PDA
View Full Version : Engine, Exhaust, Transmission and Differential
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14
  1. Change Spark Plugs
  2. Oil filter gasket?
  3. New REAL CAI on the way!
  4. Spintech
  5. Sprint Booster $250
  6. Octane Additives/Boosters
  7. Engine Cover Burning Hood Insulation???
  8. 6 spd Coupe or Roadster over 330 hp?
  9. Sprint Booster Help!
  10. In the UK & Wanna Mod My Crossie
  11. Sprint booster
  12. Install Sprint Booster
  13. K ompressor K rossfire?
  14. 8% power and torque increase
  15. AMG airbox installation
  16. Optimal Exhaust Tubing Size?
  17. Can't find where to buy Sprint Booster
  18. Marvel Mystery Oil
  19. Exhaust Grounding Kit
  20. ECU upgrade via OBD II port ?
  21. sounds and looks equally good
  22. Street true Duals
  23. What's up with the complaints re. Shifter/clutch ?
  24. Help me!!! I bought a crossfire 2 days ago! :D
  25. Which intake?
  26. SLK32 engine swap?
  27. 2006 Crossfire exhaust
  28. Intake-Worth doing?
  29. Exhaust question
  30. Coolant Color?
  31. who has the SI ecu upgrade LIST
  32. Conical vs. Reverse Conical
  33. Air Ram Intake/mods required?
  34. Low Fuel Light Blinking
  35. Do they make these?? Y splitter
  36. What companies make mods for the '06 model?
  37. Adding water to battery ???
  38. Another sound-clip of my home-made exhaust!
  39. High oil warning popped up... Quart+ overfilled?
  40. SpeedInnovation Honors Reseller Pricing 2-Week Sale [JLeviSW.com]
  41. DW Technik
  42. air intake for extra hp?
  43. New 2 speed supercharger
  44. SRT-6 Exhaust. Sound Good?
  45. engine
  46. Borla sound clip
  47. Cold Air Intakes?
  48. K&N and Speed Inn.
  49. magnaflow to produce exhaust system for xF ! if we speak up ! listed on site as...
  50. Supercharger for '04 Coupe?
  51. Best Exhaust for '04 Coupe?
  52. Link to K&N Filter?
  53. Additional Edu Tune Information
  54. All-in-one FAQ Thread - SpeedInnovation ECU Tuning Info/GBs/Specials
  55. SL intake? What parts?
  56. Evosport Vs Renntech?!? Confused?
  57. Reprogrammed ECU damages
  58. Number of 'O' Rings
  59. Ecu Tuning: Crossfire Ecu Tune! Ny/ct/pa/nj
  60. Any need?
  61. SRT-6 Xfire to 400 HP?
  62. anyone?
  63. Light Weight Flywheel ?
  64. Borla fitment on SRT?
  65. How good does the Borla sound?
  66. INMOTION Chip
  67. Techron Fuel injector cleaner
  68. Current Crossfire Problems **need Help Asap**
  69. srt motor low mileage for sale
  70. Resetting the ECU?!
  71. Magnaflow or Flowmaster
  72. Check Engine Light issues - need feedback please
  73. Supercharger kit for The Limited XF
  74. Ram Filter Air Intake
  75. 6.1 Ltr Crossfire
  76. Evosport Underdrive Pulley Question?
  77. Flamethrowers
  78. Cam Belt/Chain
  79. Modification Suggestions
  80. Guess that noise HELP
  81. Oil change prices getting better...
  82. *** M112 Engine Tech Info ***
  83. Magnecor Racing Wires
  84. Oil Leak
  85. Another Potential Mod ?
  86. Schrick Cams
  87. 9102 - Flywheel locking tool
  88. 3.2 Valves
  89. AC Pump Removal
  90. "A" Service [oil change]
  91. Help to ID a part
  92. How hot does your engine cover get?
  93. SLK 320 intake filters?
  94. Just replaced the engine cover
  95. Borla Cat-Back Exhaust Systems
  96. Mercedes dealer wont sell export parts!
  97. What's the fastest you "Allegedy" driven your Crossfire?
  98. Need more power
  99. HeLP Me! September 4th 2006!
  100. Catalytic Converter Failure
  101. warranty problems
  102. Catalytic removal, straight pipe project
  103. Chrysler 3.5 V6 motor
  104. Rev Limiter
  105. Video clip - Magnaflow 14220
  106. Rotten egg smell
  107. No more painting muffler tips
  108. Under-construction! Custom made exhaust!
  109. Injector Flow %
  110. Help!!!
  111. Top Tier Gasoline
  112. 6 Spd problems
  113. Track Video / Exhaust Note
  114. Exhaust
  115. Cooling Fan
  116. Supercharger boost
  117. information overload - enhancing performance
  118. New Custom Exhaust - Thoughts?
  119. Custom Exhuast
  120. car shakes when ignition turned off...
  121. Dealer said it was an exhaust moan
  122. Lsd
  123. Another dual exhaust video
  124. Confirmation that no exhaust/header is avail for SRT-6
  125. Dual exhaust sound clip
  126. disable ESP for dyno mode
  127. Just built my new ECU
  128. Kleemann tuning kits for Crossfires.
  129. Dual Exhaust Sound Clip
  130. Duramax Dual Exhaust Photos
  131. Increasing horsepower
  132. Today's Dyno Run
  133. Throttle Body Pics
  134. intake silencer???
  135. Intake diameters
  136. borla exhaust or upsolute chip
  137. magnaflow coming out with exhaust for crossfire.
  138. slk32 amg and srt6 (restrictions)
  139. SLK 230 or CROSSFIRE
  140. Brabus/Startech Exhaust
  141. Has anyone done a V8 swap in a crossfire ?
  142. New intake mod
  143. stock muffler
  144. Leak from rear diff
  145. Oil change indicator
  146. Back pressure?
  147. Borla Exhaust
  148. no muffler
  149. Neat video on MB-AMG website!
  150. Specs Help Please
  151. REDCROSS'S Borla
  152. Exhaust headers...
  153. What Ever Happened To ?
  154. Oil way over full - for last 500 miles
  155. bang for my buck
  156. Does anyone have this?
  157. Schrick Cams Info
  158. New Headers Arrived
  159. stock Crossfire muffler
  160. Contacted Kleeman about their supercharger.
  161. Performance
  162. Baseline Dyno Run Results
  163. Upsolute Chip Dyno/Proof!!
  164. is this the borla exhaust or is it CTD's own brand ?
  165. boosting the na v6...
  166. New Intake? Or is it a saskins?
  167. my supercharger, 6 speed
  168. the ultimate exhaust accessory...
  169. Modified Jaguar XK8 Intake on a XF?
  170. Car hesitates as clutch is depressed
  171. My Crossfire Went On Fire!!!!
  172. UPsolute Chip Tuning Crossfire Group Buy!
  173. Cold Air Intake
  174. Chrysler has done it again....
  175. feed back on upsoulute chip
  176. Oil Change
  177. OEM Coolant
  178. Long Block Photo
  179. wierd noise when accelerating
  180. How Loud's the Borla?
  181. 8.5 Quarts and reading is "HI"
  182. Now I'm Really Confused (oil)
  183. Interesting Stuff I Found
  184. Rev Limiter !!!
  185. Removing AC pump
  186. Trick Question !!!
  187. Extrude Honing Intake & Heads
  188. Crossfire Racing Exhaust Sound Movie
  189. Headers?!?!
  190. Awesome exhaust system for $275
  191. pics of exhaust?
  192. Specs. Help For Scca !!! Anyone ?
  193. 110 Octane race fuel
  194. is it the SL55 intake or the E500?
  195. Cat needs replacing after only 2,000 km's.
  196. Family line of the 3.2 V6
  197. Crud in the airbox
  198. Is the cat back on the SRT-6 different?
  199. Best HP Gain on stock engine?
  200. power chips
  201. Interest in dual exhaust
  202. Super Sprint Headers
  203. Performance Clutch ?
  204. Turbo Kit Price List
  205. Prices
  206. rear cats!
  207. crossfire header
  208. Throttle Response Is Slow!!
  209. Calling UK owners
  210. MAF & Injector Upgrade
  211. Carlsson Compressor Kit
  212. Carlsson Cams - Crossfire / SLK
  213. Amg exhuast
  214. Header source
  215. Upgrade clutch
  216. Still Waiting on Headers
  217. Question for the North
  218. ASK dual airintake????
  219. what the hell does this thing do?
  220. question about the magnaflow setup...
  221. best performance mods?
  222. Deep rumbling mustle car sound
  223. Cat -less exhaust
  224. ITG Filters
  225. Yellow Oil/Liquid
  226. Magnaflow Or Flowmaster???
  227. Saskins Intake
  228. Borla Installed!!
  229. Twin Turbo kit
  230. Mopar Exhaust
  231. Anybody try Flowmaster mufflers
  232. Rear Wheels Suspension
  233. Startech Exhaust
  234. Redline Racing Oil
  235. Headers
  236. Air Temperature Sensor
  237. Easy Question for the Veterans of the board, Air Filter
  238. new tuners
  239. Infinitas Supercharger
  240. Electric blowers....
  241. The Best Spark Plug
  242. Borla Tips
  243. "Check Engine" button ON
  244. Borla Sound Clips
  245. Since we all want more hp.......
  246. Speed Vs Rpm Ratio Comparison
  247. Service Indicator
  248. R170 SLK Supercharge Inv. Parts
  249. "Piggyback" Performance PCU Chip?
  250. Hey! What's the deal?
