- lost key
- Two lonely wires can’t figure out where they go! Help
- HOW/WHAT to TEST if You Have Starter Wiring Issues?
- Lifting a crossfire. Suspension drop problems
- High pitch bird type noises coming from the engine.
- Transmission filter locations
- Double din Radio install
- Battery grounding issue?
- Blinking Dash Lights
- towing button light flashing
- Electrical or computer??
- No crank issue
- Mercedes specific codes
- Safe to Tow a Short Distance with Driveshaft on?
- wrench for convertable top
- No start, no crank, but dashlights (sometimes )
- top problems...episode 1,000
- Automatic: Wont go back to Park
- Engine stalls out every few hours - help!
- trunk rattle
- Tonneau latch locks but come switch blinks…until…
- A slightly different Central Locking issue
- Replacing rear brake pads?
- Reset airbag
- MB A1937701798 and A1937701898
- Dim Low Beam, Left Side
- Spoiler not closing… Doh!
- Top & spoiler Inop
- AC suddenly blows hot air, any suggestions?
- eletrical issue
- Engine oil, Best
- Tonneau cover locks top down, not top up
- problem convertible top not closing properly
- Dtc 168?
- Parasitic draw
- Audible warning briefly with top down manually
- Need specs on machine screws holding latch mechanism in door.
- Help with broken vacuum tube
- Rcm
- Coolant level warning comes on with headlights
- No Wipers. No Turn Signals. No Entry using Remote
- changing the displayed units
- Key Fob and AntiTheft Alarm not working
- p2040 Reductant air pressure High Input/6 other DTC
- Pulse control module
- ESP intermittently off
- Replacing Brake Switch - removing panel
- Rear glass rubbing
- Code color
- Dashcam wiring through the firewall - path?
- Which 2006 cars immune to "Sticky Key?"
- How to replace fuel tank sender?
- Cold Weather & Louder Idling/Acceleration
- 89,000 miles never used premium!
- Engine Bay Relay Module. What is it in charge of?
- Does anyone know where I can get custom electrical modifications?
- Catalytic Converter Going Bad?
- Hood Safety Latch
- Secondary air injector motor
- OBD port connection
- Starting issue
- Potential upgrades to my '05 limited version
- Intermittent Starter Problem
- Leaving Key in Ignition Switch
- UK 2005 Crossfire automatic no-start
- SKREEM Turn Signal Flasher Relay Issue
- SRT6 P0455 Evap System Leak Detected Large Leak
- Drive train rumble from a stop
- Flutey noise when driving
- Ignition switch won’t turn off
- ECU Troublesoot
- ABS ESP lights and front right brake acting up
- Cylinders #4 & #5 misfire code
- Parasitic Battery Draw
- RE: Another Crank no Fire
- Bad Head Gasket or PCV issue?
- seat
- engine power limiter/spoiler/Odometer/ speedometer
- Central locking vacuum pump not working with key
- Parisitic Battery Drain, TPMS Module
- Top inoperable - where to start?
- No crank no start
- RCM - Question for tighed1
- 2005 crossfire drain / fuse question
- Error code 52 and will not start
- '05 Xfire starting curiosity!
- Won't Start
- Will not accelerate fast and has a sputter
- 722.6 Transmission Fluid & Maintenance
- Replacing battery
- Won't Start
- Tow button Flashing and exterior lights all flashing
- No Airbag Lught - DTC - Implausible Signal in DRBIII
- TPS & BAS ESP Issues
- Airbag Light
- replaced ignition switch but key still sticks in start & cranks no start
- BAS/ESP light and limp mode
- Oil light goes on then off when the oil level is okay
- Replacement for siren module
- Automatic Transmission gearshifter stuck
- Looking for spare key
- In operative key fob
- Break NIGHTMARE! (pedal squishy & traveling)
- Input needed
- Clips for Convertible Top ?
- ECM 2006 Chrysler Crossfire
- Bad fuse?
- Help diagnose intermittent rough running
- car running with no instruments working no a/c
- How much does it cost for a locksmith
- Cant control fan location, blows out every vent all the time.
- key wont start the car and wont go into gear
- All warning lights on, key fob works, no code, crank no start
- Fried my passenger headlamp socket - need help
- Roof bucking and window bow won't drop into place.
- Help with cut wires PLEASE
- Trying To Replace A Fuse On My Crossfire Fuse Box Looks Different
- cps , after 3 no luck . Now it's igniting at a tone wheel and pulse ring could be a
- SRT6 - Misfire
- Hello. The wire harness in the trunk?
- Parking brake, rear pads, and hardware
- Relay Control Module
- Camshaft position sensor bolt size
- CPS Install
- Transmission Will Not Shift
- no crank, black rectangel/square in the IC
- Suggested Troubleshooting steps for stalling
- 2005 Crossfire roadster key and shifter problems while parked on slight incline.
- Key stuck in ignition
- CKP location and more
- Gremlins in electrical
- It's ALIVE!
- Won't start after stalling, manual trans
- Manual trans issues
- CLP shenanigans
- Locking System won't disarm with FOB
- DRBIII in Plano TX if needed
- 2006 XF engine stumbling.
- Pictures of what's inside the gear shift lever assembly (SLA)
- 2005 Crossfire Shift Knob Problem
- Hood strut/support
- No crank after new keys
- Crossfire Key Diode
- Battery draw
- Lock/Key Issue
- Issues with O2 codes
- AC charge ?
- ESP/BAS Light // Stalling on streets
- engine shut down
- Blown radiator: a case report, and a new possibility
- More pesky dead battery woes!
- Always something! Code P0007 and C101E
- July 2023 Car starting issues – probably the RCM
- Blower Motor Continues to Operate with the Keys Out of the ignition
- Chime when shifting into park or reverse
- Will not crank
- Electrical Problem
- Oil filter "spike" loose
- 2006 crossfire Limited Coupe BSA ESP light
- Looking for dyno tuning in NE Ohio
- Data link connector
- Door latch replacement question
- Windows opening by themselves?
- Top won't go up or down
- 2005 Crossfire roadster basic has a relay static noise
- 2006 Crossfire Cranks but will not start--Tried Many Suggestions
- Small board with 2 wires under cowl?
- Drain line - evaporator air con coil
- starting issues,
- 2005 Roadster battery issue again
- RPM's Dropping to Zero (P0103 - Circuit A High)
- 2004 dies while driving, wont start
- ABS Pump/Module
- Flakey AC Fan Switch
- 2006 Crossfire Dead
- rear main oil seal & cover
- Mr
- Coolant light problem
- Does Manual have a TCM and where if so?
- data link connector Pin 5 wire routing
- 2006 Crossfire won't start
- Da Beat goes CPS
- "Fin" won't stay down and can't lock doors
- Need help finding extended lug bolts for 20mm spacers.
- Having fuel issues.
- Rear Light Markers not wired in?
- I'm stumped on code p0446 please help
- Headlamp adjusters
- Trouble communicating with ABS module
- Ignition Coils
- Won't Start
- I am on a road trip and got a P2098 code, safe to drive home?
- 2006 crossfire coupe intermittently won’t turn over
- Engine stops at Idle.
- Urgent need to fix
- Magnetic clutch of the AC compressor
- Crossfire coolant light on and AC not working properly
- ISO Original Manufacturer's Wiring Diagram
- Passenger power seat will not move
- Roof issues again
- Flickering Dome Light
- Rear defroster noise
- Brake pedal goes down very far
- BAS/S Light comes on
- Who can diagnose my 2005 Chrysler crossfire Mercedes-Benz or Chrysler
- Custom Gauges / Clocks / Dials
- Dash LED lights are dim!
- Crossfire 2007
- radiator fan runs all the time even with car off
- Replacing Seat cover with NOS
- Instruments and gauges working intermittently after being wet
- Dang! '06 Xfire no crank issue "AGAIN!"
- Passenger side headlights out entirely
- throttle problems I think, HELP
- Hydraulic fluid for top and cylinder repair
- SRT6 2005 gasoline smell when tank full
- SKREEM issue for UK owner
- Wire harness from washer reservoir
- 2008 Convertible top issues
- CHARCOAL CANISTER SHUTOFF VALVE OHM value
- Cut wires
- I KNOW this has been asked a million times and someone will likely yell at me but…
- Spare RCM and BCM
- Performance Chip
- Replaced RCM
- Auto-Shifter Shifting in Left Turns in Manual Mode
- Variation on the Mystery no start
- ABS rear senor cable issue
- Car Bucks and Stalls at Random
- Urgently in need of new working keys 2005 Ltd
- Two break pedal switches?
- PO is a POS
- Central locking failure
- Accessory Belt Tensioner - stiff and squeaky
- Morimoto 2strock 3 led bulbs
- '05 Xfire Limited: ECU / RCM box cooling
- How to lock coupe
- Squeal from front of engine?
- Supercharging to Supercharged M112 -> M11k-ish
- Some vacuum lines
- Computer issues
- Problem with spoiler
- '06 Xfire hic-up!
- Throttle bodies and Intercooler Cap.
- What's going on?
- Poltergiest in my Roadster?
- Changed CPS, still having problems.
- Remote fob problems
- Skreem Questions
