- Leaking Oil Filter
- Drag Specific TCU Tune
- Synthetic ATF instead of Pentosin 11S in PAS ???
- Oil Cooler Gasket Leak
- Air/Intake question...
- 2005 6spd loud squeak coming from under the car.
- chrysler crossfire thermostat housing O ring
- no keys
- srt6 supercharger
- srt6 supercharger
- 2006 Crossfire P0425 Code
- Transmission 13-pin connector
- Product Review: MSS ECU / Tieken TCU
- conductor plate
- Oil Leak - Transmission?
- Dc 4&5 shift volume
- Got a Flowmaster Super 44, huge mistake, looking for advice?
- Performance Air Filters
- PO410 code - blue check valve
- Ignition/Thottle Body Extension Cable Installation
- Torque converter part number
- Mercedes Part Numbers
- Missing cover
- antifreeze
- Odd issue
- How to replace auto transmission gearbox
- Radiator replacement instructions
- Bad news for Californians.
- V8 Swap
- 3,91 rear in a limited or SRT
- Oil leak
- Floor Shift Assembly
- Whirring noise when accelerator is pressed
- New support bushing
- M113K Swap Questions
- '04 hard lurch putting in gear, too many lights, 31K
- Air con not working
- Crankshaft sensor
- Rumbling at the rear on acceleration..
- Source for Brand New Driveshafts (SRT-6 & Limited)
- how you adjust manual tx linkage?
- Changed conductor plate now no start
- White smoke
- how to reach manual transmission linkage
- Unknown part- clicking noise?
- Just want opinions, why because you are the real deal...
- limp mode
- Driveshaft Support and Bearing
- Hot start Problem :(
- SRT-6 Muffler and Resonator Delete
- Whining Sound In Engine Bay
- A good place for wires and plug
- Intake ideas
- Possible Oil Leak
- Recommended fuel filter/pressure regulator
- Transmission service
- Multiple Cylinder misfires - Check Engine
- Idler pully broken in half
- poboys improved cold air intake
- rough shifting
- Cylinder heads leaking
- radiator hoses
- Idler pulley question
- The engine won’t turn over but we have power
- Help with P0104 DTC (Previously posted in Troubleshooting & Technical Forum)
- Help "flywheel" needed...
- Car will not shift out of 1st gear when driving
- Engine block heater/warmer
- low fuel light erratic
- Delayed Shifting from stop position
- Skreem, battery, and compression
- Transmission lines fittings ???
- Engine swap question
- 2005 Engine gaskets? Help please 1.10.2021
- transmission lines
- Supercharger Pulley damage
- Engine oil leak AT-205 additive
- Auto Trans shift question?
- adjusting clutch pedal free play
- Transmission Fluid, Differential Fluid at 100k Mile
- Fantom oil leak!
- Getrag 226mm Rear Differential Swap
- Please confirm this is the correct Trans fluid b4 I mess something up
- REAR Cats on SRT-6 Dented on the bottom?
- Cracks in my DRIVE belt ... now what?
- '05 six speed coupe bushings
- Watched a YouTube video that gave a little more insight into oil catch cans
- Flowmaster Super 44
- Automatic trans.
- Best setup for the SRT-6 exhaust (OFF Road Only) Use
- Crossfire rear axle shafts N/A vs SRT6
- Not going into drive when brake on where is the shift interlock switch and where can
- bigger throttle body
- New Covers v. Gasket
- Tone down catback exhaust.
- Sooty Exhaust tips
- Adding Qtp Qtec33. Cutout
- V-Tech TCU
- Intake manifold question
- YouTube discussion and Teardowns
- Limp mode issue
- Plz help i have put all new parts in.
- Manual transmission to M137 V12
- Finally : A drive shaft repair shop.
- M113k swap oil cooling?
- Time sensitive plz help !!!!
- Car stuck in Driv & Neutral!!!
- Has anyone seen damage like this before?
- Thundercore Ultra Spark Plug Wire?
- Car stalling
- need to know how to remove the muffler-its a limited
- Been reading on the MB site but do these motors have issues with the balancing shafts
- 6 speed serial # help
- Just have to laugh
- Exhaust flange issues
- Test PIPES Installed and "Loving Every Minute of It!!
- replacing Driveshaft Support and Bearing
- Automatic Engine in Manual Car
- Mixing oil grades
- Oil Change at Ford Dealership
- Gas guage inaccurate
- Scan Tool
- 2006 Hard Start Issue
- Fluid leak
- MAF sensor tool
- stage 2 clutch question
- Turbo add on?
- LSD Wanted for 2007 Crossfire LTD Auto
- Replace Thermostat along with coolant flush?
- Oil level sensor leakage after oring replacement
- Skreem module
- Oil residuos on engine
- Members @ V8 Swap and totalled Crossfires!
- Plugs owner manual Vs NGK
- Auto-Stuck in Park
- Clutch not engaging what gives ???? Plz help
- Thumping noise from rear of car
- Kinda lost need help with losing acceleration still...
- Question on changing valve covers 04 XF 6spd
- Identify pulley?
- Grinding from Rear end 05 Crossfire Auto
- Which gas pedal will fit my car plz help
- Shifter thingy removal?
- 2004 auto tranny won't shift from Park/ Secondary Air Injection
- P0171 and P0174, base engine
- Keys work! Fuel injector went out over 2 wks
- Possible Water Pump Replacement
- Exhaust performance
- 2005 engine stops in middle of road
- Do you Recommend Changing Spark Plug Wires
- Should I replace conductor plate?
- starter circuit and skreem in detail
- O2 Sensor
- Indicator relay
- Battery Positive Terminal
- Help: Still In Limp Mode
- SRT-6 Gearbox Issues
- Frozen ignition switch, need to get out of Park
- Help With Installing New Tranny Plug Connector
- Oil catch can out of eBay
- Transmission Fluid Change
- Need Desparate Help on Limp Mode Fix
- My N/A 5.5 AMG Swap Thread
- Clutch Alignment Tool
- Kirkland Signature Full Synthetic Oil
- What to look for when buying Supercharger?
- Transmission Cooler Return Line
- Socket screw fell out of transmission gearbox
- Oil Leak ??
- Manual transmission stuck in 6th gear
- It had a light surging problem and then...
- Crossfire Engine Recycle
- Cheap Mobil 1 0W-40
- Crankshaft Position Sensor or Camshaft Position Sensor
- Automatic wont go in manual mode
- What diagnostic scanner to buy?
- '04 Crossfire code
- Temperature Needle Rises At Idle
- Does anyone here use a OBDScar OB11/EOBD scanner?
- Ohhh ... crap. Shift linkage disengaged
- Another limp along car.
- How to jack up the rear.
- Transmission dip stick and seal kit . . .
- very little heat???
- Okay Now in Limp Mode Need Guidance
- Swap a SRT diff into a NA car - Plus LSD
- Autostick
- Trans swap
- Transmission noise?
- 3k @ 77mph, is that normal?
- Manual pops out of first gear
- Overheating?
- Procedure for replacing flex joint?
- Pressure points for jacks for an oil change
- Engine interchange
- Anyone know what this sensor is?
- Need sensor part # please
- Engine hoses
- Magna Flow
- My new Engine Cover
- Vacuum Line Inquiry
- oil filter
- recommended rpm's
- Mass air part number
- Ecu tune
- Ecu tuning
- OEM exhaust
- '04 Crossfire Exhaust
- Car will not stay started / SKREEM Module?
- Clutch and Shifter
- Car won't start
- Manual Gear selector Rod
- Magnesium Valve Cover Corrosion
- Srt6 tbi?
- Engine and gearbox noise
- Another thread putting SRT6 motor in N/A
- Phantom Limp Mode (HELP)
- Why reset the throttle body?
- Valve cover gasket part numbers the same?
- Another 3.7 swap
- Accelerator taking a few seconds to react with engine
- Hard Starting
- p0600
- Should I be concerned about this?
- Rear cat removal sound clip
- 2007 Crossfire won't start
- why i think you should get headers
- Car keeps dying
- tcm troubleshoot
- Engine Mounts & Transmission Mount Part Numbers Please!
- Mechanical concern
- clutch solenoid resistance
- 722.6 Unfamiliar Part
- Transmission grind (manual)
- Trans Fluid?
- 2 step with me...
- Rcm
- Trans fluid
- SRT to NA
- Muffler delete on N/A
- 5.4L AMG with 6 speed
- SRT Throttle body outside diameter
- X pipe in place of rear cats
- Spring damper on clutch pedal
- Another Strange Transmission issue
- Strange transmission issue
- New Exhaust Tip
- Photos of my Bosch 0392022003 intercooler pump after 132,800km (82,500 miles)
- Transmission
