transmission harness connector leak
  13. Do we have cold air or hot air intakes?
  14. question about mixing synthetics w/mt??
  15. 6 speed trans locked up?
  16. Need camshaft/crankshaft part numbers PLEASE
  17. Burning smell in 1st gear
  18. Intermittently not starting
  19. Clutch pilot bearing
  20. Clunk noise when shifting P R N D
  21. V8 Conversion
  22. Newbie, need help !
  23. Rubbery clutch to no clutch
  24. Raw fuel coming out of evap canister tube
  25. Change oil and reseting the service alarm DIY
  26. Clunk pressing in clutch while in first.
  27. Replacing the Fuel Pump and Filter
  28. Driveshaft length
  29. No start
  30. No power to Starter/ nothing
  31. Please help me identify a part
  32. 78mm TB
  33. Drone With New Megan Exhaust
  34. Shift kit
  35. Need help with Idler pulley
  36. Radiator fan not coming on?
  37. Engine starts and stops after a few seconds
  38. Crankshaft Position Sensor
  39. Vacuum reading vs Torque Pro
  40. V8 Conversion
  41. Engine throwing trouble code
  42. SRT 6 - Transmission stuck in gear P0715
  43. Center Bearing hanger replacement instructions available?
  44. Bad Service
  45. Differential Noise
  46. My '04 crossfire keeps dying help please
  47. No start '04 crossfire
  48. AC/Coolant/Radiator Combo HELP
  49. Suggestions on where to go for a fluid flush?
  50. Auto shifting issues
  51. Spare Mercedes TCM for Crossfire ???
  52. Backfire
  53. Cylinder Misfire Help
  54. Highest HP NA?
  55. Car cranks, stumbles for a second, then dies
  56. 2004 crossfire coupe
  57. Crossfire NA engine
  58. Fuel Filter Issue or ?
  59. Propshaft centre bearing rubber burst UK
  60. Used TCM Fixed Transmission Issue
  61. Which Cylinder is #3?
  62. Mann Oil filters?
  63. Megan MRS vs. Megan Mdf exhaust
  64. Car wont start. Please help.
  65. Do I need a new flywheel?
  66. Tranny Troubles
  67. studebaker57
  68. Oil sensor question.
  69. "Temporary" muffler Delete
  70. swapped diff in less than one hour
  71. Swap srt6 motor into a limited? Is it still a problem?
  72. Change TB
  73. 2005 Auto Trans
  74. Video from "new" exhaust
  75. Crossfire won't reset throttle response
  76. 200k
  77. Oil pressure gauge
  78. Oil temp gauge
  79. Soft Brake problem
  80. Differential Issue and Solution
  81. Engine changed 2/4/2004. What changed?
  82. Map Sensor
  83. Clutch Pedal bounces
  84. Looking at a crossfire for 55k swap
  85. 6 speed manual transmission
  86. '04 crossfire
  87. Axles, driveshaft / the difference limited to srt
  88. SRT Trans and diff Questions
  89. Oil leak
  90. OBD II Info while driving
  91. how to start engine outside of car
  92. Fuel filter Replacement and B service
  93. Transmission issue
  94. Crankshaft Position Sensor/Wiring Harness Problem
  95. Fuel lines
  96. Major Fault Need Help
  97. blower motor won't shut off leads to no start
  98. Transmission Help/Limp Mode HELP
  99. Car Repair and Maintenance
  100. Mystery part ?????
  101. engine stalls on acceleration
  102. Clicking sound
  103. Microlon engine treatment
  104. 2015 SRT 6 rough start
  105. !st gear popping out
  106. auto box problem
  107. Mass air flow sensor problem
  108. Rear cat delete only on NA
  109. Clutch pedal travel
  110. Clutch pedal travel
  111. Best order for engine removal
  112. Engine
  113. auto box changing to soon
  114. Radiator HELP
  115. Correct coil for '07 Crossfire Limited
  116. Shifter allergic to water ?
  117. Tuning?
  118. Crank to Flywheel Problems
  119. Supercharger repair question
  120. Approaching 200,000
  121. Installing Intercooler Pump
  122. rough running
  123. Transmission problem?
  124. Need help with hose clamp removal (to throttle body)
  125. Replacing bearing on tensioner pulley
  126. Intermittent power
  127. Momentary power loss at specific RPMs only when cold
  128. slk320 rear end into Crossfire ?
  129. Mercedes 272 engine.
  130. Differential Noise?
  131. Error code P2096 and P2099
  132. W/S Transmission Switch
  133. Horsepower rating for stock tranny in limited
  134. Cold air intake by Kai
  135. Innovative Performance Chip
  136. Air flow sensor to engine cover gasket
  137. Oil Level Sensor/Lower oil Pan Question
  138. Rear suspension bump
  139. Spark Plug Recommendation
  140. Differential ratio
  141. 2004 crossfire starting issue
  142. Secondary cat delete concerns
  143. Downpipes installation
  144. Oil change extractor
  145. Motor Noise
  146. Broker breather cover bolt in valve cover
  147. 2005 transmission problems
  148. Part number for passenger side breather cover hose too air intake
  149. Headers
  150. Swap C32 into E32 (SRT supercharged into NA car)
  151. New source for Bosch CPS
  152. Need mechanic in Orange county
  153. Ansa/after market muffler advise
  154. Please help! Possible coolant leak
  155. 3 3/8" aluminum Y-Pipe
  156. hot restart problem
  157. Megan Racing Exhaust
  158. water pump
  159. E55amg
  160. Oil leaking out of filter housing
  161. Advanced TB Mods?
  162. Advice On How To Move Forward with My Crossfire
  163. Throwing codes but OBD II not reading
  164. Guibo, flex coupling part number
  165. Alternator
  166. Throwing Codes
  167. Valve cover leak
  168. Speed sensor "A' code P0501
  169. Hard shift into 3rd gear...
  170. Water pump part comparison
  171. Starter Bolt Size and type.
  172. NA Muffler rubber bumper stop question
  173. RennTech pulley and ECU kit
  174. 2004 Auto Coupe Transmission 'Clunk' - Any ideas?
  175. interior ringing noise when releasing throttle
  176. Desperate Help Needed!!!
  177. Mercedes engine cover
  178. Part needed for brake / clutch pedal
  179. Exhaust Opinions
  180. Wont go over 4,300 rpm
  181. 2 step
  182. Car came with usb and OBD II cable
  183. Fuel Injector Seal
  184. Fuel line
  185. AIR INTAKE PIPE - Keeping disconnecting...
  186. Differential swap
  187. Intake Manifold Gasket
  188. Automatic gearbox does not shift up unless I let off the gas - any ideas?
  189. Oil Feed Tubes
  190. DIY Transmission Fluid Service Temp Check
  191. oil pressure notification
  192. Replacement flywheel for 2004 coupe
  193. What RPM is best shiftpoint - manual 6 speed
  194. Pierburg CWA50 chargecooler water pump
  195. Baked potato: long term reviews
  196. Intake Manifold, egr & crankcase breather
  197. spark plugs
  198. Finished "Sport Mode" exhaust cutouts 3" on Magnaflow cat back
  199. SRT6 Throttle Body Gasket / Spacer
  200. Transmission leak
  201. Fluids the Life Blood
  202. Oil leak /what is this part?!?
  203. regular 3.2l v6 engine vs the sc 3.2l v6 engine
  204. Oil drain plug removal
  205. Fuel rail test port on srt-6 supercharged engine
  206. Pulley shaft ?
  207. Smog/Air Pump Replacement
  208. Need Help!! Stranded
  209. Decat
  210. Relay Control Module
  211. Need the complete ignition key
  212. Transmission pan gasket leaking
  213. Driveshaft Flex Joint
  214. Auto transmission dip stick - 48" long
  215. Aeroturbine Muffler
  216. Universal Cold Air Intake (DIY)
  217. Bad Oil Leak
  218. dual exhaust need pics
  219. NGK (4696) IFR5D10 Spark Plugs
  220. Upper radiator hose NA models
  221. Needswings Oil Catch Can
  222. BEGi Turbo Crossfire - Final Thread!
  223. Dual Intake?
  224. Snapped the bolt on my transmission connector adapter
  225. Has Your car ever shot flames?
  226. Crossfire 6 Speed Gear box rattle??
  227. Car shuts off
  228. High Idle
  229. Passenger side fuse box
  230. Remapping Superchips
  231. Snapped an intake manifold bolt... argh
  232. AWESOME reading on 'Batteries'.
  233. SRT6 supercharger question
  234. Anybody tried these mufflers?
  235. Supercharger
  236. Coolant Flush Question
  237. Skreem programming
  238. Wiring... help!
  239. Map Sensor changing
  240. boost / vacuum gauge installation
  241. Exhaust Help
  242. Transmission Level Before Driving
  243. Differential service interval?
  244. Blue smoke on startup after sitting
  245. carbureted v8 swap?
  246. exhaust pipe flow (pressures)
  247. Finding Fumes from Below
  248. Need info removing center driveshaft bearing
  249. p0140 Careful when removing hoses!!!
  250. Engine fan still running high...please help!
