- Smoke, oil at exhaust outlet
- EGR and Secondary Air Systems
- Trans
- Fuel Filter & Thermostat on Low Mileage Roadster?
- My car sounds like it has a turbo...
- White smoke for a few minutes upon start up
- Pulley Belt
- Fan control module/ ABS ESP issue
- Engine Temp and Gauge
- Radiator overflow tank removal question
- Experienced Recommendations needed for SRT6 upgrades
- O2 Sensor Questions
- Catch Can 'splained, Lucy
- Catcg Can 'splained, Lucy!
- SRT6 Swap?
- overheating slightly in traffic
- Megan M-RS on a Crossfire SRT-6
- Skipping Oil Change?
- Supercharger is not working at all..
- Help diagnosing No-Start - Electrical? But not RCM or CPS
- Weird Clutch Problem
- Buying Chrysler engine parts
- Where do I get a 'Special Tool 9120'?!?!
- Water in Gear Shifter Assembly
- Venting engine compartment through fenders
- propshaft bush
- Fuel injector cleaner
- Exhaust leak
- Check engine light
- Burning Oil
- Torque specs at fuel rail?
- transmission leak/oil leak
- Electric fan question?
- srt oil cooler
- Ethanol Percentage in Fuel Increasing
- Spark plug
- New K&N filter
- stalling at lights
- Cooling system - how to open valve
- How much rpm need to be
- Check engine
- 2 fixes needed - oil filter & low brake pedal
- Radiator Fan always on high, any solution??
- TPS Issue? HELP!
- cost for replacement of Left side value cover and gasket
- N/A - Engine + Drivetrain modifications
- Question for the electron gods
- Single piece aluminum driveshaft
- 2006 Crossfire cuts out then starts when cooled down
- Mercedes engine cover
- Rattle coming from 2005 NA 6 Speed
- Car dies after about 40 miles... no codes.
- RCM relays
- Misfire
- Wrong oil put in - advice please
- Replacing the clutch
- Not starting
- Too quiet
- cold air intake help!
- Oil Change Weird Happening
- Repair time,labor hours
- Mobil 1 Rebate
- Whistling/chirping alternator bearing?
- If someone can advice me please
- Limp Mode/Trouble Code
- Transmission fluid/Limp mode
- 2004 crossfire not starting
- Limp Mode
- 2004 crossfire
- Drive shaft /axles/diff removable
- How to remove rear drive shafts / rear axles
- Oil Choices, any Dexos options?
- How often do you empty your Needswings PCV catch can?
- flo masters needed
- Oil leak
- OD and ID for stock Coupe/Ltd exhaust piping
- xfire trans dip stick
- No resonator...no muffler
- 2.89 in a 6 speed
- 2004 cross fire
- Cat back
- Question on differential removal
- Engine cranks; no compression?
- wanted to Purchase magna flow
- Oil can and displays 'hi'
- Manual tranny fluid change and recommended oil
- body control module
- Information on our differential
- Flashing the TCU?
- Are my cats going out??
- Transmission Fluid Change/Drain Link?
- New custom exhaust
- How to get more HP SRT6 Roadster 2005
- Hi Everyone - New guy with a question
- Valve Head Cover
- Shudder issue, suspect TCM
- coolant flush and fill needs tweaking advice
- Shudder from 2-3 and intermittent Rumble Strip vibration
- Electric cutouts vs. downpipes
- Cataclean works
- Newbie with a Diff query
- Misfire but no EML
- Where is the neutral Safety Switch Override 2004 Crossfire Automatic.
- Throttle Position Sensor?
- 74mm throttle body upgrade
- Engine Oil Emulsification
- No Posi ???
- Where or who to go to for v8 amg swap
- possible pulley sound.. any suggestions
- Kaboom
- Intake question
- 911 exhaust tips?
- Air injection pump won't turn off
- $2,230 To Replace O2 Sensors?
- mecdoux
- Any good aftermarket gearbox/transmissions?
- Engine Swap
- New Seattle owner, transmission troubles
- Check engine light came up today
- Gurgle
- Oil neck removal? (Picture)
- No P-Code???
- Eurocharged jacksonville
- head gasket?
- 74 mm TB help !!!
- Huntings revs after TB work...suspect Y pipe connection?
- Driveshaft carrier mount
- 722.6 Transmission
- 74 mm TB help !!!
- Crossfire with Strange Shifting issues Please Help!!
- engine misfire when cold on srt6
- Will an '08 engine work in my '04
- New Headers
- Where to buy SRT-6 Throttle Body?
- Crossfire (first time change) Spark plugs gap and how to?
- Delayed Shifting Gears
- Ignition key gets stuck / throttle cable module
- Differential Leaking
- Muffler delete question
- newb adding a SCAI from needswings
- Transmission leak for Automatic
- O2 Sensors
- When to replace spark plugs?
- Check Engine Light
- How hard is it to strip and clean 74mm throttle body.
- Gearstick Moving
- Radiator Cooling fan not working
- oil/air filters/tires
- Differential Lubricant Question
- Wavetrac installation
- Good price for 2 air filters?
- Transmission slips into Neutral
- why does 'sponsor' not list our car ?
- Motor Mount Fit
- Backfire
- won't shift
- ugh! crankshaft position sensor
- Mopar Cat Back?
- Valve cover leaking again
- Stock muffler with chrome tips needs a home! Pay for shipping and it's yours...
- Induction roar
- need your ecm repaired ck here
- Issues after 74MM TB upgrade, fuel trims high??
- Car accelerates when trying to brake !!! Please help.
- New NA Exhaust Downpipes
- checking rear end
- Which MB Engine Cover?
- fuel injector cleaner
- Car dies while driving???
- Engine dress up
- Need clarification on checking fluid level of automatic transmission
- Srt-6 misfire
- 2000 SLK230 auto to 6 speed V8
- Idler Pulley bolt broken in block! Please Help!
- misfire that went away
- Muffler Delete Questions
- Need help ASAP!!! Transmission limp mode
- throttle body part numbers??
- V8 swap 4.3 question
- difference between these two tb #s???
- Vacuum leak, high LTFT, pcv hissing, HELP!!!
- Knocking Noise Engine
- transmission the does and don't (questions)
- Food for thought :)
- This is getting crazy. Can anyone help me???
- Air Filter Questions
- A thought about pulleys
- Exhaust Drone Megan RS
- Muffler Question?
- Opinions on Borla or Magnaflow
- EGR Not Ready, the valve have been replaced, drove 600 miles
- vacuum tap point for gauge, n/a
- Battery
- I did it anyway
- wet nitrous kit
- Car having (possibly) serious issue.
- ECU Modification
- Possible Cause for Fan Speed Control Switch DEAD
- any port intakes, and blower plenum on a m113
- Smog Check perfect but oil is going down
- Cps
- Engine bay dress-up?
- Fuel pump or Fuel pump relay?
- fuel bomb
- Replace O2 sensors
- Needswings intake or exhaust mods
- Supercharger not working-suggestions?
- Sorry for The Dumb Question
- Engine knocking and ticking
- Factory intake ducting.
- idler pulley & belt tensionor
- More Ponies... N/A Thread.
- Engine whine, ticking, vibration sound
- battery
- CAI with factory engine cover
- Engine coolant drain plug locations?
- Maf !
- Needswings XStream filter upgrade - worth it?
- Exhaust Muffler size
- Oil extractors
- Intake manifold gasket
- Water pump failing?
- Air filter cover
- oil filter
- oil or?
- Black Friday EC tune - $250
- Syfi's DIY DCAI
- Help please rcm contact required
- Supercharger: Crank vs top?
- modify exhaust
- Secondary Cat removal advice
- Coolant Leak, need some assistance
- N/A underdrive pulleys
- Water Pump Replacement
- Power Steering Fluid
- SRT - Magnaflow
- Tuned or not?
- Please Help: How to Cable Down d/s of Engine.
- Magnaflow Performance Catback System?
- Engine Mounts for 05' Limited Roadster
- Damaged Leaky Injector
- Air conditioning heat
- Anyone overcome the lack of a cooler T-Stat
- EGR Valve...
- Eurocharged Transmission Tune?
- 2004 Crossfire Timing Chain
- Throttle Body Upgrade
- srt6 limp home mode...help
- Valve Cover Leak and Torque
