PDA
View Full Version : Engine, Exhaust, Transmission and Differential
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14
  1. CAI for 2004 Coupe
  2. MAF part number
  3. Water Pump Replacement
  4. Generic Turbo possible?
  5. Needwings Engine cover
  6. Anyone lose their tune?
  7. Intercooler Dimensions?
  8. NA Autostick jumping gears. Worn?
  9. Needswings dual SRT-6
  10. Engine Oil additives - a good thing?
  11. Needwings IC and DCAI
  12. PepBoys: Another Mobil1 Special
  13. Auto Zone oil change special
  14. Oil Change Interval
  15. New age snake oil???
  16. O'Reilly's Mobil 1 Sale
  17. na rear cat delete?
  18. UPsolute Tune
  19. Car stalled! Fuel Filter & Pump parts number needed!
  20. New cold air intake on my Limited
  21. Mercedes Engine Cover Mods and 74 mm Throttle Body
  22. K&N Filters For Merc Engine Cover
  23. What do I do for supercharger?
  24. how to adjust exhaust tip
  25. turbo kit t3 t4 on crossfire limited
  26. Ansa Muffler
  27. kool vue muffler
  28. Dual CAI vs Single CAI
  29. Turbo the V8 - your car could be next!
  30. Catalytic Convertor Issues - Help Please!
  31. srt resonator delete??? opinions please
  32. Modifications
  33. 185mm crank pulley
  34. got code p0562
  35. CV Boot vs. SRT-6 Exhaust Gas
  36. swap a srt6 engine and trans in an NA coupe
  37. This always happens... Oil catch can install
  38. Future Engine Swap?
  39. Needswing CAI For Sale almost new $325
  40. Exhaust leak?
  41. exhaust question and help
  42. oxygen sensor problem
  43. RPM Help
  44. Does this look right?
  45. Need your help with cushion, engine support
  46. How to remove tensioner pulley for PSK install?
  47. New Needswings Single CAI Installation
  48. Srt-6 graphite roadster exhaust
  49. feb 19 tune/dyno day/ft lauderdale/davie
  50. New Megan Racing M-RS Muffler! Pics inside!!
  51. Custom Exhaust Shops in Maryland?
  52. Newbie type questions
  53. Engine Diagnosis
  54. Screwed over by Meineke! Help!!!
  55. High pitched squeel when warm?
  56. HydroGraphics... Awesome Stuff
  57. where can i get i get a supercharger
  58. Help S.o.s Click Here!
  59. Another satisfied Eurocharged customer!
  60. Need Advice BAD!
  61. installed eurocharged 181 pulley, car won't start
  62. Vote for A or B letters will be chrome
  63. P0120 Code... need help
  64. Needswings CAI.
  65. Automatic Transmission + Cold Weather
  66. Normal engine rpm
  67. Premium or Regular Gas...Which r u using??
  68. Question for Megan M-RS owners
  69. Transmission
  70. Ansa Muffler - CA Compliant?
  71. Question about atomatic transmission
  72. air filter 208 Coupe/Cabriolet 1998-2003 CLK
  73. Bosch IC pump part number?
  74. Roadster with Magnaflow 14805 exhaust
  75. help
  76. tensioner #9 chattering
  77. Eurocharge on the East Coast!
  78. Pulled the plugs
  79. Mobil One Sale
  80. Engine Noise - Need Your Feedback!!!
  81. How to buy auto obd2 diagnostic scanners
  82. Battery Acid Ate My Line!
  83. I need this part
  84. 2004 Crossfire Limited Automatic , Looking To Add The Srt Supercharger !!
  85. Power Steering Flush
  86. Mobil 1 $4.99/qt at O'Reilly's
  87. A question for the magnaflow owners...
  88. CAI Help
  89. cost of a V8 in your vehicle Crossfire or any mercedes
  90. Needwings downpipes review
  91. I did the ultimate mod for a crossfire (V8)
  92. Exhaust removal hints?
  93. AutoZone Autolite Spark Plug Rebaate
  94. Is this the dreaded intercooler leak?
  95. Air Box Rubber Gasket
  96. Exhaust Setup Idea, Any Experts Out There?
  97. What CAI setup is this?
  98. crossfire air cleaner assembly
  99. Working on Engine/Things - Few Issues - Please Help!
  100. Slow acceleration and cranking issue - Tune Up?
  101. Oops, wrong oil filter maybe?
  102. Valve cover gasket on eBay - Yes/No ?
  103. Eurocharged tune??
  104. Engine disengages after spirited acceleration.
  105. WOW 4.0L SRT-6 ??? 500 hp potential?
  106. Oil
  107. Couple problems - just purchased - need advice!
  108. Mopar Performance Cat Back System?
  109. Scared, could possibly have a radiator problem
  110. RENN TECH Air Box
  111. Thrush 17653 - Thrush Welded Mufflers from Walker
  112. turbo your xfire for cheap!!!
  113. Magnaflow catback price increases on the 1st of the year
  114. Alternator repair
  115. Grill mod?
  116. another small vid
  117. SRT6 power in your NA for $9,250 - That even includes the engine!!!
  118. for those who don't check the srt-6 thread
  119. SL 55 Note
  120. Crossfire takes longer to start then normal
  121. Wanted: Mercedes C320 Airbox
  122. need to find the NEGATIVE injector wires
  123. What intakes / Induction / cone filters do you have?
  124. SRT gurus I need you!
  125. Valve cover seal
  126. Exhaust Options??? Not TOO loud?
  127. Way to test crank sensor?
  128. Anyone know who makes this?
  129. excited about my upgrades!!!
  130. Serious interest in a piston/rod combo?
  131. help transmission leak maybe?
  132. MB Engine cover - eBay - Buy It Now $49
  133. Water pump failure :(
  134. Fuel Pump Relay
  135. Catalyst & O2 not ready
  136. I need some expert advice...
  137. big problem with my xfire, please help
  138. timming
  139. rudy check this out!!!
  140. Needwings CAI and rain?
  141. serpentine belt and small leak
  142. Raising engine idle?
  143. Interesting smell at 100 mph +
  144. Whistling clutch?
  145. Marvel Mystery Oil
  146. '08 vs '07 to '04 oil filter cap/housing dimensions
  147. What are heads worth?
  148. MB Engine cover - eBay
  149. Stupid MAF Question
  150. CAB Module / ABS Pump
  151. Code PO 400
  152. OEM exhaust
  153. Magnaflow Exhaust for sale 2005 crossfire SRT-6 $350
  154. BAS ESP warning light on...
  155. HI Oil Level Alarm
  156. Does this sound like a crank position sensor?
  157. Occasional burning smell when idling or upon turning off
  158. found on ebaymotors
  159. Fuel Question
  160. engine speeds
  161. Engine Replacement
  162. Added some skirts to the rear end
  163. Security computer problems
  164. MB engine cover - ebay
  165. excessive lifter ticking, Help?
  166. I'm building another one... Supercharged V8 Part Deux!!! :D
  167. P0410 and NeedsWings intake
  168. Ansa Muffler - New Inventory Now Available
  169. Needswings Intake
  170. O Ring failure on oil filter housing
  171. Exit lane shuddering
  172. exhaust falling
  173. Stock Exhaust Available
  174. lantana you wanted a key start!!
  175. My fan belt had a baby...
  176. Borla XR-1 Muffler - Anyone ever use it?
  177. Transmission Dip stick
  178. Rhino Ramps for oil chg
  179. Cool air intakes, versus COLD air intakes
  180. MB Airbox on Ebay
  181. "CHECK ENGINE" light
  182. bling lights CAI ?
  183. Engine stalling
  184. cooling fan
  185. SLK/SRT6 engine swap, which one easiest?
  186. For those that gutted an NA muffler?
  187. Fleece Oil Filter Source - ECS Tuning
  188. Throttleboost
  189. Changing Fuel Filter
  190. SRT6 engine, how does it look?
  191. TVT Cold Air Intake vs Needwings vs TVT Ultimate Intake vs Needwings Dual CAI
  192. Noise from alternator
  193. Will this type air box fit?
  194. Help with Megan Racing M-RS
  195. Engine/Gas additives
  196. TVT vs NEEDSWING INTAKE vs K@N
  197. Storing my x-fire
  198. Fudging on oil intervals might not be so bad...
  199. Change Spark Plugs
  200. Auto Transmission shifting problem
  201. Evosport Pulley Kit
  202. A stupid question
  203. Megan or Ansa exhaust shops in NY?
  204. New pictures of intake, interior, fog lights!
  205. SRT Catback OEM... $125 ebay !!!
  206. Thinking of putting a SRT6 engine in my base Xfire
  207. Double Wrench with Engine Code 94
  208. Magnaflow #14220
  209. Go Green
  210. What's the average price for an oil filter
  211. 0-40 Mobil 1 on Sale, Farm and Fleet
  212. New to the Game!!
  213. Intake connecting tubes
  214. muffler
  215. oil leak after returning from Carlisle
  216. 3.2L engine
  217. New Intake & Exhaust - time for a reset?
  218. C320 Airbox/eng cover --- ebay
  219. Connecting rod length
  220. Engine cover for those w/CAI - eBay $100
  221. exhaust Help!!!
  222. Code P2098
  223. Srt6 Lash Adjusters
  224. Check Engine Light
  225. replacement cat for stock exhaust
  226. slow starting when cold... any ideas?
  227. Upper Radiator hose ALERT
  228. What Do You Think Of This Oil?
  229. NGK Iridium Plugs
  230. Knock sound when turning car off
  231. 0w-30???
  232. SRT6 and N/A Thermal barrier coating
  233. MB engine cover for those w/CAI - ebay
  234. check engine light--bad gas???
  235. won't start
  236. One last detail b4 CAA
  237. Secondary Air Pump CEL
  238. Car won't start
  239. If you need a supercharger ... eBay
  240. clutch is jacked up
  241. Blowed-up real good!
  242. Accelerator Pedal Fault - Non Response
  243. Performance chip?
  244. SRT engine into N/A
  245. Coolant Flush
  246. ML320 and ML430 same engine cover?
  247. exhaust manifold
  248. Aftermarket gauge questions
  249. Anyone ever use Automotix.net for used parts?
  250. Airbox question for a CLK430
