View Full Version : Crossfire Coupe
- Push to start
- 2004 Chrysler Crossfire will not turn over
- Neutral Safety Switch Part #?
- NeedsWings oil catch can and Cammus Windbooster 3S throttle controller.
- Changing throttle Body on my '05 Coupe Limited
- need ignition help
- 2005 car start issue
- 2004 Crossfire limited won’t shift out of first gear?
- Engine cover.
- Dealership searching for parts - Lifetime warranty woes
- New to the group
- Bas/esp light
- '04 Crossfire Coupe is making this sound.
- Power steering noise - can anyone please advise me. It sounds like belt issue but sto
- Weird problems when my lights are on...
- looking for hood pins
- I need help choosing manual transmission fluid
- Oil level sensor
- SRT6 on Hemmings
- Trunk interior trim
- Looking for a front right signal lamp
- 02 sensors hard fault but tested resistance 9.0 and 9.3 what's that mean they want to
- Cruise control will not work while lights are on
- Aston Martin DB5
- Orange coupe
- Our '06 coupe
- Need a new TCM!
- Autohaus Cam Sensor
- Wing goes down manually, then right back up and flashing button
- Torn steering wheel
- Recommendation of a tool set...
- Beeping above 75 mph
- Oxygen Sensor Problem? Or Crankshaft Position Sensor Problem?
- exterior door handle removal
- Defroster Woes
- Front indicator lens help
- Crossfire front bumper lens and central locking
- Car lost ALL power at idle
- Transmission issues??
- Huge Problem missing key
- Alarm randomly goes off and Spoiler doesn’t work at all.
- Electrical issues?
- Central locking and amplifier problem, wondering if I can get some direction?
- Fusible link
- Hard Shift?
- key doesn't open
- cargo area light bulb
- oil: which brand?
- Paint condition
- Foggy front headlamps
- Mirror
- 6'2" vs. the Crossfire
- Lost my only key
- To Buy or Not to Buy
- spoiler paint full of bubbles
- spoilers opens and remains open - it is a 2005
- 2004 Coupe Questions-Locks and Instruments Illumination
- I give up
- Heater resistor
- Strange noise from driver side rear on acceleration/shift.
- Dome light fuse location
- fuse located for the dome light on '04 Crossfire coupe
- Disentigrating Intake Manifold
- Excited new member here:
- Seattle area mechanic?
- Cedar/Black Interior
- Installing srt-6 seats. Dont know wiring.
- Should components work without PCM connected?
- Difference between model years if any
- car won't stay running
- 2004 Crossfire No brake lights
- Soldering the RCM board
- Where to buy "jack pads"
- only have 3rd and 4th 05 coupe limited
- Trim Piece above windshield
- Looking to buy - pricing is all over the place!
- Mercedes Space Saver Spare Tire
- Metallic Vibration/rattle in the front when accelerating hard.
- Accelerator taking a few seconds to react with engine, maybe the Throttle Body
- Looking for suggestions
- Vibration droning?
- Empty gas tank
- AC/Heater/Rear defrost issue. I've searched..
- PLEAAASE how he did the stearing wheel and the shifter ??
- Key
- Hardtop to Convertible?
- 2004 crossfire automatic shifting problem
- year of manufacture
- Transmision problem
- Alarm siren/ locking pump
- Need Air Filter Cover Screw
- Head Lamp Restoration...
- 2005 crossfire convertible
- Civic Type R
- Chemical Guys - Best Car Wash Bucket Kit - Best price I've found!
- Powered by mercedes emblem
- Low Cost Premium in Kansas
- Finally found a great foam cannon!
- Water pump or pulley going bad
- Key fob not working
- Replacing all oxygen sensors
- Chrysler Crossfire ride....low profile tires.
- Hood pad/insulation
- Portable Air Compressor - Is this a good one? Definitely is cheap on Lightning Deal
- What part number pease help me out
- Repair car
- OBD Socket
- Ignition switch locked... suggestions?
- AMG BADGE on 2006 Coupe
- 2004 Coupe for sale in Orange Park FL
- 2005 coupe base. Can I install a pair of rear speakers?
- Available modifications
- Key stuck
- How many of these are left?
- New SREEM pricing make me want to Scream!!
- Spoiler operation on lock/unlock?
- Freshened up my Crossfire
- What to look for in a used Crossfire
- You are awesome
- Speaker advise
- Show us your custom chin spoilers
- RCM again?
- Engine Light Came On Now It's Gone
- Car Starts and Stalls 2005 Crossfire Coupe
- Brakes - brake pedal travel
- Marker Lights Randomly Flashing
- Pulled a McGuyver yesterday...
- Spoiler problems
- Any body know why
- front bumper cover
- Wayne has a SRT-6
- Whine whine whine whine whiiiiiine. WHAT THE EVER LOVING CRAP?!
- Door replacement
- Resonator delete
- Installing 'new' side mirror
- Driveshaft issues
- Rain guards? :)
- No
- Sound System Trouble
- Seat Cover Clips
- Cabin ceiling cover/fabric falling apart
- TPMS Receiver Replace?
- Misfire and backfiring help
- Car over revving and BAS ESP light on
- Fender Side Grill Removal
- Seeking to buy NEW headlight
- tires and rims
- Top Speed?
- How do I convert my Xfire to run on e85?
- Build/Option Code Tag
- My Crossfire brake lights flickr
- Issue with battery drain
- My crossfire roof is leaking
- Putting out feelers - sell 2005 base coupe
- 2004 crossfire 6speed manual
- XF rear towing questions
- Beeping
- Air won't turn off
- Rear hatch lock sticks
- Crossfire does not start and does not crank
- I got into accident how much to replace bumper?
- Gas smell coming from the outside
- Starter makes noise; engine not cranking
- Which panel to open? Help
- Turn Signals
- HID Headlamps
- Oil
- P0410
- P0410
- Cracked Front Fascia - Repairable?
- Chrome bumpers good idea?
- Top Window Trim Source?
- 2004 crossfire 6 speed manual- Need Clutch safety interlock switch
- Trunk stuck locked with bad vacuum pump
- ABS, BAS/ESP, Emergency Brake, Brake Pad light, Spoiler deploys on start
- Rear Suspension noise.
- Looking for headliner installer near San Antonio, TX
- Paddle shifters
- airbag sensor pad
- Guys please help me to save money with right parts, Subject Clutch
- I need help with a part
- Help with amg wheels
- Both Fob's Not Working
- My Crossfire starts well but dies immediately and repeatedly.
- Fuel Pump Question
- Should I buy a crossfire?
- Haven't driven in a few days and left key in it.
- Bumper cover and fog light attachment
- Helpplo
- Car cut off at stop light
- Redness code for 2nd aol will not set. Air pump running
- 2004 NA Front Bumper Boring!!
- Has your SKREEM failed multiple times???
- passenger seat occupancy seat sensor '08 limited
- Questions about wheels
- '04 crossfire key not turn to crank car, wiggled steering wheel it cranked, now can't
- Change Serpenrtine Belt
- My 2004 crossfire
- Opportunity to purchase again
- Rear main seal and clutch replacement?
- Gear stuck in park
- 203,000k on the dash and still going strong.
- battery induced boo boo
- request pricing advice '04 XF 49,xxx miles
- Production numbers by exterior color
- 65k miles - service?
- Sprint booster
- 2004 Crossfire price with 10k miles
- Im about open fire on my X~Fire !
- How to solve this issue
- Lowered springs
- Retired
- '04 Spoiler "no workie"
- Battery Light On, Possibly Alternator?
- Transponder Ring
- Help buying proper and cheap motor mounts
- Not start crossfire
- Selling my modded low mileage SRT6 for cheap!!
- Chrysler Bringing The Crossfire Back?
- She's been in hibernation
- Help with leaking Power Steering fluid
- Power steering fluid. Must use OEM?
- Too Low Idle
- Advice for hurricane Harvey victim
- 2004 Cossfire starts, but won't go past 2000 rpm
- Cleaning vents?
- Strange Air Pump Behavior?
- Have any of you encountered a brz/frs/gt86
- MAP or MAF?
- 410 CEL relay location
- Squeek by left ear?
- Evaporator Drain Location / Smell
- Need help opening hood - spring mechanis, lodged between hood and grill
- Proper spark plugs for crossfire limited?
- Burning Scent From The Heater?
- Remote key won't lock the doors on 2003 Crossfire
- Key fob AND alarm not working
- Passing the batton...
- Oil Quantity Confusion
- Is it my alternator?
- Two Water Pumps?
- '05 crossfire 107k miles $7k
- Is rust a big issue.
- Intake Question
- You know...
- Passenger door lock?
- Error engine is taking air
