PDA
View Full Version : Engine, Exhaust, Transmission and Differential
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14
  1. New Upgraded Mobil Jet Oil
  2. Antifreeze
  3. TCU tune
  4. IC Pump replacement
  5. Euro Flash V2
  6. Eurocharged.com
  7. What can this be - cracked fuel hoses
  8. K&N Oil Filter Experience?
  9. Crank pulley still ok? (pics inside)
  10. Track Tested: Exhaust cutout vs Dynomax Super Turbo Muffler
  11. Water Pump and Hoses
  12. plugs n wires???
  13. Nitrous and Engine Block Thread
  14. Weird plastic in engine...
  15. New hat for my pretty girl
  16. EGR Not Ready - is there a sensor?
  17. Mobil1 0-40 on sale at Wally world
  18. Should I buy a Crank Position Sensor
  19. Air sucking/hissing sound coming from engine
  20. crankshaft sensor
  21. Exhaust recommendations
  22. HOW do you change the fuel pump on a 2004 XFIRE??❓❓❓
  23. what the heck is this!
  24. Knock n Stall
  25. What Frickin' fuse?
  26. Exhaust Leak Need Help
  27. Crossfire runs rough - cold starts
  28. A few niggles...
  29. Pulstar Plugs. Worth the extra coin?
  30. Under engine splash shield liner
  31. Vacuum line under intake 3.2L (help)
  32. BEGi Turbo Kit - I give (sorry)
  33. Why headers don't increase power on v6 engines
  34. Crankshaft Position Sensor Help
  35. alright guys fuel injector question
  36. Code PO600 What is were is the Serial Communication link malfunction?
  37. Help!!! What muffler do I use.
  38. My New Needswing CAI
  39. Proper Spark Plug Gap?
  40. Cold air intake
  41. OBX is Maximizer or Maximizer is OBX?
  42. Low oil question - refill?
  43. Shield, Engine Lower
  44. custom heads
  45. Sprint Booster Install
  46. egr flow code
  47. New Hampshire 6-speed 500 (5.0) Underway!!
  48. Valve covers leaking/Needswings need gaskets?
  49. Air Condition Noises (Loud!!!)
  50. $350.00 oil cap?!
  51. Secondary Air Injection Relay Bank Issue
  52. Side Gapping Spark Plugs
  53. Transmission will not shift from park No Start
  54. '05 Air sounds coming from under engine
  55. Water Pump failing at 32k miles
  56. Tune up help
  57. P300 to P306 Codes
  58. Damnit! Flywheel recommendations?
  59. Damnit! Flywheel recommendations?
  60. What is the biggest Filter we can use to replace Needswings Single?
  61. OBX catback
  62. error p0106
  63. Cooling system fan question
  64. K&N DryCharger water resistant air filter covers DYNO TESTED
  65. 2004 CROSSFIRE Garrett GT 35R Upgrade
  66. completed front mount twin turbos on a N/A :)
  67. worth it or not.
  68. Catch Can
  69. transmission swap!
  70. Oil leak leads to new problem
  71. vacuum gauge on na
  72. upper radiator hose collapsed when engine is cold
  73. Correct filter for 05' Crossfire Limited?
  74. A Question of Firsts...
  75. Transmission filter...
  76. How do I do a Throttle Reset?
  77. N/A exhaust inquiry.
  78. Part Numbers
  79. Question - Potential Problem (moisture)
  80. Losing Coolant did Compression & Ic test
  81. A/C and heating wont turn off
  82. clean intake manifold?
  83. MBWorld 55 NA vs 55K internals
  84. Transmission slipping/problems
  85. Valve cover hose- Large Driver side
  86. M112K's, M113's and the NSG370
  87. Sprintbooster and CPS code.
  88. Intake
  89. Lost Cause in Performance?
  90. CX Racing Heat Exchanger
  91. NA fueling...
  92. 3.2 piston and rod dimensions please
  93. Intake
  94. Noisy valves???
  95. Replacing Woodruff key after crank pully came loose
  96. 3.2L to 3.7L nice upgrade
  97. Intermittent High Idle after 74mm TB Swap and Needs Wings CAI
  98. Looky what i found !
  99. Where can I purchase a Catalytic Converter?
  100. Good deal on OBX catback.
  101. Racing Clutch?
  102. Magna Flo Exhaust #16633
  103. size of the stock inlet and outlet
  104. Need advice on nw intake manifolds
  105. Gas Smell in the Oil
  106. Mobil vs Mobil?
  107. Engine Died at High Speed
  108. Magnaflow Exhaust
  109. SC oil change? Results?
  110. Oil Filter - NAPA 7078
  111. Intake Options Discussion for N/A cars
  112. Loud noise from air pump, broken?
  113. 2005 Crossfire starting and running problems
  114. Thinking about engine limits and swaps.
  115. Knocking sound at idle - LOUD
  116. Paper vs Fleece Oil Filter
  117. Made just for us!
  118. c32 amg engine component specs?
  119. Installing Turbo on N/A, help!
  120. Oil Catch Can
  121. top SRT6 parts to have handy
  122. 90 degree design stolen from Buick
  123. check engine light
  124. How can I tell "Drive Cycle" procedure is complete?
  125. Help
  126. SRT6 stock exhaust/Megan drone
  127. How much does the SRT TB Flow?
  128. Starting
  129. Which Petrol
  130. You've really done it this time Ollie
  131. 74mm throttle body on ebay
  132. NA Exhaust options.
  133. Skip
  134. Idler Pulley (not tensioner) seized...why?
  135. Alternator Help
  136. Oil leak redux
  137. Aftermarket Radiator
  138. Looped Fuel Rail?
  139. Before I break something. Help!
  140. Oil Change Issues
  141. Cat Back
  142. Check engine light goes on and off.
  143. Turbo for $11.76
  144. Exhaust note explanation please!
  145. Motor help!
  146. New straight pipe on my '06 Crossfire
  147. Evap System Inspection
  148. exhaust replacement
  149. Pie in the sky question
  150. NW DCAI vs single CAI Dyno ?
  151. Transmission Help Pleaseee!!!
  152. Battery Light
  153. Deep transmission pan
  154. Eurocharged Log Thread.
  155. plug wires
  156. Header Discussion
  157. Help, what to say to the mechanics at the garage?
  158. UOA thread
  159. TCU tune info
  160. Lower Intake Temps
  161. rubber snubber on top of oem exhaust rear bracket
  162. New dyno on tuesday
  163. Crossfires - Interference or Non-Interfernce engines ??
  164. Air Condition Noise
  165. Crank pulley seperated. Checked after low oil light.
  166. Which exhaust setup
  167. Motor!
  168. A/C compressor issue
  169. Condensor assembly
  170. Issues keeping Magnecor Wires plugged in?
  171. Sweet Exhaust, check it out
  172. ATF Fluid
  173. Nsk srt6 supercharger oem replacement bearing
  174. Supercharger newbie - air flow, what's the path?
  175. Tri exhaust?
  176. Project 69 ... XF 370
  177. Need MB Part# for N/A Air Filter
  178. Exhaust!!
  179. Afr
  180. SRT6 family need help.
  181. Megan Muffler v. Magnaflow Catback (Video)
  182. headers
  183. Oill filler extension
  184. Varex muffler help pls
  185. High low oil sensor on engine block
  186. Crankshaft Position Sensor (CPS) Screw Lost =(
  187. What's going on!?! Engine issues
  188. wix57078 change??
  189. N/A Straight Pipe
  190. Borla has two part numbers for NA exhaust. One is substantially more expensive
  191. maxicartune exhaust
  192. MCM turbo build
  193. exh.
  194. Ordered the OBX ( Borla copy ) cat back
  195. Could really use some assistance on finding headers
  196. Interesting Tranny Article
  197. Secondary air injection
  198. Hi HP SRT's and V8 swappers ???
  199. P0410 - How to fix it for those who have fixed it already
  200. Cold Air Intakes...Snake Oil?
  201. how much to sell my motor with tranny, harness and ecu?
  202. First engine code...
  203. breather cover leak
  204. PO715 & PO730!!! Transmission speed sensor
  205. The dreades P0410 code
  206. Oil Consumption In Test Cars (Consumer Reports)
  207. New black wrinkle paint valve covers
  208. skeptical
  209. Chrysler Dealership Oil Change Screw Up
  210. Mobil1 0-40 at 53,000 miles
  211. what grade oil are you running? need help. high miles oil options please
  212. Check Engine Light On
  213. Baked potato mod/worth it?
  214. Magnaflo catback did not line up under car
  215. Conductor plate pricing and location?
  216. Engine coolant?
  217. Mobil1 0-40 5qt Jugs $22.47 at Walmart
  218. R2 Performance Package
  219. Dual Dual Magnaflow setup
  220. Personal Invitation?
  221. Clutch questions
  222. Son of POP or POP part 2.
  223. Did you know ?
  224. Help! Strange noise
  225. ...HELP...how do I put on the belt???
  226. Pizza's Turn
  227. Should I change the engine oil?
  228. Aftermarket cams?
  229. 43$ fuelpump
  230. Help - supercharger sounding unhappy - need a garage to look at it
  231. Which injector is best?
  232. Urgent! I need help clutch malfunction
  233. Oil light comes on and off
  234. Are there any simple mods to increase hp?
  235. v8
  236. Rear cats on a NA
  237. SRT6 or V8??
  238. how much air is too much
  239. Need help sourcing a cooler. Please take a sec and give it a look
  240. How big is it?
  241. Please help with eng./trans. compatibility question
  242. EuroCharge tune & Sprint booster
  243. My Exhaust
  244. Engine oil
  245. AFR adjustment via AFPR
  246. HELP. Auto Transmission Fluid overflow
  247. Need Exhaust Tips Help
  248. OBD II monitors take their sweet time!
  249. Help Please
  250. What is in my Rad?
